A partner asks:
I am having some confusion regarding the battery connections and what can be used on the i.MX6 SDP platform. Can you please provide information on how the battery is connected on the i.MX6 SDP and where can we purchase the batteries for SDP platform? Understanding the “how to connect” is a higher priority than purchasing the batteries.
Thank you
Solved! Go to Solution.
I does not get any easier with the SDP, as long as the board has the battery charging circuit populated.*
There are battery connectors and also holes for direct wire soldering.
FSL used following battery for our design testing – Powerizer PL-7548168WR 3.7V 6400mAh: Purchased at www.batteryspace.com
The customer can use any battery they desire (see notes).
* NOTES:
* NOTES:
