BOOTING ISSUE
BOOTING ISSUE
4,616 次查看
krishnanbe1994
In Booting time I am getting error like this......help me...
type=1400 audit(36.510:4): avc: granted { read open } for pid=1 comm="init" path="/dev/ttymxc0" dev="tmpfs" ino=9417 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
4 回复数
4,225 次查看
vinays
Hi kirshna ,
I am also having similar issue , zygote is being called in a loop . and further booting is getting stuck . could you help me out in this error .
regards
PARVATHI
4,280 次查看
krishnanbe1994
                                           THE problem is Init process starting again and again  at the particular point.....like this
type=1400 audit(36.510:3): avc: granted { read } for pid=1 comm="init" name="ttymxc0" dev="tmpfs" ino=9417 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
MY LOG FILES :
U-Boot 2017.03-dirty (Aug 25 2018 - 14:47:57 +0530)
CPU: Freescale i.MX6DP rev1.0 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C) at 50C
Reset cause: POR
Model: Freescale i.MX6 Dual Plus MAGIK2Q7 Smart Device Board
Board: MAGIK2Q7
I2C: ready
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
flash target is MMC:1
Net: Board Net Initialization Failed
No ethernet found.
Fastboot: Normal
Hit any key to stop autoboot: 0
boota mmc1
kernel @ 14008000 (9415320)
ramdisk @ 15000000 (2038068)
fdt @ 14f00000 (52611)
## Booting Android Image at 0x12000000 ...
Kernel load addr 0x14008000 size 9195 KiB
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=hdmi, fbpix=RGB24, bpp=32 fbmem=20M video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=400M androidboot.console=ttymxc0 androidboot.storage_type=sd consoleblank=0 androidboot.hardware=freescale cma=448M androidboot.selinux=permissive androidboot.dm_verity=disable androidboot.serialno=180981d4e3167aba androidboot.soc_type=imx6qp androidboot.storage_type=emmc
## Flattened Device Tree blob at 14f00000
Booting using the fdt blob at 0x14f00000
Loading Kernel Image ... OK
Using Device Tree in place at 14f00000, end 14f0fd82
No PMIC found!
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.9.17-03459-ga88711e-dirty (umesh.rudakiya@sysadmin-Vostro-470) (gcc version 4.9.x 20150123 (prerelease) (GCC) ) #8 SMP PREEMPT Wed Sep 5 14:16:30 IST 2018
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt:Machine model: Freescale i.MX6 Quad Q7 board TESSOLVE BOARD
cma: Reserved 448 MiB at 0x1a000000
Memory policy: Data cache writealloc
percpu: Embedded 15 pages/cpu @e66d3000 s31040 r8192 d22208 u61440
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260912
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 557440K/1048576K available (12288K kernel code, 1110K rwdata, 4096K rodata, 1024K init, 602K bss, 32384K reserved, 458752K cma-reserved, 417792K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe7000000 - 0xff800000 ( 392 MB)
lowmem : 0xc0000000 - 0xe6800000 ( 616 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0d00000 (13280 kB)
.init : 0xc1200000 - 0xc1300000 (1024 kB)
.data : 0xc1300000 - 0xc1415ad8 (1111 kB)
.bss : 0xc1415ad8 - 0xc14ac37c ( 603 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 1024 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76470001
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
pid_max: default: 32768 minimum: 301
Security Framework initialized
SELinux: Initializing.
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: update cpu_capacity 1024
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10100000 - 0x10100058
CPU1: update cpu_capacity 1024
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (12.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
CPU1: update max cpu_capacity 1024
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
CPU identified as i.MX6QP, silicon rev 1.0
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx-gpc 20dc000.gpc: pu regulator not ready, retry
mxs-dma 110000.dma-apbh: initialized
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA, using PIO instead.
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA, using PIO instead.
i2c i2c-2: IMX I2C adapter registered
i2c i2c-2: can't use DMA, using PIO instead.
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-prg 21cc000.prg: driver probed
imx-prg 21cd000.prg: driver probed
imx-pre 21c8000.pre: driver probed
imx-pre 21c9000.pre: driver probed
imx-pre 21ca000.pre: driver probed
imx-pre 21cb000.pre: driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
imx rpmsg driver is registered.
