BT calling audio not heard in iMX8MQ-EVK Board configured for AAOS-11
aniruthvk
Dear NXP,
Hardware: iMX8mq-evk
Software: Android Automotive OS-11.0.0_1.0.0
I have been working on Bluetooth calling on my i.MX8MQ-EVK board with Android 11 configured for automotive. I am able to connect my phone to the device and contacts fetched (PBAP) successfully.
Currently we have 2 audio devices configured and are working as expected:
1. imx-audio-hdmi (Audio for multimedia, for e.g., music, navigation, call etc)
2. wm8524 (For alerts, notification and warning)
In this scenario, when a BT call is made, we are able to hear ringtone. But when we connect the call, voice from the other end is not heard from HDMI or wm8524 bus.
Please advice what change I have to make to enable audio for Bluetooth call so that I can hear the voice during a call. Please find the attached audio routing conf, audio policy, dmesg, adb logs.
audio_policy_configuration.xml
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<!-- Copyright (C) 2017 The Android Open Source Project
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
<audioPolicyConfiguration version="1.0" xmlns:xi="http://www.w3.org/2001/XInclude">
<globalConfiguration speaker_drc_enabled="true"/>
<modules>
<module name="primary" halVersion="2.0">
<attachedDevices>
<item>Speaker</item>
<item>Built-In Mic</item>
</attachedDevices>
<defaultOutputDevice>Speaker</defaultOutputDevice>
<mixPorts>
<mixPort name="primary output" role="source" flags="AUDIO_OUTPUT_FLAG_PRIMARY">
<profile name="" format="AUDIO_FORMAT_PCM_16_BIT"
samplingRates="48000" channelMasks="AUDIO_CHANNEL_OUT_STEREO"/>
</mixPort>
<mixPort name="hdmi output" role="source" flags="AUDIO_OUTPUT_FLAG_DIRECT">
samplingRates="32000,44100,48000,88200,96000,176400,192000" channelMasks="AUDIO_CHANNEL_NONE"/>
</mixPort>
<mixPort name="esai output" role="source" flags="AUDIO_OUTPUT_FLAG_DIRECT">
samplingRates="48000,96000,192000,384000,768000"
channelMasks="AUDIO_CHANNEL_OUT_STEREO,AUDIO_CHANNEL_OUT_QUAD,AUDIO_CHANNEL_OUT_5POINT1,AUDIO_CHANNEL_OUT_7POINT1"/>
</mixPort>
<mixPort name="dsd output" role="source" flags="AUDIO_OUTPUT_FLAG_DIRECT|AUDIO_OUTPUT_FLAG_COMPRESS_OFFLOAD">
<profile name="" format="AUDIO_FORMAT_DSD"
samplingRates="2822400,5644800,11289600,22579200" channelMasks="AUDIO_CHANNEL_OUT_STEREO"/>
</mixPort>
<mixPort name="bt sco output" role="source">
samplingRates="16000" channelMasks="AUDIO_CHANNEL_OUT_STEREO"/>
</mixPort>
<mixPort name="primary input" role="sink">
samplingRates="8000,11025,16000,22050,24000,32000,44100,48000"
channelMasks="AUDIO_CHANNEL_IN_MONO,AUDIO_CHANNEL_IN_STEREO"/>
</mixPort>
</mixPorts>
<devicePorts>
<devicePort tagName="Speaker" type="AUDIO_DEVICE_OUT_SPEAKER" role="sink" >
</devicePort>
<devicePort tagName="Wired Headphones" type="AUDIO_DEVICE_OUT_WIRED_HEADPHONE" role="sink">
</devicePort>
<devicePort tagName="HDMI Out" type="AUDIO_DEVICE_OUT_AUX_DIGITAL" role="sink">
</devicePort>
<devicePort tagName="BT SCO Headset" type="AUDIO_DEVICE_OUT_BLUETOOTH_SCO_HEADSET" role="sink">
</devicePort>
<devicePort tagName="BT SCO CarKit" type="AUDIO_DEVICE_OUT_BLUETOOTH_SCO_CARKIT" role="sink">
</devicePort>
<devicePort tagName="BT SCO" type="AUDIO_DEVICE_OUT_BLUETOOTH_SCO" role="sink">
</devicePort>
<devicePort tagName="Built-In Mic" type="AUDIO_DEVICE_IN_BUILTIN_MIC" role="source">
</devicePort>
<devicePort tagName="Spdif-In" type="AUDIO_DEVICE_IN_AUX_DIGITAL" role="source">
</devicePort>
<devicePort tagName="BT SCO Headset Mic" type="AUDIO_DEVICE_IN_BLUETOOTH_SCO_HEADSET" role="source">
</devicePort>
</devicePorts>
<routes>
<route type="mix" sink="Speaker"
sources="primary output"/>
<route type="mix" sink="Wired Headphones"
sources="dsd output,esai output,primary output"/>
<route type="mix" sink="HDMI Out"
sources="hdmi output,primary output"/>
<route type="mix" sink="BT SCO Headset"
sources="bt sco output"/>
<route type="mix" sink="BT SCO CarKit"
<route type="mix" sink="BT SCO"
<route type="mix" sink="primary input"
sources="Built-In Mic,Spdif-In,BT SCO Headset Mic"/>
</routes>
</module>
<!-- A2dp Audio HAL -->
<xi:include href="a2dp_audio_policy_configuration.xml"/>
<!-- Usb Audio HAL -->
<xi:include href="usb_audio_policy_configuration.xml"/>
<!-- Remote Submix Audio HAL -->
<xi:include href="r_submix_audio_policy_configuration.xml"/>
</modules>
<!-- Volume section -->
<xi:include href="audio_policy_volumes.xml"/>
<xi:include href="default_volume_tables.xml"/>
</audioPolicyConfiguration>
car_audio_configuration.xml
<?xml version="1.0" encoding="utf-8"?>
<!-- Copyright (C) 2018 The Android Open Source Project
Copyright 2020 NXP
<carAudioConfiguration version="2">
<zones>
<zone name="primary zone" isPrimary="true" occupantZoneId="0">
<volumeGroups>
<group>
<device address="Speaker">
<context context="music"/>
<context context="navigation"/>
<context context="voice_command"/>
<context context="call_ring"/>
<context context="call"/>
</device>
</group>
<group>
<device address="HDMI Out">
<context context="alarm"/>
<context context="notification"/>
<context context="system_sound"/>
<context context="emergency"/>
<context context="safety"/>
<context context="vehicle_status"/>
<context context="announcement"/>
</device>
</group>
</volumeGroups>
</zone>
</zones>
</carAudioConfiguration>
iMX8M
AVK
Zhiming_Liu
Hi @aniruthvk
Have you follow the 8.2.1 Routing audio stream to different sound cards in User Guide?
Qmiller.
Jose1985
Hi @vinothkumars ,
Do you have experience in such issues?
LJ
vinothkumars
Senior Contributor IV
In this we needs to re-route the audio codec for CALL in audio-hal layer
Vinothkumar Sekar
Jose1985
Dear @aniruthvk ,
I am also facing similar issues like you. Please let me know if you find a solution.
LJ
