Please find bellow the boot log.
v
U-Boot SPL 2024.07-7.0.0-devel+git.3f772959501c (Jul 01 2024 - 18:07:18 +0000)
Training FAILED
DDR configured as single rank
SEC0: RNG instantiated
Normal Boot
WDT: Started watchdog@30280000 with servicing every 1000ms (60s timeout)
Trying to boot from BOOTROM
Boot Stage: Primary boot
Find img info 0x4802f000, size 1068
Need continue download 1024
NOTICE: Do not release JR0 to NS as it can be used by HAB
NOTICE: BL31: v2.10.0 (release):android-14.0.0_2.0.0-rc3-0-g9ce177d6d-dirty
NOTICE: BL31: Built : 10:04:22, May 29 2024
U-Boot 2024.07-7.0.0-devel+git.3f772959501c (Jul 01 2024 - 18:07:18 +0000)
CPU: Freescale i.MX8MP Lite[4] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 61C
Reset cause: POR
DRAM: 1 GiB
Core: 176 devices, 31 uclasses, devicetree: separate
MMC: FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... Reading from MMC(2)... OK
In: serial@30880000
Out: serial@30880000
Err: serial@30880000
Model: Toradex 0065 Verdin iMX8M Plus QuadLite 1GB IT V1.1A
Serial#: 15010544
Carrier: Toradex Verdin Development Board V1.1F, Serial# 11227078
Setting variant to nonwifi
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
Hit any key to stop autoboot: 1 0
MMC: no card present
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1...
Found U-Boot script /boot.scr
6092 bytes read in 1 ms (5.8 MiB/s)
## Executing script at 50280000
Loading DeviceTree: imx8mp-verdin-nonwifi-dev.dtb
87331 bytes read in 3 ms (27.8 MiB/s)
118 bytes read in 1 ms (115.2 KiB/s)
Working FDT set to 50200000
Applying Overlay: verdin-imx8mp_hdmi_overlay.dtbo
2219 bytes read in 2 ms (1.1 MiB/s)
Applying Overlay: verdin-imx8mp_dsi-to-hdmi_overlay.dtbo
4099 bytes read in 2 ms (2 MiB/s)
Applying Overlay: verdin-imx8mp_spidev_overlay.dtbo
561 bytes read in 1 ms (547.9 KiB/s)
8083848 bytes read in 51 ms (151.2 MiB/s)
Bootargs: root=PARTUUID=f833bf75-02 ro rootwait console=tty1 console=ttymxc2
Uncompressing Kernel Image to 0
## Flattened Device Tree blob at 50200000
Booting using the fdt blob at 0x50200000
Loading Device Tree to 000000007ea9e000, end 000000007ead6fff ... OK
Working FDT set to 7ea9e000
Modify /vpu_g1@38300000:status disabled
Modify /vpu_g2@38310000:status disabled
Modify /vpu_vc8000e@38320000:status disabled
Modify /vipsi@38500000:status disabled
Modify /soc@0/bus@32c00000/camera/isp@32e10000:status disabled
Modify /soc@0/bus@32c00000/camera/isp@32e20000:status disabled
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.23-7.0.0-devel-g5545cedda0e3 (oe-user@oe-host) (aarch64-tdx-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240716) #1 SMP PREEMPT Wed Aug 28 13:26:04 UTC 2024
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: Toradex Verdin iMX8M Plus on Verdin Development Board
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000005ea00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000005ea00000..0x000000007e9fffff (524288 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000000900000..0x000000000096ffff (448 KiB) nomap non-reusable ocram@900000
[ 0.000000] OF: reserved mem: 0x0000000100000000..0x000000010fffffff (262144 KiB) nomap non-reusable gpu_reserved@100000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.4
[ 0.000000] percpu: Embedded 20 pages/cpu s42792 r8192 d30936 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: root=PARTUUID=f833bf75-02 ro rootwait console=tty1 console=ttymxc2
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x000000005aa00000-0x000000005ea00000] (64MB)
[ 0.000000] Memory: 417512K/1048576K available (11584K kernel code, 1228K rwdata, 3620K rodata, 2624K init, 467K bss, 106776K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 160 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000545] Console: colour dummy device 80x25
[ 0.000553] printk: console [tty1] enabled
[ 0.001036] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.001058] pid_max: default: 32768 minimum: 301
[ 0.001197] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001222] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.002631] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.002709] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.002893] rcu: Hierarchical SRCU implementation.
[ 0.002905] rcu: Max phase no-delay instances is 1000.
[ 0.003859] EFI services will not be available.
[ 0.004178] smp: Bringing up secondary CPUs ...
[ 0.004615] Detected VIPT I-cache on CPU1
[ 0.004672] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.004708] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005196] Detected VIPT I-cache on CPU2
[ 0.005237] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.005255] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.005708] Detected VIPT I-cache on CPU3
[ 0.005749] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.005766] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.005829] smp: Brought up 1 node, 4 CPUs
[ 0.005910] SMP: Total of 4 processors activated.
[ 0.005924] CPU features: detected: 32-bit EL0 Support
[ 0.005934] CPU features: detected: CRC32 instructions
[ 0.005999] CPU: All CPU(s) started at EL2
[ 0.006009] alternatives: applying system-wide alternatives
[ 0.007118] devtmpfs: initialized
[ 0.018398] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.018442] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.033239] pinctrl core: initialized pinctrl subsystem
[ 0.033775] DMI not present or invalid.
[ 0.034382] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.035189] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.035332] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.035475] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.035974] thermal_sys: Registered thermal governor 'step_wise'
[ 0.035980] thermal_sys: Registered thermal governor 'user_space'
[ 0.035992] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.036059] cpuidle: using governor menu
[ 0.036210] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.036292] ASID allocator initialised with 65536 entries
[ 0.036528] imx mu driver is registered.
[ 0.036558] imx rpmsg driver is registered.
[ 0.045557] platform soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000/unique-id@8
[ 0.048010] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/hdmihoggrp
[ 0.048047] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpiohog3grp
[ 0.048093] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpiohog2grp
[ 0.048124] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpiohog1grp
[ 0.048152] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpio8grp
[ 0.048177] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpio7grp
[ 0.048203] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpio4grp
[ 0.048230] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpio3grp
[ 0.048260] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpio2grp
[ 0.048287] platform 30330000.pinctrl: Fixed dependency cycle(s) with /soc@0/bus@30000000/pinctrl@30330000/gpio1grp
[ 0.048815] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.049629] platform 30350000.efuse: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.050734] platform 30350000.efuse: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.059130] platform 32e60000.mipi_dsi: Fixed dependency cycle(s) with /soc@0/bus@32c00000/lcd-controller@32e80000
[ 0.059192] platform 32e60000.mipi_dsi: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a50000/hdmi@48
[ 0.059417] platform 32e60000.mipi_dsi: Fixed dependency cycle(s) with /soc@0/bus@32c00000/lcd-controller@32e80000
[ 0.059525] platform 32e80000.lcd-controller: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 0.063333] platform 32fc6000.lcd-controller: Fixed dependency cycle(s) with /soc@0/bus@30c00000/hdmi@32fd8000
[ 0.063692] platform 32fc6000.lcd-controller: Fixed dependency cycle(s) with /soc@0/bus@30c00000/hdmi@32fd8000
[ 0.063795] platform 32fd8000.hdmi: Fixed dependency cycle(s) with /soc@0/bus@30c00000/lcd-controller@32fc6000
[ 0.070050] Modules: 27840 pages in range for non-PLT usage
[ 0.070061] Modules: 519360 pages in range for PLT usage
[ 0.070651] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.070681] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.070697] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.070708] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.070722] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.070733] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.070750] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.070762] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.072629] iommu: Default domain type: Translated
[ 0.072648] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.072933] SCSI subsystem initialized
[ 0.073084] usbcore: registered new interface driver usbfs
[ 0.073125] usbcore: registered new interface driver hub
[ 0.073171] usbcore: registered new device driver usb
[ 0.074377] mc: Linux media interface: v0.10
[ 0.074422] videodev: Linux video capture interface: v2.00
[ 0.074484] pps_core: LinuxPPS API ver. 1 registered
[ 0.074496] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.074529] PTP clock support registered
[ 0.075025] Advanced Linux Sound Architecture Driver Initialized.
[ 0.076210] clocksource: Switched to clocksource arch_sys_counter
[ 0.083749] NET: Registered PF_INET protocol family
[ 0.083902] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.084843] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.084874] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.084928] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.085002] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.085224] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.085302] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.085338] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.085452] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.085793] RPC: Registered named UNIX socket transport module.
[ 0.085807] RPC: Registered udp transport module.
[ 0.085817] RPC: Registered tcp transport module.
[ 0.085828] RPC: Registered tcp-with-tls transport module.
[ 0.085841] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.085861] PCI: CLS 0 bytes, default 64
[ 0.086887] Initialise system trusted keyrings
[ 0.087050] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 0.087491] NFS: Registering the id_resolver key type
[ 0.087520] Key type id_resolver registered
[ 0.087531] Key type id_legacy registered
[ 0.087555] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.087571] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.087699] Key type asymmetric registered
[ 0.087712] Asymmetric key parser 'x509' registered
[ 0.087755] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.087776] io scheduler mq-deadline registered
[ 0.087789] io scheduler kyber registered
[ 0.087824] io scheduler bfq registered
[ 0.099117] mxs-dma 33000000.dma-apbh: initialized
[ 0.099748] SoC: i.MX8MP revision 1.1
[ 0.100125] Bus freq driver module loaded
[ 0.107023] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 0.108407] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 0.109779] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 0.159825] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.163811] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 15, base_baud = 1500000) is a IMX
[ 0.164619] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 16, base_baud = 1500000) is a IMX
[ 0.164654] imx-uart 30880000.serial: Console IMX rounded baud rate from 114286 to 114300
[ 0.164694] printk: console [ttymxc2] enabled
[ 1.348962] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 17, base_baud = 1500000) is a IMX
[ 1.368123] usbcore: registered new interface driver usb-storage
[ 1.374977] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc1
[ 1.381369] i2c_dev: i2c /dev entries driver
[ 1.389442] sdhci: Secure Digital Host Controller Interface driver
[ 1.395660] sdhci: Copyright(c) Pierre Ossman
[ 1.400326] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.406899] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.413874] usbcore: registered new interface driver usbhid
[ 1.419481] usbhid: USB HID core driver
[ 1.425099] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.435005] platform soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000
[ 1.446181] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.449206] NET: Registered PF_PACKET protocol family
[ 1.458396] Key type dns_resolver registered
[ 1.469929] Loading compiled-in X.509 certificates
[ 1.495815] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.506706] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.517491] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.523356] mmc2: new HS400 MMC card at address 0001
[ 1.527886] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.532291] mmcblk2: mmc2:0001 Q2J55L 7.09 GiB
[ 1.542074] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.547208] mmcblk2: p1 p2
[ 1.555849] reg-fixed-voltage regulator-force-sleep-moci: nonexclusive access to GPIO for (null)
[ 1.557269] i2c i2c-0: using pinctrl states for GPIO recovery
[ 1.571434] mmcblk2boot0: mmc2:0001 Q2J55L 16.0 MiB
[ 1.577331] mmcblk2boot1: mmc2:0001 Q2J55L 16.0 MiB
[ 1.583748] mmcblk2rpmb: mmc2:0001 Q2J55L 4.00 MiB, chardev (241:0)
[ 1.589986] rtc-ds1307 0-0032: registered as rtc0
[ 1.596323] rtc-ds1307 0-0032: setting system clock to 2024-09-13T10:37:10 UTC (1726223830)
[ 1.604741] nxp-pca9450 0-0025: pca9450bc probed.
[ 1.605258] at24 0-0050: supply vcc not found, using dummy regulator
[ 1.618161] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 1.624952] i2c i2c-0: IMX I2C adapter registered
[ 1.630808] i2c i2c-1: using pinctrl states for GPIO recovery
[ 1.636621] i2c i2c-1: IMX I2C adapter registered
[ 1.641990] i2c i2c-2: using pinctrl states for GPIO recovery
[ 1.647785] i2c i2c-2: IMX I2C adapter registered
[ 1.653439] i2c i2c-3: using pinctrl states for GPIO recovery
[ 1.659635] platform 32e60000.mipi_dsi: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a50000/hdmi@48
[ 1.669820] platform hdmi-connector: Fixed dependency cycle(s) with /soc@0/bus@30800000/i2c@30a50000/hdmi@48
[ 1.679788] i2c 3-0048: Fixed dependency cycle(s) with /soc@0/bus@32c00000/mipi_dsi@32e60000
[ 1.688299] i2c 3-0048: Fixed dependency cycle(s) with /hdmi-connector
[ 1.695330] at24 3-0050: supply vcc not found, using dummy regulator
[ 1.730750] at24 3-0057: supply vcc not found, using dummy regulator
[ 1.738560] at24 3-0057: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[ 1.745514] i2c i2c-3: IMX I2C adapter registered
[ 1.761056] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.768024] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.774850] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.781280] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 7 mkt segment 2 supported-hw 0x80 0x4
[ 1.793264] sdhci-esdhc-imx 30b50000.mmc: Got CD GPIO
[ 1.794221] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.805297] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.812129] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.820252] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.827066] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.833853] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.834190] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 1.842023] clk: Disabling unused clocks
[ 1.848084] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.869645] ALSA device list:
[ 1.870853] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 1.876192] No soundcards found.
[ 1.879395] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 2.002103] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 2.007110] EXT4-fs (mmcblk2p2): INFO: recovery required on readonly filesystem
[ 2.009096] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 2.015089] EXT4-fs (mmcblk2p2): write access will be enabled during recovery
[ 2.021929] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 2.034594] imx-dwmac 30bf0000.ethernet: IRQ eth_lpi not found
[ 2.041448] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[ 2.048302] imx-dwmac 30bf0000.ethernet: DWMAC4/5
[ 2.053134] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[ 2.060318] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[ 2.067488] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[ 2.073667] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 2.081345] imx-dwmac 30bf0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[ 2.088148] imx-dwmac 30bf0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 2.094954] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[ 2.102540] imx-dwmac 30bf0000.ethernet: Using 34/40 bits DMA host/device width
[ 2.115739] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 2.122543] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 2.129335] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 2.935121] EXT4-fs (mmcblk2p2): recovery complete
[ 2.941644] EXT4-fs (mmcblk2p2): mounted filesystem 33d98045-0cb0-4def-8c8d-909bd06d81d9 ro with ordered data mode. Quota mode: disabled.
[ 2.954070] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.961499] devtmpfs: mounted
[ 2.965119] Freeing unused kernel memory: 2624K
[ 2.969746] Run /sbin/init as init process
[ 3.140034] systemd[1]: Inserted module 'autofs4'
[ 3.170078] NET: Registered PF_INET6 protocol family
[ 3.177545] Segment Routing with IPv6
[ 3.181288] In-situ OAM (IOAM) with IPv6
[ 3.211527] systemd[1]: systemd 255.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 3.243573] systemd[1]: Detected architecture arm64.
Welcome to TDX Wayland with XWayland 7.0.0-devel-202409+build.2 (scarthgap)!
[ 3.265474] systemd[1]: No hostname configured, using default hostname.
[ 3.272331] systemd[1]: Hostname set to <localhost>.
[ 3.651773] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.683282] systemd[1]: Created slice Slice /system/getty.
[ OK ] Created slice Slice /system/getty.
[ 3.705998] systemd[1]: Created slice Slice /system/modprobe.
[ OK ] Created slice Slice /system/modprobe.
[ 3.729996] systemd[1]: Created slice Slice /system/serial-getty.
[ OK ] Created slice Slice /system/serial-getty.
[ 3.753503] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.776909] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 3.804878] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 3.828364] systemd[1]: Expecting device /dev/ttymxc2...
[ 3.849016] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ 3.872647] systemd[1]: Reached target Path Units.
[ OK ] Reached target Path Units.
[ 3.892360] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.912351] systemd[1]: Reached target Slice Units.
[ OK ] Reached target Slice Units.
[ 3.932375] systemd[1]: Reached target Swaps.
[ OK ] Reached target Swaps.
[ 3.980862] systemd[1]: Listening on RPCbind Server Activation Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ 4.009052] systemd[1]: Reached target RPC Port Mapper.
[ OK ] Reached target RPC Port Mapper.
[ 4.022522] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.040677] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ 4.071319] systemd[1]: Journal Audit Socket was skipped because of an unmet condition check (ConditionSecurity=audit).
[ 4.082823] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.104942] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.125093] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.149864] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.162845] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.185213] systemd[1]: Listening on User Database Manager Socket.
[ OK ] Listening on User Database Manager Socket.
[ 4.229059] systemd[1]: Mounting Huge Pages File System...
[ 4.238561] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.271949] systemd[1]: Mounting Kernel Debug File System...
[ 4.292615] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[ 4.309060] systemd[1]: Mounting Temporary Directory /tmp...
[ 4.350573] systemd[1]: Starting Create List of Static Device Nodes...
[ 4.375687] systemd[1]: Starting Load Kernel Module configfs...
[ 4.404069] systemd[1]: Starting Load Kernel Module drm...
[ 4.432477] systemd[1]: Starting Load Kernel Module fuse...
[ 4.455762] systemd[1]: Starting RPC Bind...
[ 4.469913] fuse: init (API version 7.39)
[ 4.479297] systemd[1]: Starting File System Check on Root Device...
[ 4.510059] systemd[1]: Starting Journal Service...
[ 4.533269] systemd[1]: Starting Load Kernel Modules...
[ 4.543283] systemd[1]: Starting Generate network units from Kernel command line...
Starting Generate network units from Kernel co[ 4.555627] systemd[1]: Starting Coldplug All udev Devices...
mmand line...
[ 4.568901] systemd[1]: Started RPC Bind.
[ OK ] Started 4.575637] systemd[1]: Mounted Huge Pages File System.
;39mRPC Bind.
[ 4.583950] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted 4.591637] systemd[1]: Mounted Kernel Debug File System.
;39mHuge Pages File System.[ 4.599781] systemd[1]: Mounted Temporary Directory /tmp.
[ OK ] Mounted 4.608537] systemd[1]: Finished Create List of Static Device Nodes.
1;39mPOSIX Message Queue File Sys[ 4.617888] systemd[1]: modprobe@configfs.service: Deactivated successfully.
tem.
[ OK ] Mo[ 4.627262] systemd[1]: Finished Load Kernel Module configfs.
unted Kernel Debug File [ 4.636788] systemd[1]: modprobe@drm.service: Deactivated successfully.
System.
[ OK ][ 4.645924] systemd[1]: Finished Load Kernel Module drm.
Mounted Temporary Direc[ 4.654212] systemd[1]: modprobe@fuse.service: Deactivated successfully.
tory /tmp.
[ OK 4.663262] systemd[1]: Finished Load Kernel Module fuse.
0m] Finished Create List[ 4.672083] systemd[1]: Finished Generate network units from Kernel command line.
[ OK ] Finished Load Kernel Module configf[ 4.686721] galcore: loading out-of-tree module taints kernel.
s.
[ OK ] Finished Load Kernel Modul[ 4.698540] systemd-journald[111]: Collecting audit messages is disabled.
e drm.
[ OK ] [ 4.699695] module built by at Mon Sep 2 19:19:54 UTC 2024
Finished Load Kernel Mod[ 4.700980] imx-pgc imx-pgc-domain.8: failed to command PGC
ule fuse.
[ OK 4.705626] imx-pgc imx-pgc-domain.8: failed to command PGC
m] Finished Generate net[ 4.706952] imx-pgc imx-pgc-domain.8: failed to command PGC
work units from Kernel command li[ 4.742852] Galcore version 6.4.11.p2.745085
ne.
[ 4.756853] systemd[1]: Mounting FUSE Control File System...
[ 4.759870] [drm] Initialized vivante 1.0.0 20170808 for 40000000.mix_gpu_ml on minor 0
Mounting FUSE C[ 4.772720] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 4.782320] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 4.789495] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 4.820625] systemd[1]: Mounting Kernel Configuration File System...
[ 4.846931] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[ 4.874428] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Finished File System Check on Root Device.
[ OK ] Finished Load Kernel Modules.
[ OK ] Mounted FUSE Control File System.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Finished Create Static Device Nodes in /dev gracefully.
Starting Remount Root and Kernel File Systems...
Starting Apply Kernel Variables...
[ 5.057977] EXT4-fs (mmcblk2p2): re-mounted 33d98045-0cb0-4def-8c8d-909bd06d81d9 r/w. Quota mode: disabled.
[ OK ] Finished Remount Root and Kernel File Systems.
[ OK ] Finished Apply Kernel Variables.
Starting Flush Journal to Persistent Storage...
[ 5.146061] systemd-journald[111]: Received client request to flush runtime journal.
Starting Create Static Device Nodes in /dev...
[ OK ] Finished Flush Journal to Persistent Storage.
[ OK ] Finished Create Static Device Nodes in /dev.
[ OK ] Reached target Preparation for Local File Systems.
Mounting /var/volatile...
Starting Rule-based Manager for Device Events and Files...
[ OK ] Mounted /var/volatile.
Starting Load/Save OS Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Finished Coldplug All udev Devices.
[ OK ] Started Rule-based Manager for Device Events and Files.
[ OK ] Finished Create Volatile Files and Directories.
Starting Network Time Synchronization...
[ 5.562096] imx-dwmac 30bf0000.ethernet end0: renamed from eth0
Starting Record System Boot/Shutdown in UTMP...
[ OK ] Found device /dev/ttymxc2.
[ OK ] Finished Record System Boot/Shutdown in UTMP.
[ 6.114153] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 6.139038] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.165560] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.185740] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.187129] Hot alarm is canceled. GPU3D clock will return to 64/64
[ 6.206467] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.224962] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input1
[ 6.242186] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.279811] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.290120] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.306720] caam 30900000.crypto: device ID = 0x0a16040100000100 (Era 9)
[ 6.308240] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.327658] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.330422] caam 30900000.crypto: job rings = 2, qi = 0
[ 6.340084] CAN device driver interface
[ 6.355167] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.365907] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 6.375771] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.383060] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.386094] lm75 0-0048: hwmon2: sensor 'tmp1075'
[ 6.398171] hwmon hwmon3: temp1_input not attached to any thermal zone
[ 6.398365] pca953x 3-0021: using no AI
[ 6.398941] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.402314] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.403909] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.405336] lm75 3-004f: hwmon3: sensor 'tmp75c'
[ 6.420098] ina2xx 3-0040: supply vs not found, using dummy regulator
[ 6.435425] lt8912 3-0048: supply vccmipirx not found, using dummy regulator
[ 6.436046] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.437480] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.437770] ina2xx 3-0040: power monitor ina219 (Rshunt = 10000 uOhm)
[ 6.449253] lt8912 3-0048: supply vccsysclk not found, using dummy regulator
[ 6.468339] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.477192] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.486060] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.489201] fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
[ 6.491763] lt8912 3-0048: supply vcclvdstx not found, using dummy regulator
[ 6.506189] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.514008] imx-sdma 30bd0000.dma-controller: firmware found.
[ 6.517115] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.532366] lt8912 3-0048: supply vcchdmitx not found, using dummy regulator
[ 6.534767] imx-sdma 30bd0000.dma-controller: loaded firmware 4.5
[ 6.546942] imx-bus-devfreq 32700000.interconnect: failed to fetch clk: -2
[ 6.554830] lt8912 3-0048: supply vcclvdspll not found, using dummy regulator
[ 6.554924] imx-bus-devfreq: probe of 32700000.interconnect failed with error -2
[ 6.570442] imx-sdma 30e00000.dma-controller: firmware found.
[ 6.576427] fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
[ 6.585743] imx-sdma 30e10000.dma-controller: firmware found.
