Booting i.MX6Q custom board from eMMC instead of USB
309件の閲覧回数
Rajagopal_VS
Dear NXP Community,
I have set up a Yocto build system and successfully generated the Yocto images (bootloader, rootfs, etc.) for our custom carrier board based on the i.MX6Q SoC.
Currently, the board is booting from a USB drive (partitioned with boot and rootfs). The boot partition contains the following files:
boot.scr
imx6q-apalis-eval.dtb
overlays/
overlays.txt
zImage
Now, I would like to completely avoid using the USB drive and instead boot the system directly from the internal flash or eMMC.
Could you please guide me with the required steps or commands to achieve this?
Thanks in advance for your support.
Raj
247件の閲覧回数
Bio_TICFSL
Yes you can boot from eMMC, you must first prepare the eMMC by flashing an operating system image to it, typically using the dd command in Linux . After flashing, the processor's hardware must be configured to select the eMMC as the boot source, often through low-level boot registers or by setting a hardware boot mode. Accessing the  uboot promp is a common method to both prepare the eMMC from a secondary source and to configure the eMMC boot environment before the kernel loads.
Steps to Boot from eMMC on i.MX6
  1. Get the i.MX6 Serial Console and U-Boot:
    Connect the board to your computer via its serial console port.
    Use a terminal program (like minicom or TeraTerm) to connect at 115200 baud.
    Power on the board and quickly press a key to interrupt the auto-boot process and get to the U-Boot prompt.
    Prepare the eMMC:
    Option 1: Using U-Boot with a Secondary Boot Source: If the eMMC is blank or corrupt, load a bootable image onto the eMMC from another source, such as an SD card or via TFTP.
    Use U-Boot commands like fatload to read the image and mmc write to write it to the eMMC.
    Option 2: Using dd (from a running Linux system):
    • Boot your i.MX6 board from an SD card or other media.
      Use the dd command to write the desired operating system image file directly to the eMMC device (e.g., /dev/mmcblk0).
      Configure eMMC Boot Settings:
      Method A: Via U-Boot Environment:
      • In U-Boot, you can sometimes change the boot environment variables to tell U-Boot to look for the kernel and root filesystem on the eMMC.
        Method B: Using sysfs (within Linux):
        • After the board boots from another source, you can set low-level eMMC boot configurations through the sysfs interface.
          Navigate to the appropriate eMMC device path, such as /sys/devices/platform/sdhci-esdhc-imx.2/mmc_host/mmc0/mmc0:0001, and modify the boot_partition or other relevant settings in boot_info.
          Restart and Boot from eMMC:
          • Once the eMMC is flashed and the boot configuration is set, restart the board.
            The i.MX6 should now boot the kernel and operating system directly from the eMMC storage device
%3CLINGO-SUB%20id%3D%22lingo-sub-2179965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUSB%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FeMMC%E3%81%8B%E3%82%89i.MX6Q%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179965%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AE%E7%9A%86%E6%A7%98%3C%2FP%3E%3CP%3EYocto%20%E3%83%93%E3%83%AB%E3%83%89%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%80%81i.MX6Q%20SoC%20%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%82%A2%20%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%20Yocto%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%80%81rootfs%20%E3%81%AA%E3%81%A9)%20%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%20USB%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%20(boot%20%E3%81%A8%20rootfs%20%E3%81%A7%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E5%88%86%E5%89%B2)%20%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%83%96%E3%83%BC%E3%83%88.scr%3CBR%20%2F%3Eimx6q-apalis-eval.dtb%3CBR%20%2F%3E%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4%2F%3CBR%20%2F%3E%E3%82%AA%E3%83%BC%E3%83%90%E3%83%BC%E3%83%AC%E3%82%A4.txt%3CBR%20%2F%3Ez%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%80%81USB%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%96%E3%81%AE%E4%BD%BF%E7%94%A8%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E9%81%BF%E3%81%91%E3%80%81%