Booting issue in Android Lollipop BSP in I.MX sabre6q board
13,520件の閲覧回数
arunsrk91
Hi All,
I am new to building and setting i.mx android bsp image. I have downloaded the i.MX6 Android L5.0.0_1.0.0 BSP Documentation
cd ~/myandroid/
sudo chmod +x ./device/fsl/common/tools/fsl-sdcard-partition.sh
sudo ./device/fsl/common/tools/fsl-sdcard-partition.sh -f imx6q /dev/sdc
The partition and flashing is success and booting is starting but am getting the following error. Please find the below log and kindly guide me in solving the issue.
U-Boot 2014.04-08648-g9d7bf9b (Oct 09 2015 - 19:34:25)
CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
CPU:   Temperature 24 C, calibration data: 0x5584a97d
Reset cause: POR
Board: MX6-Sabreauto revA
I2C:   ready
DRAM:  2 GiB
NAND:  0 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In:    serial
Out:   serial
Err:   serial
Found PFUZE100! deviceid=10,revid=11
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:1
Net:   FEC [PRIME]
Normal Boot
Hit any key to stop autoboot:  0
booti mmc1
kernel   @ 14008000 (6819472)
ramdisk  @ 15000000 (725570)
fdt      @ 14f00000 (50535)
kernel cmdline:
        use boot.img command line:
        console=ttymxc3,115200 init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=400M8
   Using Device Tree in place at 14f00000, end 14f0f566
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpu
Initializing cgroup subsys cpuacct
Linux version 3.10.53-88204-g4f0dd92 (root@aricent-OptiPlex-390) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEM5
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: Freescale i.MX6 Quad SABRE Automotive Board
cma: CMA: reserved 384 MiB at 5e000000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 8 pages/cpu @82008000 s9728 r8192 d14848 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 520768
Kernel command line: console=ttymxc3,115200 init=/init video=mxcfb0:dev=ldb,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off8
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
Memory: 1983MB 64MB = 2047MB total
Memory: 1666872k/1666872k available, 430280k reserved, 424960K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xe6800000 - 0xff000000   ( 392 MB)
    lowmem  : 0x80000000 - 0xe6000000   (1632 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x80e7a48c   (14794 kB)
      .init : 0x80e7b000 - 0x80ed0600   ( 342 kB)
      .data : 0x80ed2000 - 0x80f56000   ( 528 kB)
       .bss : 0x80f56000 - 0x80feacf8   ( 596 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
CPU identified as i.MX6Q, silicon rev 1.2
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Security Framework initialized
SELinux:  Initializing.
Mount-cache hash table entries: 512
Initializing cgroup subsys debug
Initializing cgroup subsys freezer
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x807e23e8 - 0x807e2440
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU2: Booted secondary processor
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU3: Booted secondary processor
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Use WDOG1 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1100 mV
vdd3p0: 2625 <--> 3400 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2400 mV
cpu: 725 <--> 1450 mV at 1150 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV at 1175 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
cs42888_supply: 3300 mV
vio1: 3300 mV
vio2: 3300 mV
vd: 3300 mV
va: 5000 mV
platform usb_h1_vbus.33: Driver reg-fixed-voltage requests probe deferral
platform usb_otg_vbus.34: Driver reg-fixed-voltage requests probe deferral
3P3V: 3300 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
pureg-dummy: no parameters
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 708K (85000000 - 850b1000)
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
mxc_epit: probe of 20d0000.epit failed with error -22
mxc_epit: probe of 20d4000.epit failed with error -22
imx6_busfreq busfreq.16: DDR medium rate not supported.
Bus freq driver module loaded
console [pstore-1] enabled
ramoops: attached 0x100000@0x8bf00000, ecc: 0/0
mxc_ramoops device success loaded
futex hash table entries: 1024 (order: 4, 65536 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(0.490:1): initialized
bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 3194
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
MIPI DSI driver module loaded
mxc_sdc_fb fb.23: registered mxc display driver ldb
imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
mxc_sdc_fb fb.24: Can't get fb option for mxcfb1!
mxc_sdc_fb fb.25: Can't get fb option for mxcfb2!
mxc_sdc_fb fb.26: Can't get fb option for mxcfb3!
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: loaded firmware 1.1
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 0-0008: Full lay: 1, Metal lay: 1
pfuze100-regulator 0-0008: FAB: 0, FIN: 0
pfuze100-regulator 0-0008: pfuze100 found.
SW1AB: 300 <--> 1875 mV at 1375 mV
SW1C: 300 <--> 1875 mV at 1375 mV
SW2: 800 <--> 3300 mV at 3000 mV
SW3A: 400 <--> 1975 mV at 1500 mV
SW3B: 400 <--> 1975 mV at 1500 mV
SW4: 800 <--> 1975 mV at 1800 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VGEN1: 800 <--> 1550 mV at 800 mV
VGEN2: 800 <--> 1550 mV at 1500 mV
VGEN3: 1800 <--> 3300 mV at 1800 mV
VGEN4: 1800 <--> 3300 mV at 1800 mV
VGEN5: 1800 <--> 3300 mV at 2500 mV
VGEN6: 1800 <--> 3300 mV at 2800 mV
Serial: IMX driver
21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
console [ttymxc3] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
si476x-core 0-0063: Using default platform data.
si476x-core 0-0063: No IRQ number specified, will use polling
si476x-core 0-0063: Error while sending command 0x11
si476x-core 0-0063: The device in inconsistent power state
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CAN device driver interface
flexcan 2094000.can: device registered (reg_base=e69e8000, irq=143)
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
platform 2184000.usb: Driver imx_usb requests probe deferral
imx_usb 2184200.usb: Can't register ci_hdrc platform device, err=-517
platform 2184200.usb: Driver imx_usb requests probe deferral
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
usbcore: registered new interface driver wacom
egalax_ts 0-0004: Failed to wake up, disable suspend,otherwise it can not wake up
egalax_ts 0-0004: Failed to read firmware version
egalax_ts: probe of 0-0004 failed with error -5
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
DBG sensor data is at 80fc48a0
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.41: V4L2 device registered as video17
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
gspca_main: v2.14.0 registered
mag3110 1-000e: check mag3110 chip ID
mag3110 1-000e: read chip ID 0xfffffffb is not equal to 0xc4!
mag3110: probe of 1-000e failed with error -22
mma8x5x 1-001c: read chip ID 0xfffffffb is not equal to 0x1a,0x2a,0x3a,0x4a,0x5a!
mma8x5x: probe of 1-001c failed with error -22
imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver btusb
cpuidle: using governor ladder
cpuidle: using governor menu
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: no vqmmc regulator found
mmc0: no vmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
Galcore version 5.0.11.25762
mmc2: new high speed SDHC card at address e624
mmcblk2: mmc2:e624 SU08G 7.40 GiB
mmcblk2: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
mmcblk2: p4 size 13352010 extends beyond EOD, truncated
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_asrc 2034000.asrc: mxc_asrc registered
mxc_vpu 2040000.vpu: VPU initialized
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ashmem: initialized
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
cs42xx8 0-0048: failed to get device ID, ret = -5
cs42xx8: probe of 0-0048 failed with error -5
fsl-hdmi-dai hdmi_audio.17: failed to probe. Load HDMI-video first.
fsl-hdmi-dai: probe of hdmi_audio.17 failed with error -12
imx-cs42888 sound-cs42888.36: failed to find codec platform device
imx-cs42888: probe of sound-cs42888.36 failed with error -22
imx-spdif sound-spdif.39:  dir-hifi <-> 2004000.spdif mapping ok
imx-audio-hdmi sound-hdmi.38: initialize HDMI-audio failed. load HDMI-video first!
imx-tuner-si476x sound-fm.37: failed to find FM platform device
imx-tuner-si476x: probe of sound-fm.37 failed with error -22
NET: Registered protocol family 26
u32 classifier
    Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: (C) 2002 David S. Miller
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
VGEN2: disabling
SWBST: disabling
SW4: disabling
regulator-dummy: disabling
imx mcc test is registered.
