Booting Issue
Booting Issue
1,293 次查看
gowthamraj1402
Hello Experts,
Am facing issue on Boot time,
Booting method : Via EMMC
U-Boot 2021.04 (Apr 28 2022 - 21:18:04 +0000)
CPU: NXP i.MX8QXP RevC A35 at 1200 MHz at 29C
Model: NXP i.MX8QXP COLLINS
Board: iMX8QXP COLLINS
Boot: MMC0
DRAM: 3 GiB
pca953x gpio@1a: Error reading output register
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
[*]-Video Link 0 (1280 x 720)
[0] dpu@56180000, video
[1] lvds-channel@0, display
In: serial
Out: serial
Err: serial
BuildInfo:
- SCFW 549b1e18, SECO-FW 7aeb8423, IMX-MKIMAGE 7a277c8a, ATF 5782363
- U-Boot 2021.04
switch to partitions #0, OK
mmc0(part 0) is current device
flash target is MMC:0
Net: pca953x gpio@1a: Error reading output register
Warning: ethernet@5b040000 (eth0) using random MAC address - b6:72:1d:f5:ad:d8
eth0: ethernet@5b040000 [PRIME]
Warning: ethernet@5b050000 (eth1) using random MAC address - 22:21:81:cd:7f:ba
, eth1: ethernet@5b050000
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 3 2 1 0
Failed to load 'boot.scr'
28072448 bytes read in 126 ms (212.5 MiB/s)
Booting from mmc ...
122982 bytes read in 7 ms (16.8 MiB/s)
Moving Image from 0x80280000 to 0x80400000, end=81fa0000
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 0000000083000000, end 0000000083021065
Disable clock-controller@5a4d0000 rsrc 62 not owned
Disable clock-controller@5ac90000 rsrc 102 not owned
Disable clock-controller@585a0000 rsrc 411 not owned
Starting kernel ...
Booting Linux on physical CPU 0x0000000000 [0x410fd042]
Linux version 5.10.87-yocto-standard (oe-user@oe-host) (aarch64-wrs-linux-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1.20210209) #1 SMP PREEMPT Mon Apr 10 06:50:25 UTC 2023
Machine model: Freescale i.MX8QXP COLLINS
earlycon: lpuart32 at MMIO32 0x000000005a060000 (options '')
printk: bootconsole [lpuart32] enabled
efi: UEFI not found.
OF: fdt: Reserved memory: failed to reserve memory for node 'm4@0x88000000': base 0x0000000088000000, size 128 MiB
Reserved memory: created CMA memory pool at 0x00000000c0000000, size 960 MiB
OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
Reserved memory: created DMA memory pool at 0x0000000090400000, size 1 MiB
OF: reserved mem: initialized node vdevbuffer, compatible id shared-dma-pool
Zone ranges:
DMA [mem 0x0000000080200000-0x00000000ffffffff]
DMA32 empty
Normal [mem 0x0000000100000000-0x00000008bfffffff]
Movable zone start for each node
Early memory node ranges
node 0: [mem 0x0000000080200000-0x0000000083ffffff]
node 0: [mem 0x0000000084000000-0x00000000861fffff]
node 0: [mem 0x0000000086200000-0x000000008fffffff]
node 0: [mem 0x0000000090000000-0x000000009001ffff]
node 0: [mem 0x0000000090020000-0x00000000900fefff]
node 0: [mem 0x00000000900ff000-0x00000000900fffff]
node 0: [mem 0x0000000090100000-0x00000000901fffff]
node 0: [mem 0x0000000090200000-0x00000000904fffff]
node 0: [mem 0x0000000090500000-0x0000000091ffffff]
node 0: [mem 0x0000000092000000-0x0000000094bfffff]
node 0: [mem 0x0000000094c00000-0x00000000ffffffff]
node 0: [mem 0x0000000880000000-0x00000008bfffffff]
Initmem setup node 0 [mem 0x0000000080200000-0x00000008bfffffff]
psci: probing for conduit method from DT.
psci: PSCIv1.1 detected in firmware.
psci: Using standard PSCI v0.2 function IDs
psci: MIGRATE_INFO_TYPE not supported.
psci: SMC Calling Convention v1.2
percpu: Embedded 30 pages/cpu s83416 r8192 d31272 u122880
Detected VIPT I-cache on CPU0
CPU features: detected: GIC system register CPU interface
Built 1 zonelists, mobility grouping on. Total pages: 773640
Kernel command line: console=ttyLP0,115200 earlycon root=/dev/mmcblk0p2 rootwait rw
Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
mem auto-init: stack:off, heap alloc:off, heap free:off
software IO TLB: mapped [mem 0x00000000bc000000-0x00000000c0000000] (64MB)
Memory: 1789888K/3143680K available (15872K kernel code, 2262K rwdata, 4304K rodata, 4864K init, 808K bss, 370752K reserved, 983040K cma-reserved)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
ftrace: allocating 49600 entries in 194 pages
ftrace: allocated 194 pages with 3 groups
rcu: Preemptible hierarchical RCU implementation.
rcu: RCU event tracing is enabled.
rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
Trampoline variant of Tasks RCU enabled.