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E5%86%85%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%BE%E3%81%9F%E3%81%AF%20eMMC%20%E3%81%8B%E3%82%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E7%9B%B4%E6%8E%A5%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%84%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%B8%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Booting%20i.MX6Q%20custom%20board%20from%20eMMC%20instead%20of%20USB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81eMMC%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20data-huuid%3D%2214937114575135769857%22%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92eMMC%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%A6%E6%BA%96%E5%82%99%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E9%80%9A%E5%B8%B8%E3%81%AFLinux%E3%81%AE%3CCODE%20class%3D%22mv6bHd%22%3Edd%3C%2FCODE%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20class%3D%22M5tQyf%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%2214937114575135770952%22%3E%3CMARK%20class%3D%22QVRyCf%22%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%BE%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%80%81eMMC%E3%82%92%E3%83%96%E3%83%BC%E3%83%88%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%3C%2FMARK%3E%E3%80%82%3C%2FSPAN%3E%3CSPAN%20data-huuid%3D%2214937114575135772047%22%3Euboot%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%80%81%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89eMMC%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E5%89%8D%E3%81%ABeMMC%E3%83%96%E3%83%BC%E3%83%88%E7%92%B0%E5%A2%83%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E6%96%B9%E6%B3%95%E3%81%A7%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%226ca9b9a5-20f4-41c4-aa96-5ae9123eb2ef%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3CDIV%20class%3D%22rPeykc%20pyPiTc%22%20data-hveid%3D%22CBIQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Qo_EKegQIEhAB%22%3E%3CSPAN%20data-huuid%3D%2218319548216719600751%22%3Ei.MX6%E3%81%A7eMMC%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E6%89%8B%E9%A0%86%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22WaaZC%22%3E%0A%3CDIV%20class%3D%22RJPOee%20EIJn2%22%20style%3D%22animation%3A%20none%20!important%3B%22%3E%0A%3COL%20data-hveid%3D%22CFAQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8QnPYKegQIUBAB%22%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%2218319548216719599046%22%3E%3CSTRONG%3Ei.MX6%20%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%A8%20U-Boot%20%E3%82%92%E5%85%A5%E6%89%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%2218319548216719601437%22%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22e4d62e4e-ff69-462d-ae34-68754af15f53%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22e4d62e4e-ff69-462d-ae34-68754af15f53%22%20data-uuids%3D%2218319548216719601437%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCAQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Q3fYKegQIIBAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%3CSPAN%20data-huuid%3D%2218319548216719598935%22%3E%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20(minicom%20%E3%82%84%20TeraTerm%20%E3%81%AA%E3%81%A9)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20115200%20%E3%83%9C%E3%83%BC%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%3CSPAN%20data-huuid%3D%2218319548216719598935%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E8%BB%8A%E8%BC%89%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E4%B8%AD%E6%96%AD%E3%81%97%E3%80%81U-Boot%20%E3%83%97%E3%83%AD%E3%83%B3%E3%83%97%E3%83%88%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%224b1062e3-fdca-42a6-b67c-52daf4928c18%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%224b1062e3-fdca-42a6-b67c-52daf4928c18%22%20data-uuids%3D%2218319548216719600529%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCcQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Q3fYKegQIJxAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%2218319548216719598027%22%3E%3CSTRONG%3EeMMC%20%E3%82%92%E6%BA%96%E5%82%99%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%2218319548216719600418%22%3E%3CSTRONG%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%201%3A%20%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%20%E3%83%96%E3%83%BC%E3%83%88%