Am looking at the SABRE Board MCIMX6Q - when we momentarily press the Power Switch Button SW1, the system goes into Standby mode. It seems that the PMIC keeps all the iMX6 supplies active
We are looking for info on how the iMX6 Dual IO pins behave when the iMX6 goes into Standby mode, when they are configured as outputs. Am not seeing this info in the "Reference Manual"
For example:
Solved! Go to Solution.
Hi Stephen
both GPIOs outputs and GPIO08 32 KHz remain unchanged in standby mode.
Hi Stephen
Thanks, this take scare of my question