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource mxc_timer1
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 1992K (c5000000 - c51f2000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Bus freq driver module loaded
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.630:1): initialized
workingset: timestamp_bits=30 max_order=18 bucket_order=0
Registering sdcardfs 0.1
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
ntfs: driver 2.1.32 [Flags: R/W DEBUG].
jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
fuse init (API version 7.26)
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
imx-weim 21b8000.weim: Driver registered.
backlight supply power not found, using dummy regulator
mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
mxc_sdc_fb fb@0: registered mxc display driver hdmi
Console: switching to colour frame buffer device 80x30
mxc_sdc_fb fb@1: Can't get fb option for mxcfb1!
mxc_sdc_fb fb@2: Can't get fb option for mxcfb2!
mxc_sdc_fb fb@3: Can't get fb option for mxcfb3!
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: loaded firmware 3.3
pfuze100-regulator 0-0008: Full layer: 2, Metal layer: 1
pfuze100-regulator 0-0008: FAB: 0, FIN: 0
pfuze100-regulator 0-0008: pfuze100 found.
vddarm: supplied by SW1AB
vddpu: supplied by SW1C
vddsoc: supplied by SW1C
usb_otg_vbus: supplied by SWBST
usb_h1_vbus: supplied by SWBST
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 27, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
imx sema4 driver is registered.
[drm] Initialized
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
zram: Added device: zram0
at24 0-0057: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
CAN device driver interface
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 22:1e:5b:ec:f8:2b
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
usbcore: registered new interface driver kaweth
pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver cdc_eem
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver option
usbserial: USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver usbtest
usbcore: registered new interface driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.9.17-03459-ga88711e-dirty ehci_hcd
usb usb1: SerialNumber: ci_hdrc.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
random: fast init done
egalax_ts 1-0004: Failed to switch to I2C interface
egalax_ts 2-0004: Failed to switch to I2C interface
input: max11801_ts as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-0048/input/input2
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
usb 1-1: new high-speed USB device number 2 using ci_hdrc
ov5642_read_reg:write reg error:reg=300a
camera ov5642 is not found
usb 1-1: New USB device found, idVendor=04b4, idProduct=6572
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product: USB2.0 Hub
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
camera ov5640_mipi is not found
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
mag3110 2-000e: check mag3110 chip ID
mag3110 2-000e: read chip ID 0xfffffffa is not equal to 0xc4!
mag3110: probe of 2-000e failed with error -22
mma8x5x 0-001c: read chip ID 0xfffffffa is not equal to 0x1a,0x2a,0x3a,0x4a,0x5a!
mma8x5x: probe of 0-001c failed with error -22
imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2194000.usdhc: assigned as wifi host
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
mmc2: new DDR MMC card at address 0001
caam 2100000.caam: ERA source: CAAMVID.
caam 2100000.caam: AXI pipeline throttling enabled.
mmcblk2: mmc2:0001 SEM04G 3.69 GiB
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a16010000000000 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
mmcblk2boot0: mmc2:0001 SEM04G partition 1 2.00 MiB
mmcblk2boot1: mmc2:0001 SEM04G partition 2 2.00 MiB
mmcblk2rpmb: mmc2:0001 SEM04G partition 3 2.00 MiB
mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] c7 e9 68 ce c1 75 43 10
platform caam_sm: [0008] d1 fa ae e1 a4 8f 53 7b
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] 52 64 4e 29 f3 95 7f 32
platform caam_sm: [0008] 5c 35 2c 61 72 13 8c f7
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] 9f 34 a4 89 f8 7e f4 4c
platform caam_sm: [0008] e4 d6 0e 51 07 3a 28 61
platform caam_sm: [0016] 05 79 1a 7f 3e 36 27 c6
platform caam_sm: [0024] c5 04 70 22 25 b4 cc 0d
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 0e 67 ca e3 ea ef 1c ea
platform caam_sm: [0008] fc 9f b4 5c e0 45 ec 89
platform caam_sm: [0016] e9 3e fe 99 a4 f3 6b 06
platform caam_sm: [0024] 2b dd bb 6e 69 3b 43 b9
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 5d 4a 53 55 56 9b a6 05
platform caam_sm: [0008] 25 a5 0b bb f9 8f d9 4e
platform caam_sm: [0016] f1 f8 5c 69 7a 74 bf ce
platform caam_sm: [0024] b5 c4 40 24 f8 36 13 95
platform caam_sm: [0032] 34 6a 66 94 36 00 20 2a
platform caam_sm: [0040] 84 8c f7 b7 f4 c0 a2 29
platform caam_sm: [0048] 89 61 3c b4 d6 9e 64 d8
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] c3 05 a9 75 fb d9 20 e1
platform caam_sm: [0008] 20 7f df 6b 74 16 df 17
platform caam_sm: [0016] 70 0b 45 c1 66 af 70 c0
platform caam_sm: [0024] 7b f3 dc 21 4d 40 5a 10
platform caam_sm: [0032] ab f7 c0 74 bd 31 05 10
platform caam_sm: [0040] 97 94 2d 74 42 a6 7f f1
platform caam_sm: [0048] 20 96 fa 0e 52 af 82 ae
platform caam_sm: [0056] a8 67 34 0b b7 50 3b a4
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] d0 17 3d cf 51 d7 c4 57
platform caam_sm: [0008] d1 44 c9 49 03 93 22 db
platform caam_sm: [0016] bd b6 7d ba df 8b 91 28
platform caam_sm: [0024] 4c f0 dd 44 8e b5 5f 14
platform caam_sm: [0032] c5 29 1d 5d 86 a3 a3 0f
platform caam_sm: [0040] 93 e2 e3 b0 e4 59 c5 a2
platform caam_sm: [0048] ff 29 d5 a2 87 c7 a7 1a
platform caam_sm: [0056] 6f dd b5 4c b4 f9 d6 af
platform caam_sm: [0064] 71 7e 96 42 1e 75 a5 ba
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 98 d4 50 56 8c fb 09 e7
platform caam_sm: [0008] e7 6d d3 6b df 79 5c 03
platform caam_sm: [0016] c2 b0 75 93 0a 3e d3 e8
platform caam_sm: [0024] d1 d5 66 f2 39 26 e1 b7
platform caam_sm: [0032] f4 7e 87 70 3e ed 07 cb
platform caam_sm: [0040] c0 79 d2 90 84 69 ac d8
platform caam_sm: [0048] 99 08 35 97 de 14 4e 9b
platform caam_sm: [0056] 40 fa 69 10 55 ac 03 d7
platform caam_sm: [0064] f1 6b cd 42 0a 71 36 d8
platform caam_sm: [0072] 4a c0 12 92 f7 d9 ac 66
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] 89 9d 91 d0 ad 59 59 f2
platform caam_sm: [0008] 14 82 f1 e3 3f 7c 1a ac
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] b2 99 e1 87 09 31 78 38
platform caam_sm: [0024] f0 79 d8 19 70 45 51 86
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
caam_keyblob caam_keyblob: caam keyblob initialized
hidraw: raw HID events driver (C) Jiri Kosina
usbhid: USB HID core driver
ion_parse_dt_heap_common: id 0 type 4 name cma align 1000
ion_parse_dt_heap_common: id 1 type 1 name sys-contig align 1000
ion_parse_dt_heap_common: id 2 type 0 name system align 1000
ashmem: initialized
usbcore: registered new interface driver snd-usb-audio
wm8962 0-001a: Failed to read ID register
fsl-ssi-dai 202c000.ssi: No cache defaults, reading back from HW
imx-wm8962 sound: failed to find codec platform device
imx-wm8962: probe of sound failed with error -22
imx-audio-hdmi sound-hdmi: hdmi-hifi.0 <-> soc:hdmi_audio@00120000 mapping ok
NET: Registered protocol family 26
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: arp_tables: (C) 2002 David S. Miller
Initializing XFRM netlink socket
NET: Registered protocol family 10
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20161123 t)
can: netlink gateway (rev 20130117) max_hops=1
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
cpu cpu0: Registered imx6q-cpufreq
registered taskstats version 1
imx-gpc 20dc000.gpc: Registered imx-gpc
imx_thermal 2000000.aips-bus:tempmon: Automotive CPU temperature grade - max:125C critical:120C passive:115C
mxc_vpu 2040000.vpu_fsl: VPU initialized
Galcore version 6.2.2.96445
input: gpio-keys as /devices/soc0/gpio-keys/input/input3
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:12 UTC (12)
usb_otg_vbus: disabling
wm8962-supply: disabling
wlreg_on: disabling
ALSA device list:
#0: imx-hdmi-soc
Freeing unused kernel memory: 1024K (c1200000 - c1300000)
init: init first stage started!
init: First stage mount skipped (missing/incompatible fstab in device tree)
init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
init: Loading SELinux policy
SELinux: Permission validate_trans in class security not defined in policy.
SELinux: the above unknown classes and permissions will be denied
audit: type=1403 audit(12.650:2): policy loaded auid=4294967295 ses=4294967295
selinux: SELinux: Loaded policy from /sepolicy
selinux: SELinux: Loaded file_contexts
init: init second stage started!
init: property_set("ro.boot.storage_type", "emmc") failed: property already set
selinux: SELinux: Loaded property_contexts from /plat_property_contexts & /nonplat_property_contexts.
init: Running restorecon...
selinux: SELinux: Could not stat /dev/block: No such file or directory.
init: waitpid failed: No child processes
init: Couldn't load property file: Unable to open '/system/etc/prop.default': No such file or directory: No such file or directory
init: Couldn't load property file: Unable to open '/prop.default': No such file or directory: No such file or directory
init: Couldn't load property file: Unable to open '/odm/default.prop': No such file or directory: No such file or directory
ueventd: ueventd started!
ueventd: Parsing file /ueventd.rc...
ueventd: Parsing file /vendor/ueventd.rc...
ueventd: Unable to open '/vendor/ueventd.rc': No such file or directory
ueventd: Parsing file /odm/ueventd.rc...
ueventd: Unable to open '/odm/ueventd.rc': No such file or directory
ueventd: Parsing file /ueventd.freescale.rc...
ueventd: Coldboot took 0.258402 seconds
keychord: using input dev gpio-keys for fevent
Console: switching to colour dummy device 80x30
watchdogd: watchdogd started (interval 10, margin 20)!
fec: <210> warning: __ecc_read: RS block 5263360: decoding failed
fec: <212> warning: __ecc_read: RS block 5263360: decoding failed
fec: <215> warning: __ecc_read: RS block 5263360: decoding failed
EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: barrier=1
EXT4-fs (mmcblk2p10): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p10): recovery complete
EXT4-fs (mmcblk2p10): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
e2fsck: e2fsck 1.43.3 (04-Sep-2016)
e2fsck: Pass 1: Checking inodes, blocks, and sizes
e2fsck: Pass 2: Checking directory structure
e2fsck: Pass 3: Checking directory connectivity
e2fsck: Pass 4: Checking reference counts
e2fsck: Pass 5: Checking group summary information
e2fsck:
EXT4-fs (mmcblk2p10): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
EXT4-fs (mmcblk2p4): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk2p4): recovery complete
EXT4-fs (mmcblk2p4): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
EXT4-fs (mmcblk2p4): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
init: [libfs_mgr]Failed to open '/dev/block/by-name/vendor': No such file or directory
init: [libfs_mgr]__mount(source=/dev/block/by-name/vendor,target=/vendor,type=ext4)=-1
init: [libfs_mgr]Running /system/bin/e2fsck on /dev/block/by-name/vendor
e2fsck: /system/bin/e2fsck: No such file or directory while trying to open /dev/block/by-name/vendor
e2fsck:
e2fsck: Possibly non-existent device?
e2fsck: e2fsck terminated by exit(8)
init: [libfs_mgr]e2fsck returned status 0x800
init: [libfs_mgr]Failed to mount an un-encryptable or wiped partition on /dev/block/by-name/vendor at /vendor options: barrier=1: No such file or directory
init: fs_mgr_mount_all returned an error: No such file or directory
init: Parsing directory /system/etc/init...
init: Parsing file /system/etc/init/[email protected]...
init: Parsing file /system/etc/init/atrace.rc...
fec: <235> warning: __ecc_read: RS block 5263360: decoding failed
file system registered
using random self ethernet address
using random host ethernet address
logd.auditd: start
logd.klogd: 27765330336
binder: 239:239 ioctl 620a 865ed8a returned -22
zram0: detected capacity change from 0 to 314572800
mkswap: Swapspace size: