Boot time of Android 13.4.1 on the sabre board i.mx6
marcoc
Hello to all,
I need to have the timestamp of the boot up  of Android on my i.mx6 but in minicom I could not d it.
Have you any idea for solve this problem?
Marco
Labels (2)
leige-b42127
Senior Contributor II
make menuconfig
Kernel hacking -> Show timing information on printks
marcoc
This is already enabled.
Thanks Marco
LeonardoSandova
Specialist I
Not sure how this is done in Android but I assume it should be as in Linux, adding the CONFIG_PRINTK_TIME=y configuration. There is also a host app which timestamps every line coming into the serial, it is called grabserial.
Leo
marcoc
I tried to install grabserial but doesn't work. I have two errors in the first two lines of code, I think there is a problem with <!DOCTIME html> but I dont know which could it be.
Do you know how to solve this problem?
Thanks Marco
LeonardoSandova
Specialist I
Hi Marco, create a new thread for this particular problem, so the title is more specific. weren't printk's timestamps enough information? or you need to have also timestamps on bootloader?
Leo
marcoc
Hi Leo, I don't have any timestamps because minicom doesn't have, and I need also the timestamps on the boot loader.
Marco
Rita_Wang
Hi Marco,
Which board are you using?
Best Regards
Dan
marcoc
A sabre board i.mx6 quad core.
Marco