usb_h1_vbus: 5000 mV
usb_otg_vbus: 5000 mV
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 3.10.53-88204-g4f0dd92 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 3.10.53-88204-g4f0dd92 ehci_hcd
usb usb2: SerialNumber: ci_hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
file system registered
android_usb gadget: Mass Storage Function, version: 2009/09/11
android_usb gadget: Number of LUNs=1
lun0: LUN: removable file: (no medium)
android_usb gadget: android_usb ready
input: gpio-keys.20 as /devices/soc0/gpio-keys.20/input/input0
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 UTC (1)
ALSA device list:
  #0: imx-spdif
Freeing unused kernel memory: 340K (80e7b000 - 80ed0000)
type=1403 audit(1.720:2): policy loaded auid=4294967295 ses=4294967295
type=1404 audit(1.730:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: /dev/hw_random not found
Console: switching to colour dummy device 80x30
bio: create slab <bio-1> at 1
device-mapper: verity: data block 0 is corrupted
EXT4-fs (dm-0): unable to read superblock
fs_mgr: __mount(source=/dev/block/dm-0,target=/system,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/dm-0 at /system options: barrier=1 error: Invalid argument
EXT4-fs (mmcblk2p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p4): recovery complete
EXT4-fs (mmcblk2p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
fs_mgr: __mount(source=/dev/block/mmcblk2p4,target=/data,type=ext4)=0
EXT4-fs (mmcblk2p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p6): recovery complete
EXT4-fs (mmcblk2p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
fs_mgr: __mount(source=/dev/block/mmcblk2p6,target=/cache,type=ext4)=0
EXT4-fs (mmcblk2p7): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk2p7,target=/device,type=ext4)=0
init: fs_mgr_mount_all returned an error
init: fs_mgr_mount_all returned unexpected error 255
init: cannot find '/system/bin/logd', disabling 'logd'
init: cannot find '/system/bin/lmkd', disabling 'lmkd'
binder: 140:140 transaction failed 29189, size 0-0
init: cannot find '/system/bin/servicemanager', disabling 'servicemanager'
init: cannot find '/system/bin/vold', disabling 'vold'
init: cannot find '/system/bin/surfaceflinger', disabling 'surfaceflinger'
init: using deprecated syntax for specifying property 'ro.serialno', use ${name} instead
init: using deprecated syntax for specifying property 'ro.product.manufacturer', use ${name} instead
init: property 'ro.product.manufacturer' doesn't exist while expanding '$ro.product.manufacturer'
init: cannot expand '$ro.product.manufacturer' while writing to '/sys/class/android_usb/android0/iManufacturer'
init: using deprecated syntax for specifying property 'ro.product.model', use ${name} instead
init: property 'ro.product.model' doesn't exist while expanding '$ro.product.model'
init: cannot expand '$ro.product.model' while writing to '/sys/class/android_usb/android0/iProduct'
android_usb: already disabled
mtp_bind_config
Thanks and Regards,
Arun S
Original Attachment has been moved to: boot-log.txt.zip
ラベル(2)
6,705件の閲覧回数
devarajgs
This is specific to Lollipop, when you are trying to build the images for SD card booting.
You need to follow the steps I mentioned.
24 返答(返信)
5,647件の閲覧回数
zhghua1103
Dear Luo,
Thanks very much for your help!
I ruan  bootargs:
setenv bootargs
setenv bootcmd boota mmc0
setenv bootargs console=ttymxc0,115200 init=/init androidboot.dm_verity=disabled androidboot.selinux=disabled androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale
saveenv
However, the errors is:
Normal Boot
boota mmc0
kernel   @ 82808000 (8723560)
ramdisk  @ 83800000 (1027595)
fdt      @ 83700000 (36758)
## Booting Android Image at 0x80800000 ...
Kernel load addr 0x82808000 size 8520 KiB
Kernel command line: console=ttymxc0,115200 init=/init androidboot.dm_verity=disabled androidboot.selinux=disabled androidboot.console=te
## Flattened Device Tree blob at 83700000
   Booting using the fdt blob at 0x83700000
   Loading Kernel Image ... OK
   Using Device Tree in place at 83700000, end 8370bf95
switch to ldo_bypass mode!
Starting kernel ...
Linux version 4.1.15-dirty (root@joshua) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Oct 24 18:31:33 CST 6
Machine model: Freescale i.MX6 SoloLite EVK Board
Reserved memory: created CMA memory pool at 0x9a000000, size 320 MiB
Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
Memory policy: Data cache writealloc
PERCPU: Embedded 13 pages/cpu @eef2d000 s22144 r8192 d22912 u53248
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260368
Kernel command line: console=ttymxc0,115200 init=/init androidboot.dm_verity=disabled androidboot.selinux=disabled androidboot.console=t9
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 690984K/1047552K available (11566K kernel code, 972K rwdata, 3688K rodata, 1024K init, 654K bss, 28888K reserved, 327680K cma-re)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0fe5a34   (16247 kB)
      .init : 0xc1000000 - 0xc1100000   (1024 kB)
      .data : 0xc1100000 - 0xc11f33d0   ( 973 kB)
       .bss : 0xc11f33d0 - 0xc1296f64   ( 655 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
        Additional per-CPU info printed with stalls.
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 256 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76030001
mxc_clocksource_init 24000000
Switching to timer-based delay loop, resolution 41ns
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
AppArmor: AppArmor disabled by boot time parameter
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Setting up static identity map for 0x80100000 - 0x80100058
Brought up 1 CPUs
SMP: Total of 1 processors activated (48.00 BogoMIPS).
device-tree: Duplicate name in lcdif@020f8000, renamed to "display#1"
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
anatop_regulator 20c8000.anatop:regulator-vddcore@140: Failed to read a valid default voltage selector.
anatop_regulator: probe of 20c8000.anatop:regulator-vddcore@140 failed with error -22
anatop_regulator 20c8000.anatop:regulator-vddsoc@140: Failed to read a valid default voltage selector.
anatop_regulator: probe of 20c8000.anatop:regulator-vddsoc@140 failed with error -22
VDSO is not a valid ELF object!
imx6sl-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
0-0048 supply SENSOR not found, using dummy regulator
i2c i2c-0: Max17135 PMIC not found!
i2c i2c-0: can't use DMA
i2c i2c-1: can't use DMA
i2c i2c-2: IMX I2C adapter registered
i2c i2c-2: can't use DMA
Bluetooth: Core ver 2.20
Switched to clocksource mxc_timer1
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Freeing initrd memory: 1004K (c3800000 - c38fb000)
CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
imx rpmsg driver is registered.
pstore: Registered ramoops as persistent store backend
ramoops: attached 0x100000@0xbbf00000, ecc: 0/0
futex hash table entries: 256 (order: 2, 16384 bytes)
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.360:1): initialized
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
ntfs: driver 2.1.32 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
fuse init (API version 7.23)
bounce: pool size: 64 pages
pwm-backlight supply power not found, using dummy regulator
sii902x 1-0039: Sii902x: cound not find device
mxsfb 20f8000.lcdif: failed to find mxc display driver
Console: switching to colour frame buffer device 100x30
mxsfb 20f8000.lcdif: initialized
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.3
pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 21, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
brd: module loaded
loop: module loaded
zram: Created 1 device(s)
m25p80 spi0.0: unrecognized JEDEC id bytes: 00,  0,  0
spi_imx 2008000.ecspi: probed
2188000.ethernet supply phy not found, using dummy regulator
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: e6:b4:8e:ed:ff:01
pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver r8152
usbcore: registered new interface driver cdc_eem
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver usb_ehset_test
usb_otg1_vbus: supplied by SWBST
usb_otg2_vbus: supplied by SWBST
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
usb usb1: Manufacturer: Linux 4.1.15-dirty ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
input: 20b8000.kpp as /devices/soc0/soc/2000000.aips-bus/20b8000.kpp/input/input0
mma8450 0-001c: read chip ID 0xfffffffb is not equal to 0xc6!
mma8450: probe of 0-001c failed with error -22
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
2-003c supply DOVDD not found, using dummy regulator
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
pxp-v4l2 pxp_v4l2_out: initialized
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: dm-devel@redhat.com
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
/soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on normal mode
sdhci-esdhc-imx 2190000.usdhc: Got WP GPIO
sdhci-esdhc-imx 2190000.usdhc: assigned as wifi host
sdhci-esdhc-imx 2190000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using DMA
/soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2194000.usdhc: Got WP GPIO
sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using DMA
/soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
sdhci-esdhc-imx 2198000.usdhc: could not get ultra high speed state, work on normal mode
sdhci-esdhc-imx 2198000.usdhc: No vmmc regulator found
sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using DMA
galcore: clk_get gpu3d_clk failed, disable 3d!
