CCM_CLKO as CLK input for peripheral
4,001件の閲覧回数
thorben
on the iMX8M mini, can we use CCM_CLKO from Clock Control Module (CCM) as an input clock for some external peripheral on our PCB or is CCM_CLKO just meant to be a test/control clock output and not intended to serve as an input clock?
Thorben
3,791件の閲覧回数
Rita_Wang
Hello, I got the update from our expert team.
Checked with our SOC, it's not recomended to drive external device by CLKOUT. Jitter may also relate to PCB layout.
The CLKOUT is not designed for the purpose. It's just for monitor.
Hope this can do help for you.
Have a nice day
Rita
7 返答(返信)
3,791件の閲覧回数
Rita_Wang
Could you tell us which product are you using?
3,791件の閲覧回数
thorben
I'm sorry, I only added the processor type to the tags. It's a iMX8M mini.
3,787件の閲覧回数
Rita_Wang
I got the update from our expert, Please refer to the register definition. OFFSET: 0x128
3,787件の閲覧回数
thorben
Thank you. I already know these values from the reference manual. I want to know if we can use it as an clock input for external peripheral? Does this output have for example jitter? If it's just a monitor clock and it maybe has some jitter, we wouldn't be able to use it.
3,792件の閲覧回数
Rita_Wang
Have a nice day
Rita
3,787件の閲覧回数
Rita_Wang
We are confirming it for you.
3,787件の閲覧回数
Rita_Wang
I have sent your question to our expert team, when I get update I will send to you as soon as possible.
