BSP Beginner: i.MX 8M Mini Device Tree & DRAM Questions
cmw
I am currently studying the i.MX 8M Mini Reference Manual (IMX8MMRM.pdf, Rev. 3, 11/2020) and the NXP BSP, and I have some questions as a BSP beginner.
Q1.
There are some device nodes described in the Reference Manual but not present in the following Device Tree file:
https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/arch/arm64/boot/dts/freescale/imx8mm.dtsi
Is this because the imx8mm.dtsi file is written specifically for the EVK?
However, there is also an imx8mm-evk.dtsi file in the same directory.
Why are not all nodes defined as listed in Chapter 2 (Memory Map) of the Reference Manual?
For example, the spdif2 node is mentioned in the RM but is not present in the dtsi.
Q2.
The Reference Manual states that only UART1, UART2, and UART3 support SDMA.
However, I found that the uart4 node in imx8mm.dtsi contains properties like dmas and dma-names.
Does this mean that UART4 can actually use DMA?
Q3.
This question is a bit challenging for me as a beginner, so I hope I can describe it properly.
I have two custom boards based on the i.MX 8M Mini.
  • One board uses the same DRAM as the i.MX8MM EVK (LPDDR4, 2 GB, MT53D512M32D2DS‑053 WT:D) and works without any issues.
  • The other board uses a different DRAM (Samsung LPDDR4, 4 GB, likely K4FBE3D4HMMGCJ).
The second board always detects only 2 GB of memory instead of 4 GB.
What I have tried so far:
  1. Makefile
    ifdef CONFIG_IMX8M_4G_LPDDR4
    obj-y += lpddr4_timing_4g.o
  2. Kconfig
    config IMX8M_4G_LPDDR4
    bool "Use LPDDR4 4GB DRAM"
  3. xxxx_defconfig
    CONFIG_IMX8M_4G_LPDDR4=y
  4. Updated the memory node ranges in both the bootloader DT and kernel DT.
Despite these changes, the system still detects only 2 GB.
My questions:
  • Do I need to generate a new lpddr4_pmu_train_*.bin file using the i.MX 8M Family DDR Tool for this Samsung LPDDR4 4 GB memory?
  • Should I also regenerate the lpddr4_timing_4g.c specifically for this DRAM?
  • Are there any reference documents or application notes available for this process?
I apologize for the long post, but I wanted to provide as many details as possible to avoid repeated clarification.
Thank you very much for your time and support.
Rita_Wang
Hi @cmw ,
Q1&A:The imx8mm.dtsi is for the i.MX8MM chip, and imx8mm-evk.dtsi is for NXP i.MX8MM EVK board.
Q2&A: I think you can try, but do not recommend you to do that. Please following our RM.
Q3&A:Yes, for the 4GB LPDDR4 you using, you need to run the DDR tool to generate the proper configration for the new LPDDR4.
I see your setting:
You also need to add the :
git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h
index d01ce0c6a0..198d911a76 100644
--- a/include/configs/imx8mm_evk.h
+++ b/include/configs/imx8mm_evk.h
@@ -213,6 +213,14 @@
#define PHYS_SDRAM 0x40000000
#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
+#ifdef CONFIG_IMX8M_4G_LPDDR4
+#undef PHYS_SDRAM_SIZE
+#define PHYS_SDRAM_SIZE 0xC0000000 /* 3GB */
+#define PHYS_SDRAM_2 0x100000000
+#define PHYS_SDRAM_2_SIZE 0x40000000 /* 1GB */
+#endif
#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM
#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_SIZE >> 1))
For ddr tool:
Hope this can do help for you
Wish you have a nice day
Best Regards
Rita
Rita_Wang
Hi @cmw ,
I see your setting:
+#endif
For ddr tool:
Best Regards
Rita