[ 6.586465] lt8912 3-0048: supply vcchdmipll not found, using dummy regulator
[ 6.606820] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.624781] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 6.635193] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 6.648833] dwhdmi-imx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with HDCP (samsung_dw_hdmi_phy2)
[ 6.663783] dwhdmi-imx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driver
[ 6.690872] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops 0xffffffc080c14b50)
[ 6.703649] imx-drm display-subsystem: bound imx-lcdifv3-crtc.1 (ops 0xffffffc080c14b50)
[ 6.733659] imx_sec_dsim_drv 32e60000.mipi_dsi: version number is 0x1060200
[ 6.745795] imx_sec_dsim_drv 32e60000.mipi_dsi: [drm] *ERROR* modalias failure on /soc@0/bus@32c00000/mipi_dsi@32e60000/port@1
[ 6.796461] imx-drm display-subsystem: bound 32e60000.mipi_dsi (ops imx_sec_dsim_driver_exit [sec_mipi_dsim_imx])
[ 6.816330] imx-drm display-subsystem: bound 32fd8000.hdmi (ops 0xffffffc080c14108)
[ 6.832706] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 1
[ 6.879991] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 6.885652] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 6.893860] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x000000a001000010
[ 6.895143] caam algorithms registered in /proc/crypto
[ 6.903566] xhci-hcd xhci-hcd.1.auto: irq 223, io mem 0x38200000
[ 6.914736] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 6.920286] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2
[ 6.928029] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 6.931886] caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto
[ 6.934761] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 6.950369] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.957655] usb usb1: Product: xHCI Host Controller
[ 6.957696] caam 30900000.crypto: rng crypto API alg registered prng-caam
[ 6.962568] usb usb1: Manufacturer: Linux 6.6.23-7.0.0-devel-g5545cedda0e3 xhci-hcd
[ 6.977083] usb usb1: SerialNumber: xhci-hcd.1.auto
[ 6.982292] caam 30900000.crypto: registering rng-caam
[ 6.982567] hub 1-0:1.0: USB hub found
[ 6.991374] hub 1-0:1.0: 1 port detected
[ 6.997619] Device caam-keygen registered
[ 7.021078] random: crng init done
[ OK ] Finished Load/Save OS Random Seed.
[ 7.157156] Console: switching to colour frame buffer device 240x67
[ 7.179899] imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
[ 7.200843] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 7.209151] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 7.217526] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ OK ] Created slice[ 7.224835] usb usb2: Product: xHCI Host Controller
Slice /system/systemd-f[ 7.232654] usb usb2: Manufacturer: Linux 6.6.23-7.0.0-devel-g5545cedda0e3 xhci-hcd
sck.
[ 7.243187] usb usb2: SerialNumber: xhci-hcd.1.auto
[ 7.249374] hub 2-0:1.0: USB hub found
[ 7.253222] hub 2-0:1.0: 1 port detected
Starting File System Check on /dev/mmcblk2p1...
Starting User Database Manager...
Starting Virtual Console Setup...
Starting Network Name Resolution...
[ OK ] Finished File System Check on /dev/mmcblk2p1.
[ 7.409081] pps pps0: new PPS source ptp0
Mounting /run/media/BOOT-mmcblk2p1...
[ 7.424015] fec 30be0000.ethernet eth0: registered PHC device 0
[ 7.434773] fec 30be0000.ethernet end1: renamed from eth0
[ 7.436702] imx6q-pcie 33800000.pcie: host bridge /soc@0/pcie@33800000 ranges:
[ 7.449098] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 7.449328] imx6q-pcie 33800000.pcie: IO 0x001ff80000..0x001ff8ffff -> 0x0000000000
[ 7.463150] imx6q-pcie 33800000.pcie: MEM 0x0018000000..0x001fefffff -> 0x0018000000
[ OK ] Started 7.473276] input: audio-hdmi HDMI Jack as /devices/platform/sound-hdmi/sound/card0/input2
;39mUser Database Manager.
[ 7.483513] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 7.485534] imx-pgc imx-pgc-domain.8: failed to command PGC
[ OK ] Finished Virtual Console Setup.
[ 7.631961] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 7.639316] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 7.641198] usb 1-1: New USB device found, idVendor=0424, idProduct=2744, bcdDevice= 2.21
[ 7.646452] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 7.653162] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.653180] usb 1-1: Product: USB2744
[ 7.669959] usb 1-1: Manufacturer: Microchip Tech
[ OK ] Started Network Name Resolution.
[ 7.692383] imx6q-pcie 33800000.pcie: iATU: unroll T, 4 ob, 4 ib, align 64K, limit 16G
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Set.
[ OK ] Reached targe[ 7.735635] hub 1-1:1.0: USB hub found
t System Initialization 7.741999] hub 1-1:1.0: 4 ports detected
[0m.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timer Units.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 7.799120] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ OK ] Listening on [ 7.809808] imx-pgc imx-pgc-domain.8: failed to command PGC
D-Bus System Message Bus[ 7.819600] imx-pgc imx-pgc-domain.8: failed to command PGC
Socket.
[ 7.827708] usb 2-1: New USB device found, idVendor=0424, idProduct=5744, bcdDevice= 2.21
[ 7.827980] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 7.835916] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 7.835928] usb 2-1: Product: USB5744
[ 7.835933] usb 2-1: Manufacturer: Microchip Tech
[ 7.863396] hub 2-1:1.0: USB hub found
[ 7.867657] hub 2-1:1.0: 3 ports detected
[ 7.872738] usbcore: registered new device driver onboard-usb-hub
[ 7.873647] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 7.886163] imx-pgc imx-pgc-domain.8: failed to command PGC
[ OK ] Listening on [ 7.896168] imx-pgc imx-pgc-domain.8: failed to command PGC
dropbear.socket.
[ OK ] Listening on GPS (Global Positioning System) Daemon Sockets.
Starting Weston socket...
[ OK ] Listening on Weston socket.
[ OK ] Reached target Socket Units.
[ OK ] Reached target Basic System.
Starting Save/Restore Sound Card State...
[ OK ] Started Kernel Logging Service.
[ OK ] Started System Logging Service.
[ 8.119084] hub 1-1:1.0: USB hub found
[ 8.126820] hub 1-1:1.0: 4 ports detected
Starting D-Bus System Message Bus...
[ OK ] Started ISP i.MX 8Mplus daemon.
Starting IPv6 Packet Filtering Framework...
[ 8.184651] imx-pgc imx-pgc-domain.8: failed to command PGC
Starting IPv4 P[ 8.195392] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 8.206665] imx-pgc imx-pgc-domain.8: failed to command PGC
Starting Telephony service...
Starting set-hostname.service...
Starting User Login Management...
[ OK ] Started Timestamping service.
Starting Load USB gadget schemas...
[ 8.316139] hub 1-1:1.0: USB hub found
[ OK ] Started 8.328421] hub 1-1:1.0: 4 ports detected
;39mD-Bus System Message Bus.
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Finished IPv6 Packet Filtering Framework.
[ 8.376847] imx-pgc imx-pgc-domain.8: failed to command PGC
[ OK ] Finished 8.387708] imx-pgc imx-pgc-domain.8: failed to command PGC
1;39mIPv4 Packet Filtering Framework.
[ 8.396828] configfs-gadget.g1 gadget.0: HOST MAC 2e:21:0b:81:9e:7b
[ 8.398311] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 8.404129] configfs-gadget.g1 gadget.0: MAC 6e:5b:83:16:de:be
[ 8.425483] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 8.435402] imx-pgc imx-pgc-domain.8: failed to command PGC
[ OK ] Finished 8.445078] imx-pgc imx-pgc-domain.8: failed to command PGC
1;39mLoad USB gadget schemas.[ 8.455005] hub 2-1:1.0: USB hub found
[ 8.461554] hub 2-1:1.0: 3 ports detected
[ 8.464214] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 8.478050] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 8.479540] imx-pgc imx-pgc-domain.8: failed to command PGC
[ OK ] Started User Login Management.
[ 8.535009] hub 2-1:1.0: USB hub found
[ 8.542115] hub 2-1:1.0: 3 ports detected
[ OK ] Started 8.550614] imx-pgc imx-pgc-domain.8: failed to command PGC
;39mTelephony service.
[ 8.561661] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 8.571031] imx-pgc imx-pgc-domain.8: failed to command PGC
[ OK ] Reached target Sound Card.
[ OK ] Reached target Hardware activated USB gadget.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 8.660281] usb 1-1.4: new high-speed USB device number 3 using xhci-hcd
Starting Hostname Service...
[ 8.700567] imx6q-pcie 33800000.pcie: Phy link never came up
[ 8.771542] usb 1-1.4: New USB device found, idVendor=0424, idProduct=2740, bcdDevice= 2.00
[ 8.782291] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.791961] usb 1-1.4: Product: Hub Controller
[ 8.798723] usb 1-1.4: Manufacturer: Microchip Tech
[ 8.807858] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 8.817406] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 8.826766] imx-pgc imx-pgc-domain.8: failed to command PGC
[ OK ] Started Hostname Service.
[ OK ] Finished set-hostname.service.
[ OK ] Reached target Preparation for Network.
Starting Connection service...
Starting Network Configuration...
[ OK ] Started Connection service.
[ 9.059147] imx-dwmac 30bf0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
Starting Avahi [ 9.069614] imx-dwmac 30bf0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-1
mDNS/DNS-SD Stack...
[ 9.082378] imx-dwmac 30bf0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-2
[ 9.092459] imx-dwmac 30bf0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-3
[ 9.102456] imx-dwmac 30bf0000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-4
Starting WPA supplicant...
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ 9.181812] imx-dwmac 30bf0000.ethernet end0: PHY [stmmac-0:07] driver [Microchip KSZ9131 Gigabit PHY] (irq=36)
[ OK ] Started WPA supplicant.
[ 9.204233] imx-dwmac 30bf0000.ethernet end0: No Safety Features support found
[ 9.214391] imx-dwmac 30bf0000.ethernet end0: IEEE 1588-2008 Advanced Timestamp supported
[ 9.225673] imx-dwmac 30bf0000.ethernet end0: registered PTP clock
[ 9.235531] imx-dwmac 30bf0000.ethernet end0: FPE workqueue start
[ 9.243861] imx-dwmac 30bf0000.ethernet end0: configuring for phy/rgmii-id link mode
[ 9.258464] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.278894] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.288779] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 9.324085] Microchip KSZ9131 Gigabit PHY 30be0000.ethernet-1:07: attached PHY driver (mii_bus:phy_addr=30be0000.ethernet-1:07, irq=146)
[ 9.714088] imx6q-pcie 33800000.pcie: Phy link never came up
[ 9.723191] imx6q-pcie 33800000.pcie: PCI host bridge to bus 0000:00
[ 9.732573] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 9.741083] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 9.750243] pci_bus 0000:00: root bus resource [mem 0x18000000-0x1fefffff]
[ 9.760079] pci 0000:00:00.0: [16c3:abcd] type 01 class 0x060400
[ 9.769084] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x000fffff]
[ 9.777674] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 9.786572] pci 0000:00:00.0: supports D1
[ 9.792708] pci 0000:00:00.0: PME# supported from D0 D1 D3hot D3cold
[ 9.803821] pci 0000:00:00.0: BAR 0: assigned [mem 0x18000000-0x180fffff]
[ 9.812855] pci 0000:00:00.0: BAR 6: assigned [mem 0x18100000-0x1810ffff pref]
[ 9.822263] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 9.830074] pcieport 0000:00:00.0: PME: Signaling with IRQ 231
[ 9.838506] pcieport 0000:00:00.0: AER: enabled with IRQ 231
[ 9.839385] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 9.858927] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 9.868353] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 9.877874] imx-pgc imx-pgc-domain.8: failed to command PGC
[ 9.894563] Bluetooth: Core ver 2.22
[ OK ] Started 9.906248] NET: Registered PF_BLUETOOTH protocol family
;39mNetwork Configuration.
[ 9.918967] Bluetooth: HCI device and connection manager initialized
[ 9.927721] Bluetooth: HCI socket layer initialized
[ 9.934864] Bluetooth: L2CAP socket layer initialized
[ OK ] Mounted 9.942186] Bluetooth: SCO socket layer initialized
;39m/run/media/BOOT-mmcblk2p1.
[ OK ] Reached target Network.
Mounting /boot...
Starting Permit User Sessions...
[ OK ] Mounted /boot.
[ OK ] Finished Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttymxc2.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
Starting Weston, a Wayland compositor, as a system service...
[ OK ] Created slice User Slice of UID 0.
Starting User Runtime Directory /run/user/0...
[ OK ] Finished User Runtime Directory /run/user/0.
Starting User Manager for UID 0...
[ OK ] Started User Manager for UID 0.
[ OK ] Started Session c1 of User root.
[ OK ] Started Session c2 of User root.
[ OK ] Started Session c3 of User root.
[ 12.303880] Unable to handle kernel paging request at virtual address deaddead00000010
[ 12.311858] Mem abort info:
[ 12.314674] ESR = 0x0000000096000004
[ 12.318446] EC = 0x25: DABT (current EL), IL = 32 bits
[ 12.323777] SET = 0, FnV = 0
[ 12.326851] EA = 0, S1PTW = 0
[ 12.330009] FSC = 0x04: level 0 translation fault
[ 12.334904] Data abort info:
[ 12.337801] ISV = 0, ISS = 0x00000004, ISS2 = 0x00000000
[ 12.343304] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[ 12.348373] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[ 12.353702] [deaddead00000010] address between user and kernel address ranges
[ 12.360855] Internal error: Oops: 0000000096000004 [#1] PREEMPT SMP
[ 12.367125] Modules linked in: bluetooth ecdh_generic nls_iso8859_1 ecc cfg80211 rfkill onboard_usb_hub spidev nls_cp437 usb_conn_gpio snd_soc_hdmi_codec dw_hdmi_gp_audio dw_hdmi_cec dwc3 roles caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes crypto_null evdev aes_ce_cipher ghash_ce gf128mul libaes sha2_ce sha256_arm64 sha1_ce sha1_generic fsl_imx8_ddr_perf snd_soc_simple_card phy_fsl_imx8mq_usb snd_soc_simple_card_utils snd_soc_imx_hdmi phy_fsl_imx8m_pcie sec_mipi_dsim_imx sec_dsim dwc3_imx8mp imx_bus phy_fsl_samsung_hdmi snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma snd_soc_fsl_aud2htx imx_sdma snd_soc_nau8822 ti_ads1015 ina2xx lontium_lt8912b gpio_pca953x flexcan industrialio_triggered_buffer lm75 kfifo_buf spi_nxp_fspi can_dev caam error pwm_imx27 snvs_pwrkey nvmem_snvs_lpgpr spi_imx imx8mm_thermal display_connector gpio_keys galcore(O) fuse ipv6 autofs4
[ 12.446071] CPU: 1 PID: 478 Comm: weston Tainted: G O 6.6.23-7.0.0-devel-g5545cedda0e3 #1
[ 12.455640] Hardware name: Toradex Verdin iMX8M Plus on Verdin Development Board (DT)
[ 12.463471] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 12.470434] pc : __lookup_mnt+0x40/0x60
[ 12.474278] lr : step_into+0xcc/0x60c
[ 12.477944] sp : ffffffc083853a70
[ 12.481258] x29: ffffffc083853a90 x28: ffffffc083853c60 x27: 0000000000000000
