Building of Android OS for IMX8M MINI EVK board not completed
Ruban1
Building of Android OS for IMX8M MINI EVK board not completed.
The processing is completely stopped.
Its not installing kernel headers and kernel modules
i have attached the log till where it stopped
Regard
Ruban
Bio_TICFSL
Hello Ruban1
Apparently you ave not specified which dtb will be compiled and its compiled the sv32 and its broken the build or your are out of spece, i suggest to erase everything and restart the building again following the User guide document.
regards
Ruban1
how to specify only the modified imx8mm-evk.dts file and complie it alone