%3CLINGO-SUB%20id%3D%22lingo-sub-2141227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBSP%20Beginner%3A%20i.MX%208M%20Mini%20Device%20Tree%20%26amp%3B%20DRAM%20Questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20currently%20studying%20the%20i.MX%208M%20Mini%20Reference%20Manual%20(IMX8MMRM.pdf%2C%20Rev.%E2%80%AF3%2C%2011%2F2020)%20and%20the%20NXP%20BSP%2C%20and%20I%20have%20some%20questions%20as%20a%20BSP%20beginner.%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EQ1.%3C%2FSTRONG%3E%3CBR%20%2F%3EThere%20are%20some%20device%20nodes%20described%20in%20the%20Reference%20Manual%20but%20not%20present%20in%20the%20following%20Device%20Tree%20file%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm.dtsi%22%20target%3D%22_new%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm.dtsi%3C%2FA%3E%3CBR%20%2F%3EIs%20this%20because%20the%20imx8mm.dtsi%20file%20is%20written%20specifically%20for%20the%20EVK%3F%3CBR%20%2F%3EHowever%2C%20there%20is%20also%20an%20imx8mm-evk.dtsi%20file%20in%20the%20same%20directory.%3CBR%20%2F%3EWhy%20are%20not%20all%20nodes%20defined%20as%20listed%20in%20Chapter%E2%80%AF2%20(Memory%20Map)%20of%20the%20Reference%20Manual%3F%3CBR%20%2F%3EFor%20example%2C%20the%20spdif2%20node%20is%20mentioned%20in%20the%20RM%20but%20is%20not%20present%20in%20the%20dtsi.%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EQ2.%3C%2FSTRONG%3E%3CBR%20%2F%3EThe%20Reference%20Manual%20states%20that%20only%20UART1%2C%20UART2%2C%20and%20UART3%20support%20SDMA.%3CBR%20%2F%3EHowever%2C%20I%20found%20that%20the%20uart4%20node%20in%20imx8mm.dtsi%20contains%20properties%20like%20dmas%20and%20dma-names.%3CBR%20%2F%3EDoes%20this%20mean%20that%20UART4%20can%20actually%20use%20DMA%3F%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EQ3.%3C%2FSTRONG%3E%3CBR%20%2F%3EThis%20question%20is%20a%20bit%20challenging%20for%20me%20as%20a%20beginner%2C%20so%20I%20hope%20I%20can%20describe%20it%20properly.%3C%2FP%3E%3CP%3EI%20have%20two%20custom%20boards%20based%20on%20the%20i.MX%E2%80%AF8M%20Mini.%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EOne%20board%20uses%20the%20same%20DRAM%20as%20the%20i.MX8MM%20EVK%20(LPDDR4%2C%E2%80%AF2%E2%80%AFGB%2C%E2%80%AFMT53D512M32D2DS%E2%80%91053%E2%80%AFWT%3AD)%20and%20works%20without%20any%20issues.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EThe%20other%20board%20uses%20a%20different%20DRAM%20(Samsung%20LPDDR4%2C%E2%80%AF4%E2%80%AFGB%2C%E2%80%AFlikely%E2%80%AFK4FBE3D4HMMGCJ).%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3EThe%20second%20board%20always%20detects%20only%E2%80%AF2%E2%80%AFGB%20of%20memory%20instead%20of%E2%80%AF4%E2%80%AFGB.%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1972779100%22%20id%3D%22toc-hId-1999768845%22%3EWhat%20I%20have%20tried%20so%20far%3A%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EMakefile%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3Eifdef%3C%2FSPAN%3E%20CONFIG_IMX8M_4G_LPDDR4%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Eobj-y%20%2B%3D%20lpddr4_timing_4g.o%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EKconfig%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Econfig%20IMX8M_4G_LPDDR4%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Ebool%20%22Use%20LPDDR4%204GB%20DRAM%22%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3Exxxx_defconfig%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3ECONFIG_IMX8M_4G_LPDDR4%3Dy%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3EUpdated%20the%20memory%20node%20ranges%20in%20both%20the%20bootloader%20DT%20and%20kernel%20DT.%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3EDespite%20these%20changes%2C%20the%20system%20still%20detects%20only%E2%80%AF2%E2%80%AFGB.%3C%2FP%3E%3CH3%20id%3D%22toc-hId-165324637%22%20id%3D%22toc-hId-192314382%22%3EMy%20questions%3A%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3EDo%20I%20need%20to%20generate%20a%20new%20lpddr4_pmu_train_*.bin%20file%20using%20the%20i.MX%E2%80%AF8M%20Family%20DDR%20Tool%20for%20this%20Samsung%20LPDDR4%E2%80%AF4%E2%80%AFGB%20memory%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EShould%20I%20also%20regenerate%20the%20lpddr4_timing_4g.c%20specifically%20for%20this%20DRAM%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EAre%20there%20any%20reference%20documents%20or%20application%20notes%20available%20for%20this%20process%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CP%3EI%20apologize%20for%20the%20long%20post%2C%20but%20I%20wanted%20to%20provide%20as%20many%20details%20as%20possible%20to%20avoid%20repeated%20clarification.