Blank display in imx8mm using LVDS bridge
Ruban1
Hi sir/ madam,
    I am currently working on Imx8mm LVDS display using sn65dsi83 mipi to lvds converter.
The problem i am facing is . I am able to attach the driver and able to probe the driver .
The current doubt is is it enough for me only to probe with LVDS bridge driver or should i even add the panel files also.
If i have to add panel files. I have already configure panel-simple.c file according to my requirements but the problem is i am not able to enter the panel folder .. I checked using added printk msg but not even one is displayed .
Kindly help me to solve the solution
Thanks and regards
Ruban
jimmychan