Galcore version 5.0.11.41671
ashmem: initialized
wm8962 1-001a: Device is not a WM8962, ID ffff != 0x6243
wm8962: probe of 1-001a failed with error -22
imx-wm8962 sound: failed to find codec platform device
imx-wm8962: probe of sound failed with error -22
imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
u32 classifier
    Actions configured
nf_conntrack version 0.5.0 (15932 buckets, 63728 max)
mip6: Mobile IPv6
sit: IPv6 over IPv4 tunneling driver
cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
dhd_module_init in
Power-up adapter 'DHD generic adapter'
wifi_platform_bus_enumerate device present 1
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SS16G 14.8 GiB (ro)
 mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
failed to power up DHD generic adapter, 3 retry left
wifi_platform_bus_enumerate device present 0
mmc0: card aaaa removed
failed to power up DHD generic adapter, 2 retry left
failed to power up DHD generic adapter, 1 retry left
failed to power up DHD generic adapter, 0 retry left
failed to power up DHD generic adapter, max retry reached**
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:14:03 UTC (843)
SW4: disabling
wm8962-supply-4v2: disabling
wm8962-supply-3v15: disabling
usb_otg1_vbus: disabling
wlreg_on: disabling
ALSA device list:
  #0: imx-spdif
Freeing unused kernel memory: 1024K (c1000000 - c1100000)
init: init started!
init: init second stage started!
init: waitpid failed: No child processes
init: property_set("ro.zygote", "zygote32") failed
init: (Loading properties from /default.prop took 0.00s.)
init: (Parsing /init.environ.rc took 0.00s.)
init: (Parsing /init.usb.rc took 0.00s.)
init: (Parsing init.freescale.usb.rc took 0.00s.)
init: (Parsing /init.freescale.rc took 0.01s.)
init: (Parsing /init.usb.configfs.rc took 0.00s.)
init: (Parsing /init.zygote32.rc took 0.00s.)
init: (Parsing /init.trace.rc took 0.00s.)
init: (Parsing /init.rc took 0.03s.)
init: Starting service 'ueventd'...
init: Waiting for /dev/.coldboot_done...
ueventd: ueventd started!
ueventd: Coldboot took 0.13s.
init: Waiting for /dev/.coldboot_done took 0.15s.
init: Failed to read from /dev/hw_random: No such device
init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No such file or directory
init: write_file: Unable to write to '/dev/cpuctl/cpu.shares': Invalid argument
init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
fs_mgr: __mount(source=/dev/block/mmcblk1p5,target=/system,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk1p5 at /system options: barrier=1 error: No such file ory
random: nonblocking pool is initialized
fs_mgr: __mount(source=/dev/block/mmcblk1p4,target=/data,type=ext4)=-1
fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/mmcblk1p4 for mount /data type ext4 )
fs_mgr: __mount(source=/dev/block/mmcblk1p6,target=/cache,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk1p6 at /cache options: nomblk_io_submit error: No such fy
fs_mgr: __mount(source=/dev/block/mmcblk1p7,target=/device,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk1p7 at /device options: (null) error: No such file or diy
zram0: detected capacity change from 0 to 314572800
Unable to find swap-space signature
fs_mgr: swapon failed for /dev/block/zram0
init: (Loading properties from /system/build.prop took 0.00s.)
init: (Loading properties from /vendor/build.prop took 0.00s.)
init: (Loading properties from /factory/factory.prop took 0.00s.)
init: error opening block device /dev/block/mmcblk1p2: No such file or directory
init: Not bootcharting.
init: Failed to reload policy
init: cannot find '/system/bin/tzdatacheck', disabling 'exec 0 (/system/bin/tzdatacheck)'
init: cannot find '/system/bin/logd', disabling 'logd-reinit'
init: Starting service 'healthd'...
init: cannot find '/system/bin/sh', disabling 'console'
binder: 172:172 transaction failed 29189, size 0-0
init: write_file: Unable to open '/sys/block/mmcblk0/queue/read_ahead_kb': No such file or directory
init: property_set("ro.ril.wake_lock_timeout", "300") failed
init: property 'ro.product.manufacturer' doesn't exist while expanding '${ro.product.manufacturer}'
init: cannot expand '${ro.product.manufacturer}' while writing to '/config/usb_gadget/g1/strings/0x409/manufacturer'
init: property 'ro.product.model' doesn't exist while expanding '${ro.product.model}'
init: cannot expand '${ro.product.model}' while writing to '/config/usb_gadget/g1/strings/0x409/product'
Would you like for help me?
With Best  Regards
Joshua
5,647件の閲覧回数
aravinthkumarja
Senior Contributor II
Hi Joshua,
 Follow the below steps:
The default images that you build works for the eMMC but to boot the image from the SD card, you need to follow the below instructions:
3.4.3 Building Android image for the SD card on the SABRE-SD
Board
The default configuration in the source code package takes internal eMMC as the boot storage. It can be changed to make the
SD card in SD Slot 3 as the boot storage as follows:
remove out/target/product/sabresd_6dq/root directory and boot*.img
remove /out/target/product/sabresd_6dq/recovery directory and recovery*.img
remove /out/target/product/sabresd_6dq/system directory and system*.img
$ make BUILD_TARGET_DEVICE=sd
Follow Section 3.4 to build the images.
For more information please refer to the Android_User_Guide.pdf from the documentation section.
Aravinth
5,647件の閲覧回数
zhghua1103
Dear Aravinth,
I do the project like this :
But I found the problem in the imx6SL-evk.dts   init 'wifi-host' , then I disabled it
then the new  problem is:
Starting kernel ...
Linux version 4.1.15-dirty (root@joshua) (gcc version 4.9.x-google 20140827 (pr6
Kernel command line: console=ttymxc0,115200 init=/init androidboot.dm_verity=di9
Memory: 690984K/1047552K available (11566K kernel code, 972K rwdata, 3688K roda)
      .text : 0xc0008000 - 0xc0fe5a3c   (16247 kB)
clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7s
Calibrating delay loop (skipped), value calculated using timer frequency.. 48.0)
Brought up 1 CPUs
clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911s
anatop_regulator 20c8000.anatop:regulator-vddcore@140: Failed to read a valid d.
anatop_regulator: probe of 20c8000.anatop:regulator-vddcore@140 failed with err2
anatop_regulator 20c8000.anatop:regulator-vddsoc@140: Failed to read a valid de.
