Boot U-Boot from ECSPI on i.MX6ULL
1,189 次查看
zard
I am developing a device based on the imx6ull chip and need to use nor flash to store the firmware. The nor uses the ecspi1 pin. Is there a uboot startup example on ecspi1 and the startup parameters of uboot startup kernel for reference?
标签 (1)
3 回复数
1,160 次查看
Chavira
Hi @zard!
Thank you for contacting NXP Support!
You can get based on the iMX6ULL-EVK board you can see the schematics and our BSP to compile successful booting from QSPI in your custom board.
https://www.nxp.com/design/design-center/development-boards-and-designs/i-mx-evaluation-and-developm...
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/embedded-linux-for...
Best Regards!
Chavira
1,132 次查看
zard
Hi Chavira, thank you for your reply. Perhaps my question has led to some misunderstanding. My current issue is booting from ecspi, not qspi. Thank you.
1,118 次查看
Chavira
Hi @zard!
Unfortunately, our hardware is not prepared for that, and I can't provide you with examples for that.
Sorry for the mistake!