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A7%20U-Boot%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%20%3CSPAN%20data-huuid%3D%2218319548216719598713%22%3EeMMC%20%E3%81%8C%E7%A9%BA%E3%81%BE%E3%81%9F%E3%81%AF%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%3CA%20class%3D%22DTlJ6d%22%20href%3D%22https%3A%2F%2Fwww.google.com%2Fsearch%3Fclient%3Dfirefox-b-d%26amp%3Bsca_esv%3Dbbe3debe957613b7%26amp%3Bchannel%3Dentpr%26amp%3Bcs%3D1%26amp%3Bq%3DSD%2Bcard%26amp%3Bsa%3DX%26amp%3Bved%3D2ahUKEwigot2c4o-QAxUMNEQIHVD-FO8QxccNegQIIRAB%26amp%3Bmstk%3DAUtExfDIOQoZdKG8pe1IEb6aoAvN8qVO2KTtlihS0p_Jg-g6ifGgp1tR7NmRuzuRZOk-_QCRiWyJ92dyLL7oJpdSkIsFMKzng4zge0Imql4MhN8g3v_0dbB1ynXS3KlzRSmOoLg%26amp%3Bcsui%3D3%22%20data-hveid%3D%22CCEQAQ%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESD%20%E3%82%AB%E3%83%BC%E3%83%89%3C%2FA%3E%E3%82%84%20TFTP%20%E3%81%AA%E3%81%A9%E3%81%AE%E5%88%A5%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%20eMMC%20%E3%81%AB%E3%83%96%E3%83%BC%E3%83%88%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22837cf07a-57e9-4090-8464-26aa1c06a83f%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22837cf07a-57e9-4090-8464-26aa1c06a83f%22%20data-uuids%3D%2218319548216719598713%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCEQAg%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Q3fYKegQIIRAC%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%2218319548216719600307%22%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%E3%81%AB%E3%81%AF%3CCODE%20class%3D%22mv6bHd%22%3Efatload%3C%2FCODE%3E%E3%81%AA%E3%81%A9%E3%81%AE%20U-Boot%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81eMMC%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%AB%E3%81%AF%3CCODE%20class%3D%22mv6bHd%22%3Emmc%20write%3C%2FCODE%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%22d619fb15-4460-4f16-a5b9-e5b1dc45f713%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%22d619fb15-4460-4f16-a5b9-e5b1dc45f713%22%20data-uuids%3D%2218319548216719600307%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CB8QAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Q3fYKegQIHxAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%3CSPAN%20data-huuid%3D%2218319548216719597805%22%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%202%3A%20%3CCODE%20class%3D%22mv6bHd%22%3Edd%3C%2FCODE%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20(%E5%AE%9F%E8%A1%8C%E4%B8%AD%E3%81%AE%20Linux%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8B%E3%82%89)%3A%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CUL%20data-hveid%3D%22CEYQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Qm_YKegQIRhAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2218319548216719600196%22%3ESD%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%97%E3%83%AC%E3%82%B9%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%80%81%E8%A3%BD%E5%93%81%E3%83%8B%E3%83%A5%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%20i.MX6%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%229ce40378-0014-43a4-bff1-db602f3dab5c%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CEEQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Q3fYKegQIQRAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%3CSPAN%20data-huuid%3D%2218319548216719597694%22%3E%3CCODE%20class%3D%22mv6bHd%22%3Edd%3C%2FCODE%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%20eMMC%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20(%E4%BE%8B%3A%20%3CCODE%20class%3D%22mv6bHd%22%3E%2Fdev%2Fmmcblk0%3C%2FCODE%3E%20)%20%E3%81%AB%E7%9B%B4%E6%8E%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%2294d8d6da-fae7-446a-96c6-532a92652688%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%2294d8d6da-fae7-446a-96c6-532a92652688%22%20data-uuids%3D%2218319548216719597694%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%2218319548216719599288%22%3E%3CSTRONG%3EeMMC%20%E3%83%96%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%2218319548216719597583%22%3E%3CSTRONG%3E%E6%96%B9%E6%B3%95A%3A%20U-Boot%E7%92%B0%E5%A2%83%E7%B5%8C%E7%94%B1%3A%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%0A%3CUL%20data-hveid%3D%22CDIQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Qm_YKegQIMhAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2218319548216719599974%22%3EU-Boot%20%E3%81%A7%