anatop_regulator: probe of 20c8000.anatop:regulator-vddsoc@140 failed with erro2
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@>
rootfs image is not initramfs (junk in compressed archive); looks like an initrd
audit: type=2000 audit(0.340:1): initialized
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 21, base_baud = 5000000) is a X
brd: module loaded
loop: module loaded
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address:0
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC add6
usb usb2: Manufacturer: Linux 4.1.15-dirty ehci_hcd
input: 20b8000.kpp as /devices/soc0/soc/2000000.aips-bus/20b8000.kpp/input/inpu0
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as 0
sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on noe
sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2198000.usdhc: could not get ultra high speed state, work on noe
ci_hdrc ci_hdrc.0: remove, state 4
usb usb1: USB disconnect, device number 1
ci_hdrc ci_hdrc.0: USB bus 1 deregistered
ashmem: initialized
u32 classifier
    Actions configured
mip6: Mobile IPv6
dhd_module_init in
Unable to handle kernel NULL pointer dereference at virtual address 000001d0
pgd = c0004000
[000001d0] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.1.15-dirty #27
Hardware name: Freescale i.MX6 SoloLite (Device Tree)
task: d80b4000 ti: d80ae000 task.ti: d80ae000
PC is at mmc_detect_change+0x8/0x4c
LR is at wifi_platform_bus_enumerate+0x54/0x90
pc : [<c082982c>]    lr : [<c06cf780>]    psr: 20000113
sp : d80afde0  ip : 00000000  fp : 00000000
r10: 00000000  r9 : 00000000  r8 : c117a6e0
r7 : d80afe18  r6 : 00000000  r5 : 00000001  r4 : 00000000
r3 : c126f024  r2 : 00000000  r1 : 00000000  r0 : 00000000
Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 8000404a  DAC: 00000015
PC: 0xc08297ac:
97ac  e3530000 1a000001 e3e00000 e8bd8038 e5903198 e3530000 1a000002 e5d03229
97cc  e3130001 0a000011 e3a01000 e1a04000 ebffff81 e5d4322a e3130010 e1a05000
97ec  0a000005 e1a00004 e3a01001 ebffff7a e1500005 21a00005 e8bd8038 e59401a4
980c  e1550000 21a00005 33a00000 e8bd8038 e59001ac e8bd8038 e92d4038 e1a04000
982c  e59031d0 e1a05001 e3130020 1a000003 e5900000 e5d03060 e3130001 1a000005
984c  e3a03001 e1a01005 e2840e27 e58432bc e8bd4038 eafffc23 e3011388 ebf60687
986c  eafffff6 e92d4070 e1a04001 e5d01208 e24dd028 e3a03000 e1a05000 e3110002
988c  e1a06002 e58d3000 e58d3004 e58d3008 e58d300c e58d3010 e58d3014 e58d3018
LR: 0xc06cf700:
f700  e30a36e0 e34c3117 e5933000 e3130001 0afffff3 e3050d44 e59f1008 e34c00ee
f720  eb1390f0 eaffffee c0c6f608 e92d4038 e2504000 0a000019 e30a36e0 e1a05001
f740  e34c3117 e5933000 e3130001 1a00000d e5944014 e3540000 0a000006 e5944008
f760  e3540000 0a000001 e1a00005 e12fff34 e3a00000 e8bd8038 e1a00005 eb05d083
f780  e1a00004 e8bd8038 e3050d9c e59f1024 e1a02005 e34c00ee eb1390d2 eaffffeb
f7a0  e3050d68 e59f100c e34c00ee eb1390cd e3e00015 e8bd8038 c0c6f620 e92d4038
f7c0  e30c4914 e34c4126 e5943000 e3530000 0a000018 e5932000 e3520001 0a000006
f7e0  e3050e00 e3051dd0 e34c00ee e34c10ee e3002169 ebff4b0a e5943000 e5d42008
SP: 0xd80afd60:
fd60  c123b894 c017b038 00000000 00000000 00000000 00000000 c123b894 0000002c
fd80  c082982c 20000113 ffffffff d80afdcc c117a6e0 c010c018 00000000 00000000
fda0  00000000 c126f024 00000000 00000001 00000000 d80afe18 c117a6e0 00000000
fdc0  00000000 00000000 00000000 d80afde0 c06cf780 c082982c 20000113 ffffffff
fde0  c126f024 00000000 00000001 c06cf780 00000001 d8888c80 00000003 c06cf990
fe00  fffffdfb d8152a10 c1265580 c126c914 00000000 00000000 d80afe18 d80afe18
fe20  00000000 c126c914 c126c914 d8888c80 fffffdfb 00000000 00000002 c109d970
fe40  00000000 c06cfc9c c1266bf0 d8152a10 c117c518 c059e94c c059e908 c1266bf0
R3: 0xc126efa4:
efa4  00000000 00000000 00000000 d8199600 00000000 00030003 d863a180 d863a180
efc4  00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
efe4  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f004  00000000 00000000 00000000 00000000 00000000 00000100 00000000 00000000
f024  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f044  c126f044 c126f044 00000000 00000000 00000000 00000000 00000000 00000000
f064  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
f084  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
R7: 0xd80afd98:
fd98  00000000 00000000 00000000 c126f024 00000000 00000001 00000000 d80afe18
fdb8  c117a6e0 00000000 00000000 00000000 00000000 d80afde0 c06cf780 c082982c
fdd8  20000113 ffffffff c126f024 00000000 00000001 c06cf780 00000001 d8888c80
fdf8  00000003 c06cf990 fffffdfb d8152a10 c1265580 c126c914 00000000 00000000
fe18  d80afe18 d80afe18 00000000 c126c914 c126c914 d8888c80 fffffdfb 00000000
fe38  00000002 c109d970 00000000 c06cfc9c c1266bf0 d8152a10 c117c518 c059e94c
fe58  c059e908 c1266bf0 d8152a10 00000000 c117c518 c059cf60 00000000 d8152a10
fe78  c117c518 d8152a44 c1166778 00000000 00000000 c059d13c 00000000 c117c518
R8: 0xc117a660:
a660  00000000 c117a528 c11d3434 00000018 00000000 c0688280 c09648b0 c0688044
a680  c09648c0 c09648c8 c09648d0 c09648d8 c068551c c09648e8 c09648f0 c09648f8
a6a0  c0964900 c0964908 c0964910 c0964918 00000000 00000000 00000000 ffffffe0
a6c0  c117a6c0 c117a6c0 c0687e30 c0687f10 00000000 c06879f4 00000000 00000000
a6e0  00000001 00000000 00000000 c0698fd8 c06975e4 c06971e0 00000000 00000000
a700  c0692810 c069275c 00000000 c0697b24 00000000 00000000 00000000 00000000
a720  00000000 c069267c 00000000 00000000 00000000 00000000 00000000 00000000
a740  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Process swapper/0 (pid: 1, stack limit = 0xd80ae210)
Stack: (0xd80afde0 to 0xd80b0000)
fde0: c126f024 00000000 00000001 c06cf780 00000001 d8888c80 00000003 c06cf990
fe00: fffffdfb d8152a10 c1265580 c126c914 00000000 00000000 d80afe18 d80afe18
fe20: 00000000 c126c914 c126c914 d8888c80 fffffdfb 00000000 00000002 c109d970
fe40: 00000000 c06cfc9c c1266bf0 d8152a10 c117c518 c059e94c c059e908 c1266bf0
fe60: d8152a10 00000000 c117c518 c059cf60 00000000 d8152a10 c117c518 d8152a44
fe80: c1166778 00000000 00000000 c059d13c 00000000 c117c518 c059d0b0 c059b474
fea0: d808695c d81532b4 c117c518 d888a700 00000000 c059c6e8 c0ee6054 c117c518
fec0: 00000000 c117c518 00000000 d8888c80 c1252978 c059d9d4 00000000 c126c914
fee0: 00000000 c06d00dc 00000000 c110bba0 c110bba0 d8888c80 c1059d20 00000000
ff00: c108ebe4 c0101730 d8087880 c0c03ad4 00000010 00006000 00000000 00000001
ff20: 00000000 c1114f10 60000113 00000000 c0f995fc ef7ffa68 c0c320fc c014cd6c
ff40: c0e538a8 ef7ffa8d 00000007 00000007 c1114ef8 000001c7 000001c7 00000007
ff60: c11f6000 c11f6000 c108ebe0 c109d970 00000000 c1000dc0 00000007 00000007
ff80: c1000598 c0153fd0 00000000 c0bb1408 00000000 00000000 00000000 00000000
ffa0: 00000000 c0bb1410 00000000 c01076e8 00000000 00000000 00000000 00000000
ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 ffffffff ffffffff
[<c082982c>] (mmc_detect_change) from [<c06cf780>] (wifi_platform_bus_enumerate)
[<c06cf780>] (wifi_platform_bus_enumerate) from [<c06cf990>] (dhd_wifi_platform)
[<c06cf990>] (dhd_wifi_platform_load) from [<c06cfc9c>] (wifi_plat_dev_drv_prob)
[<c06cfc9c>] (wifi_plat_dev_drv_probe) from [<c059e94c>] (platform_drv_probe+0x)
[<c059e94c>] (platform_drv_probe) from [<c059cf60>] (driver_probe_device+0x198/)
[<c059cf60>] (driver_probe_device) from [<c059d13c>] (__driver_attach+0x8c/0x90)
[<c059d13c>] (__driver_attach) from [<c059b474>] (bus_for_each_dev+0x68/0x9c)
[<c059b474>] (bus_for_each_dev) from [<c059c6e8>] (bus_add_driver+0x14c/0x1f4)
[<c059c6e8>] (bus_add_driver) from [<c059d9d4>] (driver_register+0x78/0xf8)
[<c059d9d4>] (driver_register) from [<c06d00dc>] (dhd_wifi_platform_register_dr)
[<c06d00dc>] (dhd_wifi_platform_register_drv) from [<c0101730>] (do_one_initcal)
Code: e59001ac e8bd8038 e92d4038 e1a04000 (e59031d0)
---[ end trace e6afdb10a6c4f335 ]---
Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
Rebooting in 5 seconds..
So, I will disabled broadcom wireless ,  but  I failed
Would you please help  me about the important problem ?
With Best Regards
Joshua
5,647件の閲覧回数
aravinthkumarja
Hi Joshua,
What problem you faced on WiFi.??(If possible attach the error log)
Why you disabled that.??
Can you explain more.
Aravinth
5,647件の閲覧回数
zhghua1103
Dear Aravinth,
Thank you for your hlep about the question?
I want to disable our wifi device,  but I cannot do it  successfully.
Especlly, we are using  BCM wifi module, But I can't disabled
Would you please help about the question?
With Best Regards
Joshua
5,647件の閲覧回数
aravinthkumarja
Hi Joshua,
How you disabled that chip??
Aravinth
5,636件の閲覧回数
zhghua1103
Dear Regards,
Thank your very much for your help !
This is my system log when I disabled "wifi-host"
such as:
Linux version 4.1.15-dirty (root@joshua) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #3 SMP PREEMPT Wed Oct 26 22:49:48 CST 6
Memory: 691000K/1047552K available (11559K kernel code, 964K rwdata, 3572K rodata, 1024K init, 645K bss, 28872K reserved, 327680K cma-re)
      .text : 0xc0008000 - 0xc0fc6cec   (16124 kB)
      .data : 0xc1100000 - 0xc11f1390   ( 965 kB)
       .bss : 0xc11f1390 - 0xc12927e4   ( 646 kB)
Brought up 1 CPUs
brd: module loaded
loop: module loaded
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 0a:0f:bb:c4:67:9d
ashmem: initialized
u32 classifier
    Actions configured
mip6: Mobile IPv6
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 01:08:07 UTC (4087)
SW4: disabling
wlreg_on: disabling
ALSA device list:
  #0: imx-spdif
init: init started!
fs_mgr: __mount(source=/dev/block/mmcblk0p5,target=/system,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk0p5 at /system options: barrier=1 error: No such file ory
fs_mgr: __mount(source=/dev/block/mmcblk0p4,target=/data,type=ext4)=-1
fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/mmcblk0p4 for mount /data type ext4 )
fs_mgr: __mount(source=/dev/block/mmcblk0p6,target=/cache,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk0p6 at /cache options: nomblk_io_submit error: No such fy
Would you please help me?
With Best Regards
Joshua
5,636件の閲覧回数
aravinthkumarja
Hi Joshua,
In this MMC device is not detected.
You  are not getting below log:
Can you tell me What do you want to do.?
Aravinth
5,636件の閲覧回数
zhghua1103
Dear Aravinth,
Thanks very much for your help along the question!
I am thanks
I do it like this:
setenv bootargs
saveenv
boot
brd: module loaded
loop: module loaded
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC add7
ashmem: initialized
wm8962 1-001a: Failed to read ID register
wm8962: probe of 1-001a failed with error -5
u32 classifier
    Actions configured
mip6: Mobile IPv6
Key type encrypted registered
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:01 )
SW4: disabling
wlreg_on: disabling
ALSA device list:
  #0: imx-spdif
init: init started!
init: write_file: Unable to open '/proc/sys/kernel/sched_compat_yield': No suchy
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcbly
fs_mgr: __mount(source=/dev/block/mmcblk0p7,target=/device,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk0p7 at /device options: (null) error: No such file or diy
fs_mgr: __mount(source=/dev/block/mmcblk0p1,target=/boot,type=mmc)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk0p1 at /boot options: (null) error: No such device
fs_mgr: __mount(source=/dev/block/mmcblk0p2,target=/recovery,type=mmc)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk0p2 at /recovery options: (null) error: No such device
fs_mgr: __mount(source=/dev/block/mmcblk0p8,target=/misc,type=mmc)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk0p8 at /misc options: (null) error: No such device
fs_mgr: __mount(source=/dev/block/mmcblk0,target=/bootloader,type=mmc)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk0 at /bootloader options: (null) error: No such device
init: error opening block device /dev/block/mmcblk0p2: No such file or directory
binder: 189:189 transaction failed 29189, size 0-0
Would you please help me about the same question?
With Best  Regards
Joshua
5,647件の閲覧回数
zhghua1103
Dear  Aravinth,
Thanks very much for your help! I am thanks.
such as:
/root/myandroid/kernel_imx/arch/arm/boot/dts/imx6sl-evk.dts->disabled
&usdhc1 {
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_usdhc1>;
        pinctrl-1 = <&pinctrl_usdhc1_100mhz>;
        pinctrl-2 = <&pinctrl_usdhc1_200mhz>;
        bus-width = <4>;
        cd-gpios = <&gpio4 7 GPIO_ACTIVE_LOW>;
        wp-gpios = <&gpio4 6 GPIO_ACTIVE_HIGH>;
        keep-power-in-suspend;
        enable-sdio-wakeup;
        wifi-host;
      pm-ignore-notify;
        non-removable;
        cd-post;
        status = "okay";
With Best Regards
Joshua
5,639件の閲覧回数
aravinthkumarja
Hi Joshua,
If you want to disable any chip, you have to do in defconfig.
if you disabled in dts, that driver will try to enumerate the chip. That's why the kernel is crashed.
Aravinth
5,636件の閲覧回数
zhghua1103
Dear Aravinth,
Thanks very much about the important question!
I am very thanks
I try to do the android system about imx6sl. But I am failed!
5,647件の閲覧回数
zhghua1103
Dear All,
Thanks for your help about the question. I am using imx6sl about android.
These errors follows:
=> boot
boota mmc0
kernel   @ 82808000 (8723568)
ramdisk  @ 83800000 (1027620)
Kernel command line: console=ttymxc0,115200 init=/init androidboot.dm_verity=die
Starting kernel ...
Kernel command line: console=ttymxc0,115200 init=/init androidboot.dm_verity=did
Brought up 1 CPUs
brd: module loaded
loop: module loaded
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC addc
ashmem: initialized
u32 classifier
    Actions configured
mip6: Mobile IPv6
dhd_module_init in
mmcblk0: mmc0:aaaa SS08G 7.40 GiB (ro)
mmcblk0: p4 size 10192490 extends beyond EOD, truncated
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:18:44 )
SW4: disabling
wlreg_on: disabling
ALSA device list:
  #0: imx-spdif
init: init started!
SELinux:  Android master kernel running Android M policy in compatibility mode.
SELinux:  Permission audit_read in class capability2 not defined in policy.
SELinux: the above unknown classes and permissions will be denied
audit: type=1403 audit(1124.610:2): policy loaded auid=4294967295 ses=4294967295
audit: type=1404 audit(1124.620:3): enforcing=1 old_enforcing=0 auid=42949672955
init: (Initializing SELinux enforcing took 0.12s.)
init: SELinux: Could not get canonical path /adb_keys restorecon: No such file .
audit: type=1400 audit(1124.770:4): avc:  denied  { mounton } for  pid=1 comm="0
ueventd: Coldboot took 0.29s.
init: Waiting for /dev/.coldboot_done took 0.29s.
fs_mgr: Error parsing fs_mgr_options
init: SELinux: Could not get canonical path /cache/recovery restorecon: No such.
init: unable to read fstab /fstab.freescale: No such file or directory
init: SELinux: Could not set context for /data:  Read-only file system
init: cannot find '/system/bin/tzdatacheck', disabling 'exec 0 (/system/bin/tzd'
init: Unable to open persistent property directory "/data/property": No such fiy
binder: 169:169 transaction failed 29189, size 0-0
init: write_file: Unable to open '/sys/block/mmcblk0/queue/read_ahead_kb': No sy
random: init urandom read with 18 bits of entropy available
init: Unable to write persistent property to temp file /data/property/.temp.QYMy
init: property 'ro.product.manufacturer' doesn't exist while expanding '${ro.pr'
init: cannot expand '${ro.product.manufacturer}' while writing to '/config/usb_'
init: property 'ro.product.model' doesn't exist while expanding '${ro.product.m'
init: cannot expand '${ro.product.model}' while writing to '/config/usb_gadget/'
Would you like help me  about the error?
With Best Regards
Joshua
5,647件の閲覧回数
danwei_luo
Hi Joshua
Please try adding "androidboot.dm_verity=disabled androidboot.selinux=disabled" in your bootargs.
Danwei Luo
5,647件の閲覧回数
danwei_luo
Hi Arun S,
I think the root cause for your problem is this:
This means that your system files has been modified somehow, thus it cannot pass verity check.
You can add "androidboot.dm_verity=disabled" in your bootargs to disable this feature. It works for me!
Danwei Luo
5,647件の閲覧回数
Lorac
We got the same boot up message on iMX7Dsabre EVK too. Who can help us to find a solution quickly. Who has writtten the Android user guide.pdf that contain all step to compile the latest source code successfully?