Rude variant of Tasks RCU enabled.
Tracing variant of Tasks RCU enabled.
rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
GICv3: GIC: Using split EOI/Deactivate mode
GICv3: 512 SPIs implemented
GICv3: 0 Extended SPIs implemented
GICv3: Distributor has no Range Selector support
GICv3: 16 PPIs implemented
GICv3: CPU0: found redistributor 0 region 0:0x0000000051b00000
random: get_random_bytes called from start_kernel+0x390/0x598 with crng_init=0
arch_timer: cp15 timer(s) running at 8.00MHz (phys).
clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
Console: colour dummy device 80x25
Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
pid_max: default: 32768 minimum: 301
LSM: Security Framework initializing
Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
rcu: Hierarchical SRCU implementation.
EFI services will not be available.
smp: Bringing up secondary CPUs ...
Detected VIPT I-cache on CPU1
GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
CPU1: Booted secondary processor 0x0000000001 [0x410fd042]
Detected VIPT I-cache on CPU2
GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
CPU2: Booted secondary processor 0x0000000002 [0x410fd042]
Detected VIPT I-cache on CPU3
GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
CPU3: Booted secondary processor 0x0000000003 [0x410fd042]
smp: Brought up 1 node, 4 CPUs
SMP: Total of 4 processors activated.
CPU features: detected: 32-bit EL0 Support
CPU features: detected: CRC32 instructions
CPU: All CPU(s) started at EL2
alternatives: patching kernel code
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
pinctrl core: initialized pinctrl subsystem
DMI not present or invalid.
NET: Registered protocol family 16
DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
thermal_sys: Registered thermal governor 'step_wise'
cpuidle: using governor ladder
hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
ASID allocator initialised with 65536 entries
imx mu driver is registered.
imx rpmsg driver is registered.
HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
raid6: neonx8 gen() 1289 MB/s
raid6: neonx8 xor() 995 MB/s
raid6: neonx4 gen() 1292 MB/s
raid6: neonx4 xor() 976 MB/s
raid6: neonx2 gen() 1210 MB/s
raid6: neonx2 xor() 886 MB/s
raid6: neonx1 gen() 1072 MB/s
raid6: neonx1 xor() 755 MB/s
raid6: int64x8 gen() 815 MB/s
raid6: int64x8 xor() 448 MB/s
raid6: int64x4 gen() 875 MB/s
raid6: int64x4 xor() 458 MB/s
raid6: int64x2 gen() 815 MB/s
raid6: int64x2 xor() 431 MB/s
raid6: int64x1 gen() 608 MB/s
raid6: int64x1 xor() 360 MB/s
raid6: using algorithm neonx4 gen() 1292 MB/s
raid6: .... xor() 976 MB/s, rmw enabled
raid6: using neon recovery algorithm
iommu: Default domain type: Translated
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
mc: Linux media interface: v0.10
videodev: Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.22
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
imx-scu scu: NXP i.MX SCU Initialized
random: fast init done
imx8qxp-pinctrl scu:pinctrl: Invalid fsl,pins or pins property in node /scu/pinctrl/mipi_lvds1_pwm_grp
imx8qxp-pinctrl scu:pinctrl: initialized IMX pinctrl driver
clocksource: Switched to clocksource arch_sys_counter
NET: Registered protocol family 2
IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
TCP: Hash tables configured (established 32768 bind 32768)
UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Initialise system trusted keyrings
workingset: timestamp_bits=46 max_order=20 bucket_order=0
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
Key type cifs.idmap registered
xor: measuring software checksum speed
8regs : 1765 MB/sec
32regs : 2049 MB/sec
arm64_neon : 1754 MB/sec
xor: using function: 32regs (2049 MB/sec)
async_tx: api initialized (async)
Key type asymmetric registered
Asymmetric key parser 'x509' registered
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
io scheduler mq-deadline registered
io scheduler kyber registered
mixel-lvds-combo-phy 56221000.ldb_phy: cannot get phy clock
mixel-lvds-combo-phy 56241000.ldb_phy: cannot get phy clock
mixel-mipi-dphy 56228300.dphy: No phy_ref clock found
mixel-mipi-dphy 56248300.dphy: No phy_ref clock found
Bus freq driver module loaded
5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 62, base_baud = 5000000) is a FSL_LPUARprintk: console [ttyLP0] enabled
printk: bootconsole [lpuart32] disabled
5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 63, base_baud = 5000000) is a FSL_LPUART
5a080000.serial: ttyLP2 at MMIO 0x5a080010 (irq = 64, base_baud = 5000000) is a FSL_LPUART
5a090000.serial: ttyLP3 at MMIO 0x5a090010 (irq = 65, base_baud = 5000000) is a FSL_LPUART
dpu-core 56180000.dpu: driver probed
brd: module loaded
loop: module loaded
imx ahci driver is registered.
