BT connectivity(connection / unpair) is not working properly
已解决
跳至解决方案
1,463 次查看
vinothkumars
Senior Contributor IV
Dear NXP,
   I am working on Toradex apalis imx6q with Android Nougat. When we try remove the paired device(bu clicking unpair), unpair was done properly. But, still music playing on bluetooth headsets.
Steps::
      1.Go BT and connect your phone.
      2.start play music.
      3.go to BT(headset/phone) and unpair the device.
Observation::
      still song/error is playing in the bluetooth headset.
VinothS
Vinothkumar Sekar
标签 (2)
1 解答
1,354 次查看
jimmychan
I think this is an application layer issue. You better to consult the company of your BLE chip. Your application may call the BLE stack. In the stack events, there should have a case for "disconnect" status. So , when BLE is disconnected, you can stop to play the music.
在原帖中查看解决方案
2 回复数
1,354 次查看
vinothkumars
Hi jimmychan,
Thank you for your reply. The issues in bluetooth stack. I want to disconnect the headset after unpair.
VinothS
Vinothkumar Sekar
1,355 次查看
jimmychan
