I have "i.MX 8QuadXPlus Multisensory Enablement Kit (MEK)" which I would like to run QNX on.
QNX have provide a BSP for this board, but I need to get some binaries from NXP to be able to use it.
From “BSP User's Guide NXP i.MX 8QuadXPlus CPU Board”
You must contact NXP Support to get the necessary firmware and binaries. After you get the necessary files, follow these steps to build the images for this BSP.
CAUTION: If you don't complete the following steps before you build this BSP, the IPL and QNX IFS images won't build nor function on your board.
Files to get:
imx-fspi-header.bin Required to build the QNX IPL boot file for Flash
imx-fspi-header.src Required to build the QNX IPL boot file for Flash
mkimage_imx8 Required to generate the QNX IPL on Linux and macOS hosts
mkimage_imx8.exe Required to generate the QNX IPL on Windows hosts
mx8qxb0-ahab-container.img Required to build the B0 IPL file
mx8qxc0-ahab-container.img Required to build the C0 IPL file
scfw_tcm_b0.bin Required to build both the B0 and C0 IPL files bl31.bin Required to build the QNX IPL (Optional)
mx-scfw-porting-kit.bin.gz
Where can I get these files?
Magnus
PS.
I am not familiar with "Code Aurora" and how to get files from it.
