I would like to boot the linux-imx kernel (for sabreauto for example) from freescale on the phyflex-imx6-4 board along with imx6q-phyflex-pbab01.dts devicetree.
Do you know if this is possible/easy ? Because this is not as straight forward as changing the device tree the kernel is using to boot.
I don't know in details the diffrence between linux-imx and linux-mainline ? Is there any documentation about it ?
This is because I want to use vpu encoders etc.
Thank you in advance,
Quentin.