U-Boot 2015.04-14469-g9433975 (Jun 21 2016 - 09:05:03)
CPU:   Freescale i.MX7D rev1.2 at 792 MHz
CPU:   Temperature 33 C
Reset cause: POR
Board: i.MX7D SABRESD RevB
I2C:   ready
DRAM:  1 GiB
PMIC: PFUZE300 DEV_ID=0x30 REV_ID=0x11
No panel detected: default to TFT43AB
Display: TFT43AB (480x272)
Video: 480x272x24
In:    serial
Out:   serial
Err:   serial
Fastboot: Normal
flash target is MMC:0
Net:   FEC0
Normal Boot
boota mmc0
kernel   @ 82808000 (8398592)
ramdisk  @ 83800000 (1066255)
fdt      @ 83700000 (47518)
Kernel load addr 0x82808000 size 8202 KiB
Kernel command line: console=ttymxc0,115200 init=/init androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale
   Using Device Tree in place at 83700000, end 8370e99d
Starting kernel ...
Linux version 3.14.52-141398-gad65770 (cardes1@wksqc06044-linux) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Jun 20 16:54:09 EDT 2016
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
Machine model: Freescale i.MX7 SabreSD Board
cma: CMA: reserved 320 MiB at 8a000000
PERCPU: Embedded 9 pages/cpu @eef2f000 s13312 r8192 d15360 u36864
Kernel command line: console=ttymxc0,115200 init=/init androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale androidboot.serialno=00000134ee18b953
Memory: 692252K/1047552K available (10720K kernel code, 789K rwdata, 3820K rodata, 593K init, 766K bss, 355300K reserved, 270336K highmem)
      .text : 0xc0008000 - 0xc0e3b4b8   (14542 kB)
      .init : 0xc0e3c000 - 0xc0ed0400   ( 593 kB)
      .data : 0xc0ed2000 - 0xc0f976ac   ( 790 kB)
       .bss : 0xc0f976ac - 0xc1057024   ( 767 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Architected cp15 timer(s) running at 8.00MHz (phys).
sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2147483648000ns
Ignoring duplicate/late registration of read_current_timer delay
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
/cpus/cpu@0 missing clock-frequency property
/cpus/cpu@1 missing clock-frequency property
Setting up static identity map for 0x80a38090 - 0x80a380e8
Brought up 2 CPUs
SMP: Total of 2 processors activated (12.00 BogoMIPS).
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
syscon 30340000.iomuxc-gpr: regmap [mem 0x30340000-0x3034ffff] registered
syscon 30350000.ocotp-ctrl: regmap [mem 0x30350000-0x3035ffff] registered
syscon 30360000.anatop: regmap [mem 0x30360000-0x3036ffff] registered
vdd1p0d: 800 <--> 1200 mV at 1000 mV
vdd1p2: 1100 <--> 1300 mV
syscon 30390000.src: regmap [mem 0x30390000-0x3039ffff] registered
DDR type is DDR3!
failed to find ocotp node
hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 8 bytes.
imx7d-pinctrl 302c0000.iomuxc-lpsr: failed to get pin(27) name
pinconfig core: failed to register map default (2): no group/pin given
imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
MU is ready for cross core communication!
mxs-dma 33000000.dma-apbh: initialized
usb_otg1_vbus: 5000 mV
usb_otg2_vbus: 5000 mV
can2-3v3: 3300 mV
vref-1v8: 1800 mV
VDD_SD1: 3300 mV
wlreg_on: 5000 mV
usbphy_nop1.10 supply vcc not found, using dummy regulator
usbphy_nop2.11 supply vcc not found, using dummy regulator
i2c i2c-3: IMX I2C adapter registered
Bluetooth: Core ver 2.18
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource arch_sys_counter
Freeing initrd memory: 1040K (c3800000 - c3904000)
bt power gpio is:119
mxc_bt_rfkill driver success loaded
rfkill: BT RF going to : on
mxc_bt_rfkill_reset
ramoops: attached 0x100000@0x9f700000, ecc: 0/0
futex hash table entries: 512 (order: 3, 32768 bytes)
audit: type=2000 audit(0.310:1): initialized
msgmni has been set to 1466
pwm-backlight.14 supply power not found, using dummy regulator
sii902x 2-0039: No reset pin found
30730000.lcdif supply lcd not found, using dummy regulator
mxsfb 30730000.lcdif: failed to find mxc display driver
Console: switching to colour frame buffer device 60x34
mxsfb 30730000.lcdif: initialized
imx-sdma 30bd0000.sdma: no event needs to be remapped
imx-sdma 30bd0000.sdma: loaded firmware 4.1
imx-sdma 30bd0000.sdma: initialized
pfuze100-regulator 0-0008: Full layer: 1, Metal layer: 1
pfuze100-regulator 0-0008: pfuze3000 found.
SW1A: 700 <--> 3300 mV at 1100 mV
SW1B: 700 <--> 1475 mV at 975 mV
SW2: 1500 <--> 1850 mV at 1800 mV
SW3: 900 <--> 1650 mV at 1350 mV
VREFDDR: 750 mV
VLDO1: 1800 <--> 3300 mV at 1800 mV
VLDO2: 800 <--> 1550 mV at 1500 mV
VCCSD: 2850 <--> 3300 mV at 3300 mV
V33: 2850 <--> 3300 mV at 3300 mV
VLDO3: 1800 <--> 3300 mV at 3300 mV
VLDO4: 1800 <--> 3300 mV at 3300 mV
Serial: IMX driver
30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 58, base_baud = 1500000) is a IMX
fbcvt: 640x480@60: CVT Name - .307M3
30a70000.serial: ttymxc4 at MMIO 0x30a70000 (irq = 62, base_baud = 5000000) is a IMX
30a80000.serial: ttymxc5 at MMIO 0x30a80000 (irq = 48, base_baud = 5000000) is a IMX
brd: module loaded
loop: module loaded
zram: Created 1 device(s) ...
fxos8700 device driver probe successfully
fxas2100x 1-0020: fxas2100x device driver probe successfully
spi_gpio spi4.23: gpio-miso property not found, switching to no-rx mode
spi_imx 30840000.ecspi: probed
flexcan 30a10000.can: device registered (reg_base=f5a10000, irq=143)
30be0000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 30be0000.ethernet eth0: registered PHC device 0
30bf0000.ethernet supply phy not found, using dummy regulator
pps pps1: new PPS source ptp1
fec 30bf0000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
fec 30bf0000.ethernet (unregistered net_device): Using random MAC address: 2e:5b:6c:e4:ac:ba
fec 30bf0000.ethernet eth1: registered PHC device 1
30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
30b20200.usbmisc supply vbus-wakeup not found, using dummy regulator
30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
usb usb1: Manufacturer: Linux 3.14.52-141398-gad65770 ehci_hcd
input: 30370000.snvs-pwrkey as /devices/soc.3/30000000.aips-bus/30370000.snvs-pwrkey/input/input0
snvs_pwrkey 30370000.snvs-pwrkey: i.MX snvs powerkey probed
spi2.0 supply vcc not found, using dummy regulator
ads7846 spi2.0: touchscreen, irq 221
input: ADS7846 Touchscreen as /devices/soc.3/30800000.aips-bus/30800000.spba-bus/30840000.ecspi/spi_master/spi2/spi2.0/input/input1
read mpl3115 chip id 0xc4
input: mpl3115 as /devices/virtual/input/input2
mpl3115 device driver probe successfully
snvs_rtc 30370034.snvs-rtc-lp: rtc core: registered 30370034.snvs-rtc-l as rtc0
IR RC5(x) protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
mxc_mipi-csi 30750000.mipi-csi: mipi csi v4l2 device registered
CSI: Registered sensor subdevice: mxc_mipi-csi.0
mxc_mipi-csi 30750000.mipi-csi: lanes: 2, hs_settle: 13, wclk: 1, freq: 240000000
pxp-v4l2 pxp_v4l2_out.15: initialized
imx2-wdt 30280000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
usbcore: registered new interface driver bcm203x
usb 1-1: new full-speed USB device number 2 using ci_hdrc
mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
sdhci-esdhc-imx 30b50000.usdhc: assigned as wifi host
mmc1: no vqmmc regulator found
mmc1: no vmmc regulator found
mmc1: SDHCI controller on 30b50000.usdhc [30b50000.usdhc] using ADMA
mmc2: SDHCI controller on 30b60000.usdhc [30b60000.usdhc] using ADMA
caam 30900000.caam: Instantiated RNG4 SH0
caam 30900000.caam: Instantiated RNG4 SH1
caam 30900000.caam: device ID = 0x0a160300 (Era 8)
caam 30900000.caam: job rings = 3, qi = 0
usb 1-1: New USB device found, idVendor=060b, idProduct=6001
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1: Product: soild year usb hub keyboard
usb 1-1: Manufacturer: soild year
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 3 ports detected
caam algorithms registered in /proc/crypto
caam_jr 30901000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 8 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] cf c6 94 91 6d da d5 95
platform caam_sm: [0008] 25 b2 12 da 5a b3 04 ac
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 3d 25 c9 85 44 af 62 6c
platform caam_sm: [0008] 05 2a 49 f6 8d e8 3c 30
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] d9 b7 b1 ab ae 49 45 ad
platform caam_sm: [0008] ce d8 d7 39 0a ca 68 5f
platform caam_sm: [0016] a4 da 38 95 e0 9e eb ae
platform caam_sm: [0024] 24 69 87 e5 f7 65 3b 60
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
mmc0: Problem setting current limit!
