Bring-up i.MX8QX custom board using JTAG
ソリューションへジャンプ
2,054件の閲覧回数
_asif_muhammed_
I am trying to bring up a imx8qx based board using JTAG. Can you please point me in the right direction so as to where to get started?
How can I use it to flash firmware for cortex M4/ cortex A35?
Any support will be deeply appreciated.
2,038件の閲覧回数
AldoG
You may refer to this 2 app notes, those will help you on getting started with your custom board (creating and customizing images) and download/debug using JTAG in normal and secure mode.
https://www.nxp.com/docs/en/application-note/AN13275.pdf
https://www.nxp.com/webapp/Download?colCode=AN12631
Aldo.
5 返答(返信)
2,022件の閲覧回数
_asif_muhammed_
Hi Aldo,
I have one more question regarding this. On reading the application note(AN12631), I saw that we need to connect the Lauterbach hardware to the board. I have a SEGGER JLink EDU with me. Will it be possible to use that?
2,005件の閲覧回数
AldoG
It may be possible, but please note that unfortunately we do not have documents or guides to do this.
Aldo.
1,960件の閲覧回数
_asif_muhammed_
Thank You Aldo.
Asif
2,039件の閲覧回数
AldoG
Aldo.
2,024件の閲覧回数
_asif_muhammed_
Thank you Aldo for your quick reply. I will check them out.
Asif