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%80%81U-Boot%20%E3%81%AB%20eMMC%20%E4%B8%8A%E3%81%AE%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E3%83%AB%E3%83%BC%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%8C%87%E7%A4%BA%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%229d63ee0d-827d-4a13-b1f2-8310ccad066e%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%229d63ee0d-827d-4a13-b1f2-8310ccad066e%22%20data-uuids%3D%2218319548216719599974%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCYQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Q3fYKegQIJhAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%2218319548216719601568%22%3E%E6%96%B9%E6%B3%95%20B%3A%20%3CCODE%20class%3D%22mv6bHd%22%3Esysfs%3C%2FCODE%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20(Linux%20%E5%86%85)%3A%20%3C%2FSPAN%3E%0A%3CUL%20data-hveid%3D%22CEsQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Qm_YKegQISxAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2218319548216719599863%22%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E5%88%A5%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%20%3CCODE%20class%3D%22mv6bHd%22%3Esysfs%3C%2FCODE%3E%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E4%BD%8E%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%20eMMC%20%E3%83%96%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%229b3208fa-130e-4155-99f9-fafa4b265f51%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%3CSPAN%20data-huuid%3D%2218319548216719601457%22%3E%3CCODE%20class%3D%22mv6bHd%22%3E%2Fsys%2Fdevices%2F%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%2Fsdhci-esdhc-imx.2%2Fmmc_host%2Fmmc0%2Fmmc0%3A0001%3C%2FCODE%3E%20%E3%81%AA%E3%81%A9%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%20eMMC%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%91%E3%82%B9%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%80%81%3CCODE%20class%3D%22mv6bHd%22%3E%20boot_info%3C%2FCODE%3E%20%E3%81%AE%3CCODE%20class%3D%22mv6bHd%22%3E%20boot_partition%3C%2FCODE%3E%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%224c5153cd-ce94-4062-9f28-8bb6b748038d%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E9%96%A2%E9%80%A3%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%224c5153cd-ce94-4062-9f28-8bb6b748038d%22%20data-uuids%3D%2218319548216719601457%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CEAQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Q3fYKegQIQBAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22Gur8Ad%22%20style%3D%22display%3A%20inline%3B%22%3E%3CSPAN%20data-huuid%3D%2218319548216719598955%22%3E%3CSTRONG%3E%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6eMMC%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%20%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%0A%3CUL%20data-hveid%3D%22CDQQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Qm_YKegQINBAB%22%3E%0A%3CLI%3E%3CSPAN%20data-huuid%3D%2218319548216719601346%22%3EeMMC%20%E3%81%8C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E6%A7%8B%E6%88%90%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CSPAN%20class%3D%22pjBG2e%22%20data-cid%3D%2297929a94-d528-47d2-8951-acdda3960769%22%3E%3CSPAN%20class%3D%22UV3uM%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CDIV%20class%3D%22NPrrbc%22%20data-cid%3D%2297929a94-d528-47d2-8951-acdda3960769%22%20data-uuids%3D%2218319548216719601346%22%3E%0A%3CDIV%20class%3D%22BMebGe%20btku5b%20LwdV0e%20FR7ZSc%20OJeuxf%22%20tabindex%3D%220%22%20role%3D%22button%22%20aria-label%3D%22Ver%20v%C3%ADnculos%20relacionados%22%20data-hveid%3D%22CCMQAQ%22%20data-ved%3D%222ahUKEwigot2c4o-QAxUMNEQIHVD-FO8Q3fYKegQIIxAB%22%3E%0A%3CDIV%20class%3D%22niO4u%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20data-huuid%3D%2218319548216719598844%22%3Ei.MX6%E3%81%AFeMMC%E3%82%B9%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8B%E3%82%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E7%9B%B4%E6%8E%A5%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20data-huuid%3D%2218319548216719598844%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CDIV%20class%3D%22zMgcWd%20dSKvsb%22%20data-il%3D%22%22%3E%0A%3CDIV%20data-crb-p%3D%22%22%3E%0A%3CDIV%20class%3D%22xFTqob%22%3E%0A%3CDIV%20class%3D%22vM0jzc%22%20style%3D%22display%3A%20inline%3B%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
