Hello Chuck,
Thanks for your reply and the AN4199, I read it around the 4.2V issue.
I checked 5V power connected, and it's always be around 5.1V.
Since this board have not been programed, there is no power up code to run.
I realized that at power on time, the 4.2V regulator is not enabled.
The problem is, when trying mfgtools, it would have 1167 error. what power situation would make this error happen?
Thanks & Regards,
Zhu
