Boot wince 6.0 image from SD card with MX28
liangliangzhu
Hi All,
I am trying to boot the wince image my SD card.    I have configure to run the image from SD card,
                                 [5] Select Boot Device : NK from SD/MMC
However, the booting process stuck at reading the NK image
            Initiating image launch in 0 seconds.
            Launching flash image  ...
            INFO: Using device name: 'MX2865535'
            INFO: Reading NK image to SDHC (please wait)...
Thank you for your help!
Liang
liangliangzhu
Dear Adeneo Support Team,
sorry for the late reply!  I just found out that I have reply from you!
1.  Yes,  I am building my own binaries and I did replaced all the binaries on the SD card
2.  I do not whether this is the hardware revision number you are looking for, MX2865535
3.  I have a display connected to the motherboard.
Thank you,
Liang
admin
Specialist II
Deactivated user, can you help with this question?  Thanks.
karina_valencia
NXP Apps Support
NXP Apps Support
Deactivated user are you available to help on this case?