%3CBR%20%2F%3EThank%20you%20very%20much%20for%20your%20time%20and%20support.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2141227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20Family%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BSP%20Beginner%3A%20i.MX%208M%20Mini%20Device%20Tree%20%26amp%3B%20DRAM%20Questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253129%22%20target%3D%22_blank%22%3E%40cmw%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3EQ1%26amp%3BA%3AThe%20imx8mm.dtsi%20is%20for%20the%20i.MX8MM%20chip%2C%20and%20imx8mm-evk.dtsi%20is%20for%20NXP%20i.MX8MM%20EVK%20board.%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3EQ2%26amp%3BA%3A%20I%20think%20you%20can%20try%2C%20but%20do%20not%20recommend%20you%20to%20do%20that.%20Please%20following%20our%20RM.%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%228VAD9jKP5d%22%3EQ3%26amp%3BA%3AYes%2C%20for%20the%204GB%20LPDDR4%20you%20using%2C%20you%20need%20to%20run%20the%20DDR%20tool%20to%20generate%20the%20proper%20configration%20for%20the%20new%20LPDDR4.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3EI%20see%20your%20setting%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3EYou%20also%20need%20to%20add%20the%20%3A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22vNA772KgA1%22%3Egit%20a%2Finclude%2Fconfigs%2Fimx8mm_evk.h%20b%2Finclude%2Fconfigs%2Fimx8mm_evk.h%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3Eindex%20d01ce0c6a0..198d911a76%20100644%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E---%20a%2Finclude%2Fconfigs%2Fimx8mm_evk.h%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%2B%2B%20b%2Finclude%2Fconfigs%2Fimx8mm_evk.h%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%40%40%20-213%2C6%20%2B213%2C14%20%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%23define%20PHYS_SDRAM%200x40000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%23define%20PHYS_SDRAM_SIZE%200x80000000%20%2F*%202GB%20DDR%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23ifdef%20CONFIG_IMX8M_4G_LPDDR4%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23undef%20PHYS_SDRAM_SIZE%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22vxwWYzMVAz%22%3E%2B%23define%20PHYS_SDRAM_SIZE%200xC0000000%20%2F*%203GB%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23define%20PHYS_SDRAM_2%200x100000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23define%20PHYS_SDRAM_2_SIZE%200x40000000%20%2F*%201GB%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23endif%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%23define%20CONFIG_SYS_MEMTEST_START%20PHYS_SDRAM%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%222NwP1kRDqo%22%3E%23define%20CONFIG_SYS_MEMTEST_END%20(CONFIG_SYS_MEMTEST_START%20%2B%20(PHYS_SDRAM_SIZE%20%26gt%3B%26gt%3B%201))%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3EFor%20ddr%20tool%3A%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX8MMini-m845S-DDR-Register-Programming-Aid-RPA%2Fta-p%2F1172443%22%20target%3D%22_blank%22%3Ei.MX8MMini%20(m845S)%20DDR%20Register%20Programming%20Aid%20(RPA)%20-%20NXP%20Community%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-8M-Family-DDR-Tool-Release%2Fta-p%2F1104467%22%20target%3D%22_blank%22%3Ei.MX%208M%20Family%20DDR%20Tool%20Release%20-%20NXP%20Community%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3EHope%20this%20can%20do%20help%20for%20you%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3EWish%20you%20have%20a%20nice%20day%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3EBest%20Regards%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3ERita%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
