BSP Beginner: i.MX 8M Mini Device Tree & DRAM Questions
2,179 次查看
cmw
I am currently studying the i.MX 8M Mini Reference Manual (IMX8MMRM.pdf, Rev. 3, 11/2020) and the NXP BSP, and I have some questions as a BSP beginner.
Q1.
There are some device nodes described in the Reference Manual but not present in the following Device Tree file:
https://github.com/nxp-imx/linux-imx/blob/lf-6.12.y/arch/arm64/boot/dts/freescale/imx8mm.dtsi
Is this because the imx8mm.dtsi file is written specifically for the EVK?
However, there is also an imx8mm-evk.dtsi file in the same directory.
Why are not all nodes defined as listed in Chapter 2 (Memory Map) of the Reference Manual?
For example, the spdif2 node is mentioned in the RM but is not present in the dtsi.
Q2.
The Reference Manual states that only UART1, UART2, and UART3 support SDMA.
However, I found that the uart4 node in imx8mm.dtsi contains properties like dmas and dma-names.
Does this mean that UART4 can actually use DMA?
Q3.
This question is a bit challenging for me as a beginner, so I hope I can describe it properly.
I have two custom boards based on the i.MX 8M Mini.
  • One board uses the same DRAM as the i.MX8MM EVK (LPDDR4, 2 GB, MT53D512M32D2DS‑053 WT:D) and works without any issues.
  • The other board uses a different DRAM (Samsung LPDDR4, 4 GB, likely K4FBE3D4HMMGCJ).
The second board always detects only 2 GB of memory instead of 4 GB.
What I have tried so far:
  1. Makefile
    ifdef CONFIG_IMX8M_4G_LPDDR4
    obj-y += lpddr4_timing_4g.o
  2. Kconfig
    config IMX8M_4G_LPDDR4
    bool "Use LPDDR4 4GB DRAM"
  3. xxxx_defconfig
    CONFIG_IMX8M_4G_LPDDR4=y
  4. Updated the memory node ranges in both the bootloader DT and kernel DT.
Despite these changes, the system still detects only 2 GB.
My questions:
  • Do I need to generate a new lpddr4_pmu_train_*.bin file using the i.MX 8M Family DDR Tool for this Samsung LPDDR4 4 GB memory?
  • Should I also regenerate the lpddr4_timing_4g.c specifically for this DRAM?
  • Are there any reference documents or application notes available for this process?
I apologize for the long post, but I wanted to provide as many details as possible to avoid repeated clarification.
Thank you very much for your time and support.
2,128 次查看
Rita_Wang
Hi @cmw ,
Q1&A:The imx8mm.dtsi is for the i.MX8MM chip, and imx8mm-evk.dtsi is for NXP i.MX8MM EVK board.
Q2&A: I think you can try, but do not recommend you to do that. Please following our RM.
Q3&A:Yes, for the 4GB LPDDR4 you using, you need to run the DDR tool to generate the proper configration for the new LPDDR4.
I see your setting:
You also need to add the :
git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h
index d01ce0c6a0..198d911a76 100644
--- a/include/configs/imx8mm_evk.h
+++ b/include/configs/imx8mm_evk.h
@@ -213,6 +213,14 @@
#define PHYS_SDRAM 0x40000000
#define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
+#ifdef CONFIG_IMX8M_4G_LPDDR4
+#undef PHYS_SDRAM_SIZE
+#define PHYS_SDRAM_SIZE 0xC0000000 /* 3GB */
+#define PHYS_SDRAM_2 0x100000000
+#define PHYS_SDRAM_2_SIZE 0x40000000 /* 1GB */
+#endif
#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM
#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + (PHYS_SDRAM_SIZE >> 1))
For ddr tool:
Hope this can do help for you
Wish you have a nice day
Best Regards
Rita
2,129 次查看
Rita_Wang
Hi @cmw ,
I see your setting:
+#endif
For ddr tool:
Best Regards
Rita
%3CLINGO-SUB%20id%3D%22lingo-sub-2141227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBSP%20%E5%88%9D%E5%AD%A6%E8%80%85%EF%BC%9Ai.MX%208M%20%E8%BF%B7%E4%BD%A0%E8%AE%BE%E5%A4%87%E6%A0%91%20%26amp%3B%20DRAM%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2141227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E5%AD%A6%E4%B9%A0%20i.MX%208M%20Mini%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%88IMX8MMRM.pdf%EF%BC%8CRev.%203%EF%BC%8C2020%20%E5%B9%B4%2011%20%E6%9C%88%EF%BC%89%E5%92%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E7%9A%84%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%EF%BC%8C%E4%BD%9C%E4%B8%BA%E7%94%B5%E8%B7%AF%E6%9D%BF%E6%94%AF%E6%8C%81%E5%8C%85%E5%88%9D%E5%AD%A6%E8%80%85%EF%BC%8C%E6%88%91%E6%9C%89%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EQ1.%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E6%8F%8F%E8%BF%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E8%AE%BE%E5%A4%87%E8%8A%82%E7%82%B9%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%AD%98%E5%9C%A8%E4%BA%8E%E4%BB%A5%E4%B8%8B%E8%AE%BE%E5%A4%87%E6%A0%91%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm.dtsi%22%20target%3D%22_new%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Flinux-imx%2Fblob%2Flf-6.12.y%2Farch%2Farm64%2Fboot%2Fdts%2Ffreescale%2Fimx8mm.dtsi%3C%2FA%3E%20%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E5%9B%A0%E4%B8%BA%20imx8mm.dtsi%20%E6%96%87%E4%BB%B6%E6%98%AF%E4%B8%93%E9%97%A8%E4%B8%BA%20EVK%20%E7%BC%96%E5%86%99%E7%9A%84%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E5%90%8C%E4%B8%80%E7%9B%AE%E5%BD%95%E4%B8%8B%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%20imx8mm-evk.dtsi%20%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%B8%8D%E6%98%AF%E6%8C%89%E7%85%A7%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%AC%AC%202%20%E7%AB%A0%EF%BC%88%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%EF%BC%89%E4%B8%AD%E5%88%97%E5%87%BA%E7%9A%84%E6%89%80%E6%9C%89%E8%8A%82%E7%82%B9%E8%BF%9B%E8%A1%8C%E5%AE%9A%E4%B9%89%EF%BC%9F%3CBR%20%2F%3E%E4%BE%8B%E5%A6%82%EF%BC%8CRM%20%E4%B8%AD%E6%8F%90%E5%88%B0%E4%BA%86%20spdif2%20%E8%8A%82%E7%82%B9%EF%BC%8C%E4%BD%86%20dtsi%20%E4%B8%AD%E5%8D%B4%E6%B2%A1%E6%9C%89%E3%80%82%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EQ2%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E6%8C%87%E5%87%BA%EF%BC%8C%E5%8F%AA%E6%9C%89%20UART1%E3%80%81UART2%20%E5%92%8C%20UART3%20%E6%94%AF%E6%8C%81%20SDMA%E3%80%82%3CBR%20%2F%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%20imx8mm.dtsi%20%E4%B8%AD%E7%9A%84%20uart4%20%E8%8A%82%E7%82%B9%E5%8C%85%E5%90%AB%20dmas%20%E5%92%8C%20dma-names%20%E7%AD%89%E5%B1%9E%E6%80%A7%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%20UART4%20%E5%AE%9E%E9%99%85%E4%B8%8A%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20DMA%EF%BC%9F%3C%2FP%3E%3CHR%20%2F%3E%3CP%3E%3CSTRONG%3EQ3.%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%AF%B9%E6%88%91%E8%BF%99%E4%B8%AA%E5%88%9D%E5%AD%A6%E8%80%85%E6%9D%A5%E8%AF%B4%EF%BC%8C%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E6%9C%89%E7%82%B9%E9%9A%BE%E5%BA%A6%EF%BC%8C%E5%B8%8C%E6%9C%9B%E6%88%91%E8%83%BD%E6%8F%8F%E8%BF%B0%E5%BE%97%E5%BD%93%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%A4%E4%B8%AA%E5%9F%BA%E4%BA%8E%20i.MX%208M%20Mini%20%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E4%B8%80%E5%9D%97%E6%9D%BF%E4%BD%BF%E7%94%A8%E4%B8%8E%20i.mx8mm%20EVK%EF%BC%88LPDDR4%E3%80%812%20GB%E3%80%81MT53D512M32D2DS%E2%80%91053%20WT%3A%20D%EF%BC%89%E7%9B%B8%E5%90%8C%E7%9A%84%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8%EF%BC%8C%E8%BF%90%E8%A1%8C%E6%97%B6%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%8F%A6%E4%B8%80%E5%9D%97%E6%9D%BF%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E5%8A%A8%E6%80%81%E9%9A%8F%E6%9C%BA%E5%AD%98%E5%8F%96%E5%AD%98%E5%82%A8%E5%99%A8(DRAM)%EF%BC%88%E4%B8%89%E6%98%9F%20LPDDR4%EF%BC%8C4%20GB%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%20K4FBE3D4HMMGCJ%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E7%AC%AC%E4%BA%8C%E5%9D%97%E6%9D%BF%E5%A7%8B%E7%BB%88%E5%8F%AA%E8%83%BD%E6%A3%80%E6%B5%8B%E5%88%B0%202%20GB%20%E7%9A%84%E5%86%85%E5%AD%98%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%204%20GB%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1972779100%22%20id%3D%22toc-hId-1999768876%22%3E%E6%88%91%E7%9B%AE%E5%89%8D%E5%B7%B2%E7%BB%8F%E5%B0%9D%E8%AF%95%E8%BF%87%E7%9A%84%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EMakefile%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3Eifdef%3C%2FSPAN%3ECONFIG_IMX8M_4G_LPDDR4%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Eobj-y%20%2B%3D%20lpddr4_timing_4g.o%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EKconfig%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3E%E9%85%8D%E7%BD%AE%20IMX8M_4G_LPDDR4%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3Ebool%20%22%20%E4%BD%BF%E7%94%A8%20LPDDR4%204GB%20DRAM%20%22%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3Exxxx_defconfig%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CSPAN%3ECONFIG_IMX8M_4G_LPDDR4%3Dy%20%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%9B%B4%E6%96%B0%E4%BA%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%20DT%20%E5%92%8C%E5%86%85%E6%A0%B8%20DT%20%E4%B8%AD%E7%9A%84%E5%86%85%E5%AD%98%E8%8A%82%E7%82%B9%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E5%81%9A%E4%BA%86%E8%BF%99%E4%BA%9B%E6%9B%B4%E6%94%B9%EF%BC%8C%E7%B3%BB%E7%BB%9F%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9A%84%E6%95%B0%E6%8D%AE%E4%BB%8D%E7%84%B6%E5%8F%AA%E6%9C%89%202%20GB%E3%80%82%3C%2FP%3E%3CH3%20id%3D%22toc-hId-165324637%22%20id%3D%22toc-hId-192314413%22%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%20lpddr4_pmu_train_*.bin%20%E6%96%87%E4%BB%B6%EF%BC%9F%E4%BD%BF%E7%94%A8%20i.MX%208M%20%E7%B3%BB%E5%88%97%20DDR%20%E5%B7%A5%E5%85%B7%E4%B8%BA%E8%BF%99%E6%AC%BE%20Samsung%20LPDDR4%204%20GB%20%E5%86%85%E5%AD%98%E6%8F%90%E4%BA%A4%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E8%BF%98%E5%BA%94%E8%AF%A5%E9%87%8D%E6%96%B0%E7%94%9F%E6%88%90%20lpddr4_timing_4g.c%20%E6%96%87%E4%BB%B6%EF%BC%9F%E4%B8%93%E9%97%A8%E4%B8%BA%E8%BF%99%E4%B8%AA%20DRAM%20%E5%87%86%E5%A4%87%E7%9A%84%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E9%80%82%E7%94%A8%E4%BA%8E%E6%AD%A4%E8%BF%87%E7%A8%8B%E7%9A%84%E5%8F%82%E8%80%83%E6%96%87%E4%BB%B6%E6%88%96%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E6%88%91%E5%86%99%E4%BA%86%E8%BF%99%E4%B9%88%E9%95%BF%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E6%8F%90%E4%BE%9B%E5%B0%BD%E5%8F%AF%E8%83%BD%E5%A4%9A%E7%9A%84%E7%BB%86%E8%8A%82%EF%BC%8C%E4%BB%A5%E9%81%BF%E5%85%8D%E9%87%8D%E5%A4%8D%E8%AF%B4%E6%98%8E%E3%80%82%3CBR%20%2F%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E6%97%B6%E9%97%B4%E5%92%8C%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2141227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2142517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20BSP%20Beginner%3A%20i.MX%208M%20Mini%20Device%20Tree%20%26amp%3B%20DRAM%20Questions%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253129%22%20target%3D%22_blank%22%3E%40cmw%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E7%AC%AC%201%20%E5%AD%A3%E5%BA%A6%20%26amp%3B%20%E7%AD%94%EF%BC%9Aimx8mm.dtsi%20%E9%80%82%E7%94%A8%E4%BA%8E%20i.mx8mm%20%E8%8A%AF%E7%89%87%EF%BC%8Cimx8mm-evk.dtsi%20%E9%80%82%E7%94%A8%E4%BA%8E%20i.mx8mm%20EVK%20%E6%9D%BF%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