Hello All,
I want to burn the SRK fuses in i.MX8MQ devices to enable SecureBoot.
What is the best way to burn SRK fuses in production environment?
Thank You,
Pratik Manvar
Solved! Go to Solution.
Hi pratik_manvar
one can use uboot for fuse programming
https://imxdev.gitlab.io/tutorial/Burning_eFuses_on_i.MX8_and_i.MX8x_families/
Hi pratik_manvar
Hi @igorpadykov,
Thanks for your answer.
I am able to burn fuses using "uuu_imx_android_flash.sh".
So, there are two ways to burn secure-boot fuses
/sys/fsl_otp/HW_OCOTP_SRK1
/sys/fsl_otp/HW_OCOTP_SRK2
/sys/fsl_otp/HW_OCOTP_SRK3
/sys/fsl_otp/HW_OCOTP_SRK4
/sys/fsl_otp/HW_OCOTP_SRK5
/sys/fsl_otp/HW_OCOTP_SRK6
/sys/fsl_otp/HW_OCOTP_SRK7
/sys/fsl_otp/HW_OCOTP_BOOT_CFG0
