I had updated the u-boot on the SPI NOR on the boundary devices. Now when I turn on the board, the u-boot causes an abort, followed by CPU reset and it is in a continuous reboot.
I tried changing the DIP switch setting to USB-OTG and when I turn on the board, the board still starts the u-boot and goes into a continuous reboot.
What is the procedure to reset the SPI NOR u-boot to the manufacture default?
Siva
Solved! Go to Solution.
My mistake, I was turning the DIP switch 2 instead of 1.