[ 12.488399] x26: 2f2f2f2f2f2f2f2f x25: 0000000000000002 x24: ffffffc0811985c0
[ 12.495540] x23: 0000000000000002 x22: 0000000000210000 x21: ffffff8000460240
[ 12.502685] x20: ffffff8000460240 x19: ffffffc083853c60 x18: 0000000000000000
[ 12.509826] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 12.516966] x14: 0000000000000000 x13: ffffff80001e8021 x12: ffffffc083853ca4
[ 12.524107] x11: 00000003b7a97b7e x10: 0000000000000002 x9 : 0000000000000003
[ 12.531247] x8 : ffffff8000454b40 x7 : 732e646c2f637465 x6 : 00000000000007ff
[ 12.538388] x5 : ffffff8000054000 x4 : 000000000000000b x3 : ffffff80000897e0
[ 12.545529] x2 : 0000ffffff800027 x1 : ffffff8000460240 x0 : deaddead00000000
[ 12.552676] Call trace:
[ 12.555122] __lookup_mnt+0x40/0x60
[ 12.558613] walk_component+0x4c/0x190
[ 12.562366] link_path_walk.part.0.constprop.0+0x25c/0x384
[ 12.567854] path_openat+0xa8/0xdc4
[ 12.571346] do_filp_open+0x9c/0x14c
[ 12.574924] do_sys_openat2+0xc4/0x104
[ 12.578676] __arm64_sys_openat+0x64/0xac
[ 12.582687] invoke_syscall.constprop.0+0x50/0xe8
[ 12.587396] do_el0_svc+0x40/0xc8
[ 12.590714] el0_svc+0x48/0x148
[ 12.593857] el0t_64_sync_handler+0x120/0x12c
[ 12.598215] el0t_64_sync+0x190/0x194
[ 12.601882] Code: b5000080 1400000a f9400000 b4000100 (f9400802)
[ 12.607979] ---[ end trace 0000000000000000 ]---
[ 12.669035] imx-dwmac 30bf0000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.678304] Unable to handle kernel paging request at virtual address 000000000801022f
[ 12.686267] Mem abort info:
[ 12.689081] ESR = 0x0000000096000005
[ 12.692849] EC = 0x25: DABT (current EL), IL = 32 bits
[ 12.698173] SET = 0, FnV = 0
[ 12.701235] EA = 0, S1PTW = 0
[ 12.704384] FSC = 0x05: level 1 translation fault
[ 12.709273] Data abort info:
[ 12.712152] ISV = 0, ISS = 0x00000005, ISS2 = 0x00000000
[ 12.717645] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[ 12.722705] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[ 12.728025] user pgtable: 4k pages, 39-bit VAs, pgdp=0000000043aeb000
[ 12.734476] [000000000801022f] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
[ 12.743194] Internal error: Oops: 0000000096000005 [#2] PREEMPT SMP
[ 12.749463] Modules linked in: bluetooth ecdh_generic nls_iso8859_1 ecc cfg80211 rfkill onboard_usb_hub spidev nls_cp437 usb_conn_gpio snd_soc_hdmi_codec dw_hdmi_gp_audio dw_hdmi_cec dwc3 roles caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes crypto_null evdev aes_ce_cipher ghash_ce gf128mul libaes sha2_ce sha256_arm64 sha1_ce sha1_generic fsl_imx8_ddr_perf snd_soc_simple_card phy_fsl_imx8mq_usb snd_soc_simple_card_utils snd_soc_imx_hdmi phy_fsl_imx8m_pcie sec_mipi_dsim_imx sec_dsim dwc3_imx8mp imx_bus phy_fsl_samsung_hdmi snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma snd_soc_fsl_aud2htx imx_sdma snd_soc_nau8822 ti_ads1015 ina2xx lontium_lt8912b gpio_pca953x flexcan industrialio_triggered_buffer lm75 kfifo_buf spi_nxp_fspi can_dev caam error pwm_imx27 snvs_pwrkey nvmem_snvs_lpgpr spi_imx imx8mm_thermal display_connector gpio_keys galcore(O) fuse ipv6 autofs4
[ 12.828412] CPU: 3 PID: 483 Comm: kworker/u8:2 Tainted: G D O 6.6.23-7.0.0-devel-g5545cedda0e3 #1
[ 12.838502] Hardware name: Toradex Verdin iMX8M Plus on Verdin Development Board (DT)
[ 12.846331] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 12.853294] pc : __lookup_mnt+0x40/0x60
[ 12.857138] lr : step_into+0xcc/0x60c
[ 12.860804] sp : ffffffc0838bba80
[ 12.864117] x29: ffffffc0838bbaa0 x28: ffffffc0838bbc70 x27: 0000000000000000
[ 12.871259] x26: 2f2f2f2f2f2f2f2f x25: 0000000000000002 x24: ffffffc0811985c0
[ 12.878402] x23: 0000000000000002 x22: 0000000000210000 x21: ffffff8000454cc0
[ 12.885543] x20: ffffff8000454cc0 x19: ffffffc0838bbc70 x18: 0000000000000000
[ 12.892685] x17: 0000000000000000 x16: ffffffc080c952f8 x15: ffffffffffffffff
[ 12.899826] x14: 0000000000000000 x13: ffffff80015e11a0 x12: ffffffc0838bbcb4
[ 12.906967] x11: 000000037f871908 x10: 0000000000000002 x9 : 0000000000000003
[ 12.914107] x8 : ffffff8000454b40 x7 : 6e6962732f727375 x6 : 00000000000007ff
[ 12.921248] x5 : ffffff8000054000 x4 : 000000000000000b x3 : ffffff80000897e0
[ 12.928389] x2 : 0000ffffff800026 x1 : ffffff8000454cc0 x0 : 000000000801021f
[ 12.935530] Call trace:
[ 12.937976] __lookup_mnt+0x40/0x60
[ 12.941467] walk_component+0x4c/0x190
[ 12.945220] link_path_walk.part.0.constprop.0+0x25c/0x384
[ 12.950709] path_openat+0xa8/0xdc4
[ 12.954202] do_filp_open+0x9c/0x14c
[ 12.957781] do_open_execat+0x60/0x148
[ 12.961531] bprm_execve+0x118/0x524
[ 12.965108] kernel_execve+0x12c/0x1b0
[ 12.968858] call_usermodehelper_exec_async+0xd0/0x140
[ 12.973999] ret_from_fork+0x10/0x20
[ 12.977581] Code: b5000080 1400000a f9400000 b4000100 (f9400802)
[ 12.983677] ---[ end trace 0000000000000000 ]---
[ 12.989178] Unable to handle kernel paging request at virtual address 000000000801022f
[ 12.997139] Mem abort info:
[ 12.999937] ESR = 0x0000000096000005
[ 13.003728] EC = 0x25: DABT (current EL), IL = 32 bits
[ 13.009076] SET = 0, FnV = 0
[ 13.012133] EA = 0, S1PTW = 0
[ 13.015286] FSC = 0x05: level 1 translation fault
[ 13.020172] Data abort info:
[ 13.023060] ISV = 0, ISS = 0x00000005, ISS2 = 0x00000000
[ 13.028553] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[ 13.033613] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[ 13.038934] user pgtable: 4k pages, 39-bit VAs, pgdp=0000000043aeb000
[ 13.045383] [000000000801022f] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000
[ 13.054098] Internal error: Oops: 0000000096000005 [#3] PREEMPT SMP
[ 13.060366] Modules linked in: bluetooth ecdh_generic nls_iso8859_1 ecc cfg80211 rfkill onboard_usb_hub spidev nls_cp437 usb_conn_gpio snd_soc_hdmi_codec dw_hdmi_gp_audio dw_hdmi_cec dwc3 roles caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes crypto_null evdev aes_ce_cipher ghash_ce gf128mul libaes sha2_ce sha256_arm64 sha1_ce sha1_generic fsl_imx8_ddr_perf snd_soc_simple_card phy_fsl_imx8mq_usb snd_soc_simple_card_utils snd_soc_imx_hdmi phy_fsl_imx8m_pcie sec_mipi_dsim_imx sec_dsim dwc3_imx8mp imx_bus phy_fsl_samsung_hdmi snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma snd_soc_fsl_aud2htx imx_sdma snd_soc_nau8822 ti_ads1015 ina2xx lontium_lt8912b gpio_pca953x flexcan industrialio_triggered_buffer lm75 kfifo_buf spi_nxp_fspi can_dev caam error pwm_imx27 snvs_pwrkey nvmem_snvs_lpgpr spi_imx imx8mm_thermal display_connector gpio_keys galcore(O) fuse ipv6 autofs4