E9%97%AE%E9%A2%98%202%26amp%3B%E7%AD%94%EF%BC%9A%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%BB%BA%E8%AE%AE%E4%BD%A0%E8%BF%99%E6%A0%B7%E5%81%9A%E3%80%82%E8%AF%B7%E5%85%B3%E6%B3%A8%E6%88%91%E4%BB%AC%E7%9A%84%20RM%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%228VAD9jKP5d%22%3E%E9%97%AE%E9%A2%98%203%26amp%3B%E7%AD%94%3A%E6%98%AF%E7%9A%84%EF%BC%8C%E5%AF%B9%E4%BA%8E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%204GB%20LPDDR4%EF%BC%8C%E6%82%A8%E9%9C%80%E8%A6%81%E8%BF%90%E8%A1%8C%20DDR%20%E5%B7%A5%E5%85%B7%E4%B8%BA%E6%96%B0%E7%9A%84%20LPDDR4%20%E7%94%9F%E6%88%90%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E6%88%91%E7%9C%8B%E5%88%B0%E4%BD%A0%E7%9A%84%E8%AE%BE%E7%BD%AE%E4%BA%86%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E6%82%A8%E8%BF%98%E9%9C%80%E8%A6%81%E6%B7%BB%E5%8A%A0%20.NET%20Framework%203.0%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22vNA772KgA1%22%3Egit%20a%2Finclude%2Fconfigs%2Fimx8mm_evk.hb%2Finclude%2Fconfigs%2Fimx8mm_evk.h%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%E7%B4%A2%E5%BC%95%20d01ce0c6a0..198d911a76%20100644%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E---%20a%2Finclude%2Fconfigs%2Fimx8mm_evk.h%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%2B%2B%20b%2Finclude%2Fconfigs%2Fimx8mm_evk.h%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%40%40%20-213%2C6%20%2B213%2C14%20%40%40%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%23define%20PHYS_SDRAM%200x40000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%23define%20PHYS_SDRAM_SIZE%200x80000000%20%2F*%202GB%20DDR%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23ifdef%20CONFIG_IMX8M_4G_LPDDR4%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23undef%20PHYS_SDRAM_SIZE%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%22vxwWYzMVAz%22%3E%2B%23define%20PHYS_SDRAM_SIZE%200xC0000000%20%2F*%203GB%20*%2F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23define%20PHYS_SDRAM_2%200x100000000%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23define%20PHYS_SDRAM_2_SIZE%200x40000000%20%2F*%201GB%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%23endif%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%2B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%23define%20CONFIG_SYS_MEMTEST_START%20PHYS_SDRAM%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%20data-slate-fragment%3D%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%22%3E%3CSPAN%20data-slate-node%3D%22text%22%3E%3CSPAN%20class%3D%22%22%20data-slate-leaf%3D%22true%22%20data-sent-id%3D%222NwP1kRDqo%22%3E%23define%20CONFIG_SYS_MEMTEST_END%20(CONFIG_SYS_MEMTEST_START%20%2B%20(PHYS_SDRAM_SIZE%26gt%3B%26gt%3B%201))%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%E7%94%A8%E4%BA%8E%20ddr%20%E5%B7%A5%E5%85%B7%EF%BC%9A%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX8MMini-m845S-DDR-Register-Programming-Aid-RPA%2Fta-p%2F1172443%22%20target%3D%22_blank%22%3Ei.MX8MMini%20(m845S)%20DDR%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%BC%96%E7%A8%8B%E8%BE%85%E5%8A%A9%E5%B7%A5%E5%85%B7%20(RPA)%20-%20NXP%20%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2Fi-MX-8M-Family-DDR-Tool-Release%2Fta-p%2F1104467%22%20target%3D%22_blank%22%3Ei.MX%208M%20%E7%B3%BB%E5%88%97%20DDR%20%E5%B7%A5%E5%85%B7%E7%89%88%E6%9C%AC%20-%20%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%E7%A5%9D%E6%82%A8%E6%9C%89%E7%BE%8E%E5%A5%BD%E7%9A%84%E4%B8%80%E5%A4%A9%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3ERita%3C%2FDIV%3E%0A%3CDIV%20data-slate-node%3D%22element%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
