In repository 'imx_sec_apps' there's an example I'd like to try: "caam-ecdsa-blackkey".
This project contains a Readme, with a link to the build instructions:
"Details and build instructions are described in the following document:
https://community.nxp.com/docs/DOC-342461"
However, I cannot view this document (Access Denied - You do not have sufficient privileges for this resource or its parent to perform this action.).
Is there an alternative location of the build instructions, or maybe someone of NXP can elevate my privileges ?
Thanks, Jeroen.
PS: I'm using iMX8M Mini, kernel 5.4.47.
Solved! Go to Solution.
@Jeroen_H
please use AN12838 (Strengthening Public Key Cryptography using CAAM Secure Key)
https://www.nxp.com/webapp/Download?colCode=AN12838&location=null
Yuri.
Ok, thanks!
@Jeroen_H
Yuri.