[ 13.139303] CPU: 3 PID: 484 Comm: kworker/u8:2 Tainted: G D O 6.6.23-7.0.0-devel-g5545cedda0e3 #1
[ 13.149393] Hardware name: Toradex Verdin iMX8M Plus on Verdin Development Board (DT)
[ 13.157223] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 13.164186] pc : __lookup_mnt+0x40/0x60
[ 13.168029] lr : step_into+0xcc/0x60c
[ 13.171696] sp : ffffffc08384ba80
[ 13.175011] x29: ffffffc08384baa0 x28: ffffffc08384bc70 x27: 0000000000000000
[ 13.182153] x26: 2f2f2f2f2f2f2f2f x25: 0000000000000002 x24: ffffffc0811985c0
[ 13.189293] x23: 0000000000000002 x22: 0000000000210000 x21: ffffff8000454cc0
[ 13.196434] x20: ffffff8000454cc0 x19: ffffffc08384bc70 x18: 0000000000000000
[ 13.203575] x17: 0000000000000000 x16: ffffffc080c952f8 x15: ffffffffffffffff
[ 13.210716] x14: 0000000000000000 x13: ffffff80015e11a0 x12: ffffffc08384bcb4
[ 13.217857] x11: 000000037f871908 x10: 0000000000000002 x9 : 0000000000000003
[ 13.224998] x8 : ffffff8000454b40 x7 : 6e6962732f727375 x6 : 00000000000007ff
[ 13.232139] x5 : ffffff8000054000 x4 : 000000000000000b x3 : ffffff80000897e0
[ 13.239280] x2 : 0000ffffff800026 x1 : ffffff8000454cc0 x0 : 000000000801021f
[ 13.246421] Call trace:
[ 13.248867] __lookup_mnt+0x40/0x60
[ 13.252360] walk_component+0x4c/0x190
[ 13.256112] link_path_walk.part.0.constprop.0+0x25c/0x384
[ 13.261600] path_openat+0xa8/0xdc4
[ 13.265091] do_filp_open+0x9c/0x14c
[ 13.268670] do_open_execat+0x60/0x148
[ 13.272421] bprm_execve+0x118/0x524
[ 13.275997] kernel_execve+0x12c/0x1b0
[ 13.279748] call_usermodehelper_exec_async+0xd0/0x140
[ 13.284889] ret_from_fork+0x10/0x20
[ 13.288471] Code: b5000080 1400000a f9400000 b4000100 (f9400802)
[ 13.294566] ---[ end trace 0000000000000000 ]---
[ 15.094408] Unable to handle kernel paging request at virtual address 0000000008010259
[ 15.094417] Unable to handle kernel paging request at virtual address 0000000008010259
[ 15.094424] Mem abort info:
[ 15.094426] ESR = 0x0000000096000005
[ 15.102359] Mem abort info:
[ 15.102361] ESR = 0x0000000096000005
[ 15.102365] EC = 0x25: DABT (current EL), IL = 32 bits
[ 15.110291] EC = 0x25: DABT (current EL), IL = 32 bits
[ 15.113091] SET = 0, FnV = 0
[ 15.113095] EA = 0, S1PTW = 0
[ 15.116851] SET = 0, FnV = 0
[ 15.119641] FSC = 0x05: level 1 translation fault
[ 15.123398] EA = 0, S1PTW = 0
[ 15.128713] Data abort info:
[ 15.128716] ISV = 0, ISS = 0x00000005, ISS2 = 0x00000000
[ 15.134030] FSC = 0x05: level 1 translation fault
[ 15.134034] Data abort info:
[ 15.137091] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[ 15.137095] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[ 15.140239] ISV = 0, ISS = 0x00000005, ISS2 = 0x00000000
[ 15.140243] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[ 15.143293] user pgtable: 4k pages, 39-bit VAs, pgdp=00000000448ad000
[ 15.148176] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[ 15.151323] [0000000008010259] pgd=0000000000000000
[ 15.154211] user pgtable: 4k pages, 39-bit VAs, pgdp=0000000045478000
[ 15.159685] , p4d=0000000000000000, pud=0000000000000000
[ 15.164566] [0000000008010259] pgd=0000000000000000, p4d=0000000000000000
[ 15.167445]
[ 15.172503] , pud=0000000000000000
[ 15.177819] Internal error: Oops: 0000000096000005 [#4] PREEMPT SMP
[ 15.183310]
[ 15.188349] Modules linked in: bluetooth ecdh_generic nls_iso8859_1 ecc cfg80211 rfkill onboard_usb_hub spidev nls_cp437 usb_conn_gpio snd_soc_hdmi_codec dw_hdmi_gp_audio dw_hdmi_cec dwc3 roles caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes crypto_null evdev aes_ce_cipher ghash_ce gf128mul libaes sha2_ce sha256_arm64 sha1_ce sha1_generic fsl_imx8_ddr_perf snd_soc_simple_card phy_fsl_imx8mq_usb snd_soc_simple_card_utils snd_soc_imx_hdmi phy_fsl_imx8m_pcie sec_mipi_dsim_imx sec_dsim dwc3_imx8mp imx_bus phy_fsl_samsung_hdmi snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma snd_soc_fsl_aud2htx imx_sdma snd_soc_nau8822 ti_ads1015 ina2xx lontium_lt8912b gpio_pca953x flexcan industrialio_triggered_buffer lm75 kfifo_buf spi_nxp_fspi can_dev caam error pwm_imx27 snvs_pwrkey nvmem_snvs_lpgpr spi_imx imx8mm_thermal display_connector gpio_keys galcore(O) fuse ipv6 autofs4
[ 15.315104] CPU: 2 PID: 462 Comm: (agetty) Tainted: G D O 6.6.23-7.0.0-devel-g5545cedda0e3 #1
[ 15.324848] Hardware name: Toradex Verdin iMX8M Plus on Verdin Development Board (DT)
[ 15.332677] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 15.339640] pc : __lookup_mnt+0x40/0x60
[ 15.343483] lr : step_into+0xcc/0x60c
[ 15.347150] sp : ffffffc08382ba70
[ 15.350464] x29: ffffffc08382ba90 x28: ffffffc08382bc60 x27: 0000000000000000
[ 15.357606] x26: 2f2f2f2f2f2f2f2f x25: 0000000000000002 x24: ffffffc0811985c0
[ 15.364746] x23: 0000000000000002 x22: 0000000000210000 x21: ffffff8000454a80
[ 15.371887] x20: ffffff8000454a80 x19: ffffffc08382bc60 x18: 0000000000000000
[ 15.379029] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 15.386175] x14: 0000000000000000 x13: ffffff800100c021 x12: ffffffc08382bca4
[ 15.393316] x11: 0000000341ef3aee x10: 0000000000000002 x9 : 0000000000000003
[ 15.400457] x8 : ffffff8000454b40 x7 : 317974742f766564 x6 : 00000000000007ff
[ 15.407598] x5 : ffffff8000054000 x4 : 000000000000000b x3 : ffffff80000897e0
[ 15.414739] x2 : 0000ffffff800026 x1 : ffffff8000454a80 x0 : 0000000008010249
[ 15.421880] Call trace:
[ 15.424326] __lookup_mnt+0x40/0x60
[ 15.427819] walk_component+0x4c/0x190
[ 15.431570] link_path_walk.part.0.constprop.0+0x25c/0x384
[ 15.437059] path_openat+0xa8/0xdc4
[ 15.440551] do_filp_open+0x9c/0x14c
[ 15.444129] do_sys_openat2+0xc4/0x104
[ 15.447881] __arm64_sys_openat+0x64/0xac
[ 15.451892] invoke_syscall.constprop.0+0x50/0xe8
[ 15.456601] do_el0_svc+0x40/0xc8
[ 15.459918] el0_svc+0x48/0x148
[ 15.463062] el0t_64_sync_handler+0x120/0x12c
[ 15.467420] el0t_64_sync+0x190/0x194
[ 15.471088] Code: b5000080 1400000a f9400000 b4000100 (f9400802)
[ 15.477182] ---[ end trace 0000000000000000 ]---
[ 15.481800] Internal error: Oops: 0000000096000005 [#5] PREEMPT SMP
[ 15.484378] Unable to handle kernel paging request at virtual address 0000000008010259
[ 15.488070] Modules linked in: bluetooth ecdh_generic nls_iso8859_1 ecc cfg80211 rfkill onboard_usb_hub spidev nls_cp437 usb_conn_gpio snd_soc_hdmi_codec dw_hdmi_gp_audio dw_hdmi_cec dwc3 roles caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes
[ 15.496051] Mem abort info:
[ 15.496052] crypto_null
[ 15.496056] ESR = 0x0000000096000005
[ 15.520285] evdev aes_ce_cipher ghash_ce gf128mul libaes sha2_ce sha256_arm64 sha1_ce sha1_generic fsl_imx8_ddr_perf snd_soc_simple_card phy_fsl_imx8mq_usb snd_soc_simple_card_utils
[ 15.523124] EC = 0x25: DABT (current EL), IL = 32 bits
[ 15.525624] snd_soc_imx_hdmi phy_fsl_imx8m_pcie sec_mipi_dsim_imx sec_dsim dwc3_imx8mp imx_bus phy_fsl_samsung_hdmi snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma snd_soc_fsl_aud2htx
[ 15.529400] SET = 0, FnV = 0
[ 15.545635] imx_sdma snd_soc_nau8822 ti_ads1015 ina2xx lontium_lt8912b gpio_pca953x
[ 15.550959] EA = 0, S1PTW = 0
[ 15.567195] flexcan industrialio_triggered_buffer lm75 kfifo_buf spi_nxp_fspi can_dev
[ 15.570264] FSC = 0x05: level 1 translation fault
[ 15.577990] caam error pwm_imx27 snvs_pwrkey nvmem_snvs_lpgpr spi_imx imx8mm_thermal display_connector
[ 15.581148] Data abort info:
[ 15.589050] gpio_keys galcore(O) fuse ipv6 autofs4
[ 15.589063] CPU: 1 PID: 463 Comm: (agetty) Tainted: G D O 6.6.23-7.0.0-devel-g5545cedda0e3 #1
[ 15.589069] Hardware name: Toradex Verdin iMX8M Plus on Verdin Development Board (DT)
[ 15.593957] ISV = 0, ISS = 0x00000005, ISS2 = 0x00000000
[ 15.603332] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 15.603338] pc : __lookup_mnt+0x40/0x60
[ 15.606229] CM = 0, WnR = 0, TnD = 0, TagAccess = 0
[ 15.611093] lr : step_into+0xcc/0x60c
[ 15.611101] sp : ffffffc08383ba70
[ 15.620843] GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
[ 15.628658] x29: ffffffc08383ba90 x28: ffffffc08383bc60 x27: 0000000000000000
[ 15.628667] x26: 2f2f2f2f2f2f2f2f
[ 15.634155] user pgtable: 4k pages, 39-bit VAs, pgdp=0000000040f45000
[ 15.641102] x25: 0000000000000002 x24: ffffffc0811985c0
[ 15.641109] x23: 0000000000000002 x22: 0000000000210000 x21: ffffff8000454a80
[ 15.644952] [0000000008010259] pgd=0000000000000000
[ 15.649990]
[ 15.649991] x20: ffffff8000454a80 x19: ffffffc08383bc60 x18: 0000000000000000
[ 15.649999] x17: 0000000000000000
[ 15.653664] , p4d=0000000000000000
[ 15.656966] x16: 0000000000000000 x15: 0000000000000000
[ 15.656971] x14: 0000000000000000 x13: ffffff80001ec021 x12: ffffffc08383bca4
[ 15.662294] , pud=0000000000000000
[ 15.669413]
[ 15.669414] x11: 0000000341ef3aee x10: 0000000000000002 x9 : 0000000000000003
[ 15.669422] x8 : ffffff8000454b40
[ 15.672739]
[ 15.679166] x7 : 6d7974742f766564 x6 : 00000000000007ff
[ 15.679173] x5 : ffffff8000054000 x4 : 000000000000000b x3 : ffffff80000897e0
[ 15.753562] x2 : 0000ffffff800026 x1 : ffffff8000454a80 x0 : 0000000008010249
[ 15.760704] Call trace:
[ 15.763150] __lookup_mnt+0x40/0x60
[ 15.766644] walk_component+0x4c/0x190
[ 15.770396] link_path_walk.part.0.constprop.0+0x25c/0x384
[ 15.775885] path_openat+0xa8/0xdc4
[ 15.779379] do_filp_open+0x9c/0x14c
[ 15.782960] do_sys_openat2+0xc4/0x104
[ 15.786714] __arm64_sys_openat+0x64/0xac
[ 15.790725] invoke_syscall.constprop.0+0x50/0xe8
[ 15.795433] do_el0_svc+0x40/0xc8
[ 15.798751] el0_svc+0x48/0x148
[ 15.801894] el0t_64_sync_handler+0x120/0x12c
[ 15.806252] el0t_64_sync+0x190/0x194
[ 15.809920] Code: b5000080 1400000a f9400000 b4000100 (f9400802)
[ 15.816015] ---[ end trace 0000000000000000 ]---
[ 15.820632] Internal error: Oops: 0000000096000005 [#6] PREEMPT SMP
[ 15.826907] Modules linked in: bluetooth ecdh_generic nls_iso8859_1 ecc cfg80211 rfkill onboard_usb_hub spidev nls_cp437 usb_conn_gpio snd_soc_hdmi_codec dw_hdmi_gp_audio dw_hdmi_cec dwc3 roles caam_jr caamkeyblob_desc caamhash_desc caamalg_desc crypto_engine authenc libdes crypto_null evdev aes_ce_cipher ghash_ce gf128mul libaes sha2_ce sha256_arm64 sha1_ce sha1_generic fsl_imx8_ddr_perf snd_soc_simple_card phy_fsl_imx8mq_usb snd_soc_simple_card_utils snd_soc_imx_hdmi phy_fsl_imx8m_pcie sec_mipi_dsim_imx sec_dsim dwc3_imx8mp imx_bus phy_fsl_samsung_hdmi snd_soc_fsl_sai snd_soc_fsl_utils imx_pcm_dma snd_soc_fsl_aud2htx imx_sdma snd_soc_nau8822 ti_ads1015 ina2xx lontium_lt8912b gpio_pca953x flexcan industrialio_triggered_buffer lm75 kfifo_buf spi_nxp_fspi can_dev caam error pwm_imx27 snvs_pwrkey nvmem_snvs_lpgpr spi_imx imx8mm_thermal display_connector gpio_keys galcore(O) fuse ipv6 autofs4
[ 15.905851] CPU: 3 PID: 1 Comm: systemd Tainted: G D O 6.6.23-7.0.0-devel-g5545cedda0e3 #1
[ 15.915333] Hardware name: Toradex Verdin iMX8M Plus on Verdin Development Board (DT)
[ 15.923162] pstate: 00000005 (nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 15.930125] pc : __lookup_mnt+0x40/0x60
[ 15.933969] lr : step_into+0xcc/0x60c
[ 15.937636] sp : ffffffc08135ba70
[ 15.940949] x29: ffffffc08135ba90 x28: ffffffc08135bc60 x27: 0000000000000000
[ 15.948091] x26: 2f2f2f2f2f2f2f2f x25: 0000000000000002 x24: ffffffc0811985c0
[ 15.955232] x23: 0000000000000002 x22: 0000000000210000 x21: ffffff8000454a80
[ 15.962372] x20: ffffff8000454a80 x19: ffffffc08135bc60 x18: 0000000000000000
[ 15.969515] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
[ 15.976656] x14: 0000000000000000 x13: ffffff8000f5e021 x12: ffffffc08135bca4
[ 15.983796] x11: 0000000341ef3aee x10: 0000000000000002 x9 : 0000000000000003
[ 15.990937] x8 : ffffff8000454b40 x7 : 317974742f766564 x6 : 00000000000007ff
[ 15.998077] x5 : ffffff8000054000 x4 : 000000000000000b x3 : ffffff80000897e0
[ 16.005218] x2 : 0000ffffff800026 x1 : ffffff8000454a80 x0 : 0000000008010249
[ 16.012361] Call trace:
[ 16.014807] __lookup_mnt+0x40/0x60
[ 16.018300] walk_component+0x4c/0x190
[ 16.022052] link_path_walk.part.0.constprop.0+0x25c/0x384
[ 16.027540] path_openat+0xa8/0xdc4
[ 16.031032] do_filp_open+0x9c/0x14c
[ 16.034610] do_sys_openat2+0xc4/0x104
[ 16.038361] __arm64_sys_openat+0x64/0xac
[ 16.042373] invoke_syscall.constprop.0+0x50/0xe8
[ 16.047081] do_el0_svc+0x40/0xc8
[ 16.050399] el0_svc+0x48/0x148
[ 16.053545] el0t_64_sync_handler+0x120/0x12c
[ 16.057902] el0t_64_sync+0x190/0x194
[ 16.061569] Code: b5000080 1400000a f9400000 b4000100 (f9400802)
[ 16.067665] ---[ end trace 0000000000000000 ]---
[ 16.072327] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 16.079989] SMP: stopping secondary CPUs
[ 16.084216] Kernel Offset: disabled
[ 16.087704] CPU features: 0x0,00000000,00020000,1000420b
[ 16.093017] Memory Limit: none
[ 16.096075] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