fsl_lpspi 5a010000.spi: spi_register_controller error.
spi-nor spi1.0: mt35xu512aba (65536 Kbytes)
3 fixed-partitions partitions found on MTD device 5d120000.spi
Creating 3 MTD partitions on "5d120000.spi":
0x000000000000-0x000000200000 : "uboot"
0x000000200000-0x000000500000 : "dts"
0x000000300000-0x000002300000 : "kernel"
libphy: Fixed MDIO Bus: probed
pps pps0: new PPS source ptp0
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
ehci-platform: EHCI generic platform driver
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-pci: OHCI PCI platform driver
ohci-platform: OHCI generic platform driver
usbcore: registered new interface driver uas
input: sc-powerkey as /devices/platform/sc-powerkey/input/input0
imx-sc-rtc scu:rtc: registered as rtc0
imx-sc-rtc scu:rtc: setting system clock to 1970-01-01T00:00:08 UTC (8)
i2c /dev entries driver
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
ledtrig-cpu: registered to indicate activity on CPUs
SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
caam 31400000.crypto: device ID = 0x0a16040000000100 (Era 9)
caam 31400000.crypto: job rings = 2, qi = 0
mmc0: SDHCI controller on 5b010000.mmc [5b010000.mmc] using ADMA
caam algorithms registered in /proc/crypto
caam 31400000.crypto: caam pkc algorithms registered in /proc/crypto
caam 31400000.crypto: registering rng-caam
Device caam-keygen registered
usbhid: USB HID core driver
mxc-md bus@58000000:camera: deferring cap_device device registration
mxc-isi 58100000.isi: mxc_isi.0 registered successfully
random: crng init done
mxc-mipi-csi2 58227000.csi: lanes: 2, name: mxc-mipi-csi2.0
mmc0: new HS400 MMC card at address 0001
remoteproc remoteproc0: releasing imx-rproc
mmcblk0: mmc0:0001 S0J35A 7.28 GiB
imx8qxp_adc 5a880000.adc: supply vref not found, using dummy regulator
mmcblk0boot0: mmc0:0001 S0J35A partition 1 31.5 MiB
mmcblk0boot1: mmc0:0001 S0J35A partition 2 31.5 MiB
mmcblk0rpmb: mmc0:0001 S0J35A partition 3 4.00 MiB, chardev (243:0)
[VPU Decoder] warning: init rtx channel failed, ret: -517
mmcblk0: p1 p2
[VPU Decoder] failed to request mailbox, ret = -517
[VPU Encoder] warning: init rtx channel failed, ret: -517
[VPU Encoder] fail to request mailbox, ret = -517
Galcore version 6.4.3.p2.336687
[drm] Initialized vivante 1.0.0 20170808 for 80000000.imx8_gpu0_ss on minor 0
OF: /sound-bt-sco/simple-audio-card,cpu: could not get #sound-dai-cells for /bus@59000000/sai@59040000
asoc-simple-card sound-bt-sco: parse error -22
asoc-simple-card: probe of sound-bt-sco failed with error -22
u32 classifier
input device check on
Actions configured
NET: Registered protocol family 10
Segment Routing with IPv6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Bridge firewalling registered
Key type dns_resolver registered
NET: Registered protocol family 40
Loading compiled-in X.509 certificates
Key type ._fscrypt registered
Key type .fscrypt registered
Key type fscrypt-provisioning registered
Btrfs loaded, crc32c=crc32c-generic
Key type encrypted registered
gpio-42 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
imx-lpi2c 37230000.i2c: using scl,sda for recovery
imx-lpi2c 37230000.i2c: can't get the TX DMA channel, error -19!
