Is there any way to have the g2d system blend two gray scale images and output a new gray scale image? From the examples I have seen it seems to only accept rgb as output. But maybe it's possible to somehow make g2d do the gray scale bending correctly for a gray scale output, even though it treats it as rgba?
Hello Erlend,
Sorry the output has to be in RGB, but you can the scale with gray image, but the output should be in RGB format.
