We have a custom board based on i.MX 8M mini processor.
We are trying to boot the board from SPI nor flash(W25Q32JW) that is connected to ECSPI2.
What are the necessary changes that need to be made in U-boot in order to flash and boot from SPI nor flash?
What should be the fuse command in uboot to burn the fuse to boot from SPI nor flash that is connected to ECSPI2?
