Battery capacity measurement
ソリューションへジャンプ
5,548件の閲覧回数
martinhowell
We have a design based on the iMX51 EVK, and using the MC13892 PMIC (same as the EVK).
We want to use the Coulomb  counter on the PMIC to indicate remaining battery charge, and the datasheet seems fairly vaugue on this, especialy the calibration procedure.
If anyone has used the coulomb counter can they share any experiences, tips tricks etc?
タグ(2)
5,295件の閲覧回数
imxcommunitysco
Senior Contributor II
Please find attached a brief users guide on how to initialize and use the coulomb counter.
5 返答(返信)
5,295件の閲覧回数
jimmychan
Attached is the Coulomb counter Users Guide. Hope this can help you.
5,295件の閲覧回数
SteM
I enabled the counter but it is relative to the last power off: it is a "relative" count..
How can i get an absolute count?
Should I occasionally save the count? In this way i will burn the storage!
Any idea?
5,296件の閲覧回数
imxcommunitysco
5,295件の閲覧回数
SteM
This is the same doc posted by jimmychan ...
5,295件の閲覧回数
jimmychan
