Has someone been able to get Bluetooth USB dongle working on SabreLite Nitrogen6x board in non Android builds?
I've been trying to achieve this with fsl-ubuntu (L3.0.35.1.1.0 / L3.0.35.1.1.1) and with Yocto build with these instructions How to test yocto for imx6 .
For me it looks like that rfkill soft blocking is being enabled due some automatic event, either from kernel or Bluetoothd.
I tried to build kernel without rfkill driver but then I'm not able to see any devices with hciconfig.
With quick look there is no build flag in Bluetooth driver to disable rfkill as there is in Andoroid.
I can see following behaviour when trying to set rfkill unblock all.
Initial Situation
0: hci0: bluetooth
Soft blocked: yes
Hard blocked: no
After rfkill unblock all
0: hci0: bluetooth
Soft blocked: no
Hard blocked: no
About 0,5sec after rfkill unblock all
0: hci0: bluetooth
Soft blocked: yes
Hard blocked: no
Below is the /var/log/messages for Bluetooth events
May 7 02:01:33 imx6qsabreauto daemon.info bluetoothd[717]: Bluetooth daemon 4.101
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[717]: src/main.c:parse_config() parsing main.conf
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[717]: src/main.c:parse_config() discovto=0
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[717]: src/main.c:parse_config() pairto=0
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[717]: src/main.c:parse_config() pageto=8192
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[717]: src/main.c:parse_config() auto_to=60
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[717]: src/main.c:parse_config() name=%h-%d
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[717]: src/main.c:parse_config() class="0x000100"
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[717]: src/main.c:parse_config() Key file does not have key 'DeviceID'
May 7 02:01:33 imx6qsabreauto daemon.info bluetoothd[718]: Starting SDP server
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:plugin_init() Loading builtin plugins
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading audio plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading input plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading serial plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading network plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading service plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading hciops plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading mgmtops plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading formfactor plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading storage plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:add_plugin() Loading adaptername plugin
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/plugin.c:plugin_init() Loading plugins /usr/lib/bluetooth/plugins
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: plugins/service.c:register_interface() path /org/bluez/717/any
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: plugins/service.c:register_interface() Registered interface org.bluez.Service on path /org/bluez/717/any
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: network/manager.c:read_config() /etc/bluetooth/network.conf: Key file does not have key 'DisableSecurity'
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: network/manager.c:read_config() Config options: Security=true
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: input/manager.c:input_manager_init() input.conf: Key file does not have key 'IdleTimeout'
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: audio/manager.c:audio_manager_init() audio.conf: Key file does not have key 'AutoConnect'
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: plugins/hciops.c:hciops_init()
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: plugins/hciops.c:hciops_setup()
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/main.c:main() Entering main loop
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: src/rfkill.c:rfkill_event() RFKILL event idx 0 type 2 op 0 soft 1 hard 0
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: plugins/hciops.c:init_known_adapters()
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: plugins/hciops.c:init_device() hci0
May 7 02:01:33 imx6qsabreauto daemon.info bluetoothd[718]: Listening for HCI events on hci0
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: plugins/hciops.c:init_device() child 719 forked
May 7 02:01:33 imx6qsabreauto daemon.err bluetoothd[719]: Can't init device hci0: Operation not possible due to RF-kill (132)
May 7 02:01:33 imx6qsabreauto daemon.debug bluetoothd[718]: plugins/hciops.c:child_exit() child 719 exited
May 7 02:04:23 imx6qsabreauto daemon.debug bluetoothd[718]: src/rfkill.c:rfkill_event() RFKILL event idx 0 type 2 op 2 soft 0 hard 0
May 7 02:04:23 imx6qsabreauto daemon.debug bluetoothd[718]: src/rfkill.c:rfkill_event() RFKILL event idx 0 type 2 op 2 soft 1 hard 0
May 7 02:04:34 imx6qsabreauto daemon.debug bluetoothd[718]: src/rfkill.c:rfkill_event() RFKILL event idx 0 type 2 op 2 soft 0 hard 0
Hi Kari,
GaryCollins mentioned that he was successful by simply adding
CONFIG_HMIBTUSB=m into his kernel configuration and installing
the bluez-utils and bluez packages.
I don't know the details of what type of dongle he used though.
Kari, please check out these references: https://community.freescale.com/search.jspa?q=*bluetooth*+*usb*+*dongle*.