imx-lpi2c 37230000.i2c: error -ENODEV: dma setup error -19, use pio
i2c i2c-16: LPI2C adapter registered
pca953x 1-001a: error -ENODEV: reg get err
pca953x 1-001a: using no AI
pca953x 1-001a: failed writing register
pca953x: probe of 1-001a failed with error -5
i2c i2c-1: Added multiplexed i2c bus 17
i2c i2c-1: Added multiplexed i2c bus 18
i2c i2c-1: Added multiplexed i2c bus 19
i2c i2c-1: Added multiplexed i2c bus 20
pca954x 1-0071: registered 4 multiplexed busses for I2C switch pca9646
i2c i2c-1: LPI2C adapter registered
imx-lpi2c 58226000.i2c: can't get the TX DMA channel, error -19!
imx-lpi2c 58226000.i2c: error -ENODEV: dma setup error -19, use pio
imx219 21-0010: failed to read chip id 219
imx219: probe of 21-0010 failed with error -5
i2c i2c-21: LPI2C adapter registered
imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops 0xffff8000110623c8)
imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops 0xffff800011062088)
imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops 0xffff800011062088)
fsl_lpspi 5a010000.spi: dma setup error -19, use pio
[drm] Initialized st7735r 1.0.0 20171128 for spi2.0 on minor 1
Console: switching to colour frame buffer device 20x16
st7735r spi2.0: [drm] fb0: st7735rdrmfb frame buffer device
fec 5b040000.ethernet: Invalid MAC address: 00:00:00:00:00:00
fec 5b040000.ethernet: Using random MAC address: ce:e0:c7:2f:74:ea
libphy: fec_enet_mii_bus: probed
fec 5b040000.ethernet eth0: registered PHC device 0
xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
xhci-hcd xhci-hcd.1.auto: hcc params 0x200073c8 hci version 0x100 quirks 0x0000002200018010
xhci-hcd xhci-hcd.1.auto: irq 176, io mem 0x5b130000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
unregister ISI channel: mxc_isi.0
imx-rproc imx8x_cm4@0: mbox_request_channel_byname() could not locate channel named "txdb"
imx-rproc imx8x_cm4@0: No txdb, ret -22
remoteproc remoteproc0: imx-rproc is available
mmc1: SDHCI controller on 5b020000.mmc [5b020000.mmc] using ADMA
imx-lpi2c 56226000.i2c: can't get the TX DMA channel, error -19!
imx-lpi2c 56226000.i2c: error -ENODEV: dma setup error -19, use pio
adv7511 22-003d: supply avdd not found, using dummy regulator
adv7511 22-003d: supply dvdd not found, using dummy regulator
adv7511 22-003d: supply pvdd not found, using dummy regulator
adv7511 22-003d: supply a2vdd not found, using dummy regulator
adv7511 22-003d: supply v3p3 not found, using dummy regulator
adv7511 22-003d: supply v1p2 not found, using dummy regulator
adv7511 22-003d: Probe failed. Remote port 'dsi_host@56228000' disabled
i2c i2c-22: LPI2C adapter registered
imx-lpi2c 56246000.i2c: can't get the TX DMA channel, error -19!
imx-lpi2c 56246000.i2c: error -ENODEV: dma setup error -19, use pio
adv7511 23-003d: supply avdd not found, using dummy regulator
adv7511 23-003d: supply dvdd not found, using dummy regulator
adv7511 23-003d: supply pvdd not found, using dummy regulator
adv7511 23-003d: supply a2vdd not found, using dummy regulator
adv7511 23-003d: supply v3p3 not found, using dummy regulator
adv7511 23-003d: supply v1p2 not found, using dummy regulator
adv7511 23-003d: Probe failed. Remote port 'dsi_host@56248000' disabled
i2c i2c-23: LPI2C adapter registered
1,281 次查看
Dhruvit
Hi @gowthamraj1402,
I hope you are doing well.
Thanks for the logs, I checked it.
->Please kindly share the command you gave to boot from eMMC.
->If one wants to boot up the system through rootfs in eMMC, using HDMI as display:
Please follow the below-given command for i.MX8QXP
a. Pick a particular video mode for legacy FB emulation since system startup.
video=HDMI-A-{n}: {video_mode}
b. Enable or disable legacy FB emulation.
drm_kms_helper.fbdev_emulation=0 or 1
c. Set legacy FB emulation framebuffer’s bits per pixel (bpp) parameter.
imxdrm.legacyfb_depth=16 or 24 or 32
Please kindly refer to section 4.4.1.3 Using eMMC for more details
https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
I hope this information helps you!
Thanks & Regards,
Dhruvit Vasavada
