Build sdk failed for libraries not found
Mingheng
    I couldn'd found the old topic with the same name. So I setup this again.
    I tried to build sdk for imx8mm-evk, using command `bitbake -c populate_sdk imx-image-full`. But there is an error about qtpdf as follow picture
    Hope could get someone help again here.
Mingheng
Harvey021
Harvey021
clay_miller
Looks like you might be either missing some QT packages or having some versioning conflicts.
If the goal is to just generate the SDK. Try building a smaller option without all the QT and machine learning. It'll build much quicker as well.
bitbake core-image-minimal -c populate_sdk
Also is this a fresh yocto setup? Are you using a shared state cache?
Clay
Mingheng
Thanks for your reply
It's a fresh yocto setup.
OTOH, there is a folder named "sstate-cache", did you mean that? The configuration is in default.
BTW, this issue was been repeated by another NXP employee and solved by adding some command in `local.conf` and `bblayers.conf` few days ago. But I forgot to markdown the modification and now I can not find that topic any more.
clay_miller
The sstate-cache is just a spot for yocto to consolidate packages that it checks before looking at mirrors. One way to speed up yocto builds with different configurations is to use a locally defined sstated-cache, but sometimes when doing so across several builds you can end up with multiple package versions that cause a similar problem. Fortunately, that is not the issue here.
Did Harley's link solve your issue?
Clay
%3CLINGO-SUB%20id%3D%22lingo-sub-1938243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBuild%20sdk%20failed%20for%20libraries%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20I%20couldn'd%20found%20the%20old%20topic%20with%20the%20same%20name.%20So%20I%20setup%20this%20again.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20I%20tried%20to%20build%20sdk%20for%20imx8mm-evk%2C%20using%20command%20%60bitbake%20-c%20populate_sdk%20imx-image-full%60.%20But%20there%20is%20an%20error%20about%20qtpdf%20as%20follow%20picture%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Mingheng_0-1724314873236.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Mingheng_0-1724314873236.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F294715i8A53ED5A772A84EC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Mingheng_0-1724314873236.png%22%20alt%3D%22Mingheng_0-1724314873236.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EMingheng_0-1724314873236.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20Hope%20could%20get%20someone%20help%20again%20here.%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3EMingheng%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1941415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Build%20sdk%20failed%20for%20libraries%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1941415%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20sstate-cache%20is%20just%20a%20spot%20for%20yocto%20to%20consolidate%20packages%20that%20it%20checks%20before%20looking%20at%20mirrors.%20One%20way%20to%20speed%20up%20yocto%20builds%20with%20different%20configurations%20is%20to%20use%20a%20locally%20defined%20sstated-cache%2C%20but%20sometimes%20when%20doing%20so%20across%20several%20builds%20you%20can%20end%20up%20with%20multiple%20package%20versions%20that%20cause%20a%20similar%20problem.%20Fortunately%2C%20that%20is%20not%20the%20issue%20here.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDid%20Harley's%20link%20solve%20your%20issue%3F%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EClay%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1939127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Build%20sdk%20failed%20for%20libraries%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1939127%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FEncounter-error-when-bitbake-qtwebengine-cconfigure-in-imx8-bsp%2Fm-p%2F1490894%22%20target%3D%22_self%22%3EEncounter-error-when-bitbake-qtwebengine%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1938795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Build%20sdk%20failed%20for%20libraries%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938795%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThanks%20for%20your%20reply%3CBR%20%2F%3E%3CBR%20%2F%3EIt's%20a%20fresh%20yocto%20setup.%3CBR%20%2F%3EOTOH%2C%20there%20is%20a%20folder%20named%20%22sstate-cache%22%2C%20did%20you%20mean%20that%3F%20The%20configuration%20is%20in%20default.%3CBR%20%2F%3E%3CBR%20%2F%3EBTW%2C%20this%20issue%20was%20been%20repeated%20by%20another%20NXP%20employee%20and%20solved%20by%20adding%20some%20command%20in%20%60local.conf%60%20and%20%60bblayers.conf%60%20few%20days%20ago.%20But%20I%20forgot%20to%20markdown%20the%20modification%20and%20now%20I%20can%20not%20find%20that%20topic%20any%20more.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1938725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Build%20sdk%20failed%20for%20libraries%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1938725%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELooks%20like%20you%20might%20be%20either%20missing%20some%20QT%20packages%20or%20having%20some%20versioning%20conflicts.%3C%2FP%3E%0A%3CP%3EIf%20the%20goal%20is%20to%20just%20generate%20the%20SDK.%26nbsp%3BTry%20building%20a%20smaller%20option%20without%20all%20the%20QT%20and%20machine%20learning.%20It'll%20build%20much%20quicker%20as%20well.%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Ebitbake%20core-image-minimal%26nbsp%3B-c%20populate_sdk%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EAlso%20is%20this%20a%20fresh%20yocto%20setup%3F%20Are%20you%20using%20a%20shared%20state%20cache%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3ERegards%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EClay%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