platform caam_sm: [0000] 36 ad db fd f9 10 6a 66
platform caam_sm: [0008] 01 29 78 1c d6 40 20 20
platform caam_sm: [0016] c8 d2 a5 bb 49 e6 b5 f4
platform caam_sm: [0024] a4 92 0d 2e 6c 8d 18 b0
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
usb 1-1.1: new full-speed USB device number 3 using ci_hdrc
mmc0: new ultra high speed DDR50 SDHC card at address 0007
mmcblk0: mmc0:0007 SD16G 14.9 GiB
platform caam_sm: 196-bit unwritten blob:
mmcblk0: p4 size 29057024 extends beyond EOD, truncated
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 7c ca 5e 20 d9 66 38 3d
usb 1-1.1: New USB device found, idVendor=060b, idProduct=6001
usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.1: Product: soild year usb hub keyboard
usb 1-1.1: Manufacturer: soild year
usb 1-1.1: SerialNumber: soild year usb hub keyboard
platform caam_sm: [0008] 35 3f f6 52 02 2b c9 6a
platform caam_sm: [0016] e0 60 75 68 39 dc f7 5c
platform caam_sm: [0024] 06 93 71 79 82 14 dc ba
platform caam_sm: [0032] 9a fb 0c db f8 1a c3 be
platform caam_sm: [0040] f2 42 c4 e6 1a d4 95 10
platform caam_sm: [0048] c3 87 0f 79 c5 08 34 6d
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 0e 2a 2b 7a 16 b0 cb 64
platform caam_sm: [0008] 9a 4d 2d b3 73 bf 3f cb
platform caam_sm: [0016] 43 75 43 d7 84 bd d0 55
platform caam_sm: [0024] f7 a5 46 4e 5a 29 4a ea
platform caam_sm: [0032] 49 34 c0 79 34 09 96 ac
platform caam_sm: [0040] c3 6c 2f 40 ce e1 b2 2a
platform caam_sm: [0048] 54 7e fa 63 2f 86 18 29
platform caam_sm: [0056] 10 93 10 bb e2 74 9c 3a
usb 1-1.2: new low-speed USB device number 4 using ci_hdrc
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] 24 2d 29 40 4f c6 a1 93
platform caam_sm: [0008] 34 03 a8 97 cd 75 fe 52
platform caam_sm: [0016] d9 a0 e7 36 4a 3c cc f6
platform caam_sm: [0024] 33 7c ba 11 f1 a2 d1 4a
platform caam_sm: [0032] 92 9c d9 6e 22 f1 8b 34
platform caam_sm: [0040] 20 d1 89 f6 a9 04 c1 29
platform caam_sm: [0048] 9d 9c fa 48 5b 17 71 59
platform caam_sm: [0056] 53 e4 2f e6 ff b5 d1 cc
platform caam_sm: [0064] c7 01 66 e7 5e 20 99 95
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 41 a8 2b 47 6a 66 51 5d
platform caam_sm: [0008] 84 ff 07 83 fd b8 66 42
platform caam_sm: [0016] 49 ff 51 b3 85 60 49 f9
platform caam_sm: [0024] 08 32 39 3d cf e5 54 c0
platform caam_sm: [0032] 20 1f cc ac a7 dc 65 b0
platform caam_sm: [0040] 90 9a 1a 72 0a 82 a2 d3
platform caam_sm: [0048] 64 bc 83 29 51 93 bf 8c
platform caam_sm: [0056] 03 b0 39 12 46 31 d1 bb
platform caam_sm: [0064] a5 ad c7 d6 a9 c3 97 7b
platform caam_sm: [0072] 54 b4 b7 44 46 68 f2 30
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 73 53 10 00 0d b2 3c 7c
usb 1-1.2: New USB device found, idVendor=04b3, idProduct=310d
usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
platform caam_sm: [0008] 42 26 66 af 4d 13 45 21
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 86 43 d8 cf 4b 12 6d 95
platform caam_sm: [0024] d1 4d e1 08 52 4f 74 52
platform caam_sm: restored 256-bit black key:
snvs-secvio 30370000.caam-snvs: violation handlers armed - non-secure state
input: soild year soild year usb hub keyboard as /devices/soc.3/30800000.aips-bus/30b20000.usb/ci_hdrc.1/usb1/1-1/1-1.1/1-1.1:1.0/0003:060B:6001.0001/input/input3
hid-generic 0003:060B:6001.0001: input,hidraw0: USB HID v1.10 Keyboard [soild year soild year usb hub keyboard] on usb-ci_hdrc.1-1.1/input0
hid (null): usage index exceeded
hid-generic 0003:060B:6001.0002: usage index exceeded
hid-generic 0003:060B:6001.0002: item 0 2 2 2 parsing failed
hid-generic: probe of 0003:060B:6001.0002 failed with error -22
input: HID 04b3:310d as /devices/soc.3/30800000.aips-bus/30b20000.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2:1.0/0003:04B3:310D.0003/input/input4
hid-generic 0003:04B3:310D.0003: input,hidraw1: USB HID v1.11 Mouse [HID 04b3:310d] on usb-ci_hdrc.1-1.2/input0
ashmem: initialized
coresight-tmc 30086000.etr: TMC initialized
coresight-tmc 30084000.etf: TMC initialized
coresight-tpiu 30087000.tpiu: TPIU initialized
coresight-funnel 30083000.funnel: FUNNEL initialized
coresight-funnel 30041000.funnel: FUNNEL initialized
coresight-replicator replicator.2: REPLICATOR initialized
coresight-etm3x 3007c000.etm: ETM initialized
coresight-etm3x 3007d000.etm: ETM initialized
imx-wm8960 sound.21: wm8960-hifi <-> 308a0000.sai mapping ok
imx-sii902x sound-hdmi.22: snd-soc-dummy-dai <-> 308c0000.sai mapping ok
u32 classifier
    Actions configured
nf_conntrack version 0.5.0 (15952 buckets, 63808 max)
mip6: Mobile IPv6
SWBST: disabling
wlreg_on: disabling
can2-3v3: disabling
dhd_module_init in
mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
mmc1: queuing unknown CIS tuple 0x80 (6 bytes)
mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
mmc1: new ultra high speed SDR104 SDIO card at address 0001
F1 signature OK, socitype:0x1 chip:0x4339 rev:0x1 pkg:0x0
DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
wifi_platform_get_mac_addr
CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211)
wl_create_event_handler(): thread:wl_event_handler:9b started
CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xec7e143c
dhd_attach(): thread:dhd_watchdog_thread:9c started
dhd_attach(): thread:dhd_dpc:9d started
dhd_deferred_work_init: work queue initialized
Dongle Host Driver, version 1.141.72 (r)
Compiled from
Register interface [wlan0]  MAC: 00:90:4c:11:22:33
dhd_prot_ioctl : bus is down. we have nothing to do
using random self ethernet address
using random host ethernet address
Number of LUNs=8
input: gpio-keys.0 as /devices/gpio-keys.0/input/input6
snvs_rtc 30370034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
ALSA device list:
  #0: wm8960-audio
  #1: sii902x-audio
Freeing unused kernel memory: 592K (c0e3c000 - c0ed0000)
init: init started!
audit: type=1403 audit(2.730:2): policy loaded auid=4294967295 ses=4294967295
audit: type=1404 audit(2.750:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: (Initializing SELinux enforcing took 0.24s.)
init: (Loading properties from /default.prop took 0.01s.)
init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
init: Waiting for /dev/.coldboot_done took 0.31s.
fs_mgr: Could not seek to start of verity metadata block.
fs_mgr: Could not set up verified partition, skipping!
