Customer try to build SCFW 1.3.3 for i.MX8X Revision C0, and found error as below.
~/imx-scfw-porting-kit-1.3.3/packages/imx-scfw-porting-kit-1.3.3/src/scfw_export_mx8$ make qx R=C0 B=mek
make: *** No rule to make target 'build_mx8qx_c0/devices/startup.o', needed by 'build_mx8qx_c0/scfw_tcm.elf'. Stop.
Solved! Go to Solution.
Sorry I saw it in AN12770.
