Build issue with the debian 12 based on 6.6.52
Neha_V
i am working with debian 12 based  on linux 6.6.52
when i use the bld uboot -m imx8mpiwg command mkimage and uboot binaries are generating but when i use bld -m imx8mpiwg this command uboot and makimage binaries are not generating what might be the issue ?
what is the solution for this
joanxie
I built imx8mpevk board, can find the uboot folder and mkimage folder under flexbuild/build_lsdk2512/bsp, for bld -m <machine>, you can get the BSP firmware image which consists
of the ATF, U-Boot, OP-TEE OS, kernel, dtb, peripheral firmware, and initramfs under flexbuild/build_lsdk2512/images, if you only need uboot, you can use the command "bld uboot -m <machine>"
joanxie
Neha_V
The issue has been resolved now.
Thank you
%3CLINGO-SUB%20id%3D%22lingo-sub-2289830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBuild%20issue%20with%20the%20debian%2012%20based%20on%206.6.52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei%20am%20working%20with%20debian%2012%20based%26nbsp%3B%20on%20linux%206.6.52%3C%2FP%3E%3CP%3Ewhen%20i%20use%20the%26nbsp%3Bbld%20uboot%20-m%20imx8mpiwg%20command%20mkimage%20and%20uboot%20binaries%20are%20generating%20but%20when%20i%20use%26nbsp%3Bbld%20-m%20imx8mpiwg%20this%20command%20uboot%20and%20makimage%20binaries%20are%20not%20generating%20what%20might%20be%20the%20issue%20%3F%3C%2FP%3E%3CP%3Ewhat%20is%20the%20solution%20for%20this%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2291327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Build%20issue%20with%20the%20debian%2012%20based%20on%206.6.52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20built%20imx8mpevk%20board%2C%20can%20find%20the%20uboot%20folder%20and%20mkimage%20folder%20under%26nbsp%3Bflexbuild%2Fbuild_lsdk2512%2Fbsp%2C%20for%20bld%20-m%20%3CMACHINE%3E%2C%20you%20can%20get%20the%26nbsp%3BBSP%20firmware%20image%20which%26nbsp%3Bconsists%3CBR%20%2F%3Eof%20the%20ATF%2C%20U-Boot%2C%20OP-TEE%20OS%2C%20kernel%2C%20dtb%2C%20peripheral%20firmware%2C%20and%20initramfs%20under%20flexbuild%2Fbuild_lsdk2512%2Fimages%2C%20if%20you%20only%20need%20uboot%2C%20you%20can%20use%20the%20command%20%22bld%20uboot%20-m%20%3CMACHINE%3E%22%3C%2FMACHINE%3E%3C%2FMACHINE%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2292938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Build%20issue%20with%20the%20debian%2012%20based%20on%206.6.52%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThe%20issue%20has%20been%20resolved%20now.%3CBR%20%2F%3EThank%20you%3C%2FLINGO-BODY%3E