EXT4-fs (mmcblk0p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p4): recovery complete
EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
fs_mgr: __mount(source=/dev/block/mmcblk0p4,target=/data,type=ext4)=0
EXT4-fs (mmcblk0p6): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p6): recovery complete
EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
fs_mgr: __mount(source=/dev/block/mmcblk0p6,target=/cache,type=ext4)=0
EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
fs_mgr: __mount(source=/dev/block/mmcblk0p7,target=/device,type=ext4)=0
binder: 174:174 transaction failed 29189, size 0-0
init: write_file: Unable to open '/sys/block/mmcblk1/queue/read_ahead_kb': No such file or directory
rfkill: BT RF going to : off
audit: type=1400 audit(7.140:4): avc:  denied  { write } for  pid=1 comm="init" name="galcore" dev="sysfs" ino=11024 scontext=u:r:init:s0 tcontext=u:object_r:sysfs:s0 tclass=dir
init: write_file: Unable to open '/sys/bus/platform/drivers/galcore/gpu3DMinClock': Permission denied
init: cannot find '/system/bin/netd', disabling 'netd'
init: cannot find '/system/bin/debuggerd', disabling 'debuggerd'
init: cannot find '/system/bin/debuggerd64', disabling 'debuggerd64'
init: cannot find '/system/bin/drmserver', disabling 'drm'
init: cannot find '/system/bin/mediaserver', disabling 'media'
init: cannot find '/system/bin/installd', disabling 'installd'
init: cannot find '/system/bin/install-recovery.sh', disabling 'flash_recovery'
init: cannot find '/system/bin/keystore', disabling 'keystore'
init: cannot find '/system/bin/rild', disabling 'ril-daemon'
init: cannot find '/system/bin/app_process', disabling 'zygote'
init: cannot find '/system/bin/gatekeeperd', disabling 'gatekeeperd'
init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
init: cannot find '/system/bin/fsl_sensor_fusion', disabling 'sensor_fusion'
mtp_bind_config
5,647件の閲覧回数
void_
I am getting same issue regarding booting of android - 5.1.1 lollipop in sabresd-imx6q board.
Freeing unused kernel memory: 428K (c0bb7000 - c0c22000)
audit: type=1403 audit(1.650:2): policy loaded auid=4294967295 ses=4294967295
audit: type=1404 audit(1.670:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
device-mapper: verity: metadata block 91433 is corrupted
fs_mgr: __mount(source=/dev/block/mmcblk2p4,target=/data,type=ext4)=-1
fs_mgr: fs_mgr_mount_all(): possibly an encryptable blkdev /dev/block/mmcblk2p4 for mount /data type ext4 )
fs_mgr: __mount(source=/dev/block/mmcblk2p6,target=/cache,type=ext4)=-1
fs_mgr: Failed to mount an un-encryptable or wiped partition on/dev/block/mmcblk2p6 at /cache options: nomblk_io_submit error: Read-only file system
binder: 132:132 transaction failed 29189, size 0-0
random: init urandom read with 53 bits of entropy available
mtp_bind_config
help me to solve this one thanks in advance
5,647件の閲覧回数
danwei_luo
Hi HongBo,
Please try adding "androidboot.dm_verity=disabled" in your bootargs.
Danwei Luo
5,647件の閲覧回数
vikaskolapudi
Hi Devaraj,
Platform : IMX6EVKSL
I am facing the similar issue as above, and when I am following the above steps:
I am ending up with an error:
dex2oatd F 23708 23708 art/runtime/gc/heap.cc:286] 0xffc32000-0xffc53000 rw- [stack]
dex2oatd F 23708 23708 art/runtime/runtime.cc:289] Runtime aborting...
dex2oatd F 23708 23708 art/runtime/runtime.cc:289] (Aborting thread was not attached to runtime!)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #00 pc 00006d56  /root/myandroid/out/host/linux-x86/lib/libbacktrace_libc++.so (UnwindCurrent::Unwind(unsigned int, ucontext*)+82)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #01 pc 000043f1  /root/myandroid/out/host/linux-x86/lib/libbacktrace_libc++.so (Backtrace::Unwind(unsigned int, ucontext*)+33)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #02 pc 00388819  /root/myandroid/out/host/linux-x86/lib/libartd.so (art::DumpNativeStack(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, int, char const*, art::mirror::ArtMethod*)+121)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #03 pc 00351a3d  /root/myandroid/out/host/linux-x86/lib/libartd.so (art::AbortState::Dump(std::__1::basic_ostream<char, std::__1::char_traits<char> >&)+301)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #04 pc 00351909  /root/myandroid/out/host/linux-x86/lib/libartd.so (art::Dumpable<art::AbortState>::Dump(std::__1::basic_ostream<char, std::__1::char_traits<char> >&) const+41)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #05 pc 00350298  /root/myandroid/out/host/linux-x86/lib/libartd.so (std::__1::basic_ostream<char, std::__1::char_traits<char> >& art::operator<<<art::AbortState>(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, art::Dumpable<art::AbortState> const&)+40)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #06 pc 00349738  /root/myandroid/out/host/linux-x86/lib/libartd.so (art::Runtime::Abort()+168)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #07 pc 000fcae9  /root/myandroid/out/host/linux-x86/lib/libartd.so (art::LogMessage::~LogMessage()+393)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #08 pc 001fe0c3  /root/myandroid/out/host/linux-x86/lib/libartd.so (art::gc::Heap::Heap(unsigned int, unsigned int, unsigned int, unsigned int, double, double, unsigned int, unsigned int, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, art::InstructionSet, art::gc::CollectorType, art::gc::CollectorType, unsigned int, unsigned int, bool, unsigned int, unsigned int, bool, bool, bool, bool, bool, bool, bool, bool, bool, unsigned long long)+6995)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #09 pc 00349f4f  /root/myandroid/out/host/linux-x86/lib/libartd.so (art::Runtime::Init(std::__1::vector<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, void const*>, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, void const*> > > const&, bool)+1295)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #10 pc 00349a0d  /root/myandroid/out/host/linux-x86/lib/libartd.so (art::Runtime::Create(std::__1::vector<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, void const*>, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, void const*> > > const&, bool)+93)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #11 pc 00017aca  /root/myandroid/out/host/linux-x86/bin/dex2oatd (art::Dex2Oat::CreateRuntime(std::__1::vector<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, void const*>, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, void const*> > > const&, art::InstructionSet)+42)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #12 pc 0000f22f  /root/myandroid/out/host/linux-x86/bin/dex2oatd (art::Dex2Oat::Create(art::Dex2Oat**, std::__1::vector<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, void const*>, std::__1::allocator<std::__1::pair<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, void const*> > > const&, art::CompilerOptions const&, art::Compiler::Kind, art::InstructionSet, art::InstructionSetFeatures, art::VerificationResults*, art::DexFileToMethodInlinerMap*, unsigned int)+143)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #13 pc 00008a65  /root/myandroid/out/host/linux-x86/bin/dex2oatd (art::dex2oat(int, char**)+12885)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #14 pc 00005800  /root/myandroid/out/host/linux-x86/bin/dex2oatd (main+32)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #15 pc 00019a62  /lib32/libc-2.19.so (__libc_start_main+242)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289]   native: #16 pc 00004de4  /root/myandroid/out/host/linux-x86/bin/dex2oatd (???)
dex2oatd F 23708 23708 art/runtime/runtime.cc:289] Dumping all threads without appropriate locks held: thread list lock mutator lock
dex2oatd F 23708 23708 art/runtime/runtime.cc:289] All threads:
dex2oatd F 23708 23708 art/runtime/runtime.cc:289] DALVIK THREADS (0):
make: *** [out/target/product/generic/obj/APPS/BasicDreams_intermediates/arm/package.odex] Aborted (core dumped)
make: *** Deleting file `out/target/product/generic/obj/APPS/BasicDreams_intermediates/arm/package.odex'
Please help me to resolve this issue.
Thanks and Regards,
Joseph Vikas.
5,647件の閲覧回数
devarajgs
Looks like issue with the build environment setup.
repo sync might not have been successful.
Please follow the guidelines provided in the BSP user guide from the beginning.
Thanks and Regards,
-Devaraj
