Building docker images on other arm64 machines does not work correctly for imx target.
1,734件の閲覧回数
synaption
I am getting the error Illegal instruction (core dumped) on many commands run inside an arm64 docker container. Even simply typing pip results in the error. I am using buildroot so the error could be related to my kernel configurations. The container does run on raspberry pi with nearly the same buildroot configuration. I compiled the container on qemu, and AWS. I have made the container work by building it on target, but this is slow and runs out of room easily. What can I do to make other build machines work?
1,721件の閲覧回数
Bio_TICFSL
NXP don't have docker for its linux BSP if you want docker you have to do it.
1,717件の閲覧回数
synaption
Or gee, I don't know.  Maybe somebody else could help.
