Building uboot 22.04 / flash.bin failed
arno_0
before adding my own board to uboot I try to compile flash.bin for the imx8mp EVK board.
I cloned https://github.com/nxp-imx/uboot-imx.git
"git clone https://github.com/nxp-imx/uboot-imx.git -b lf_v2022.04"
and followed the instruction in imx8mp_evk.rst. (createdt a bl31.bin, downloaded firmware...).
"make O=build" doesn't build a flash.bin.
Doing a "make O=build flash.bin" fails with
OBJCOPY u-boot-nodtb.bin
RELOC u-boot-nodtb.bin
arch/arm/dts/imx8mp-evk.dtb > u-boot.its
/bin/sh: 1: ../: Permission denied
make[1]: *** [/home/user/y/src/nxp/uboot-imx/Makefile:1371: u-boot.its] Error 126
make[1]: *** Deleting file 'u-boot.its'
make[1]: Leaving directory '/home/user/y/src/nxp/uboot-imx/build'
How to fix it?
Tags (3)
arno_0
Sorry for delay.
What do you mean with "upstream"?  I found at least 3 ways to build:
* mainline (from uboot repos)
* repos from nxp (done as described in that docu inside)
* repos from nxp as described in your mentioned porting guide).
I am not really clear why there are so different ways. Is it just to add the HDMI blob?
What I found is missed in this is to add BINMAN to the target. Other imx8mp targets have that inside, EVK not. With that included it compiles a flash.bin. But will try that way from porting guide too. Can I just skip the HDMI step if I don't use it?
Harvey021
After consulting the R&D team, binman is turned off by default, in theory, there will be problems with binman doing FIT. So suggested using the imx-mkimage tool,
Harvey
Harvey021
Hi @arno_0
This build is for upstream, I'd suggest you use imx-mkimage (4.5.13 How to build imx-boot image by using imx-mkimage) of Linux user guide.
Harvey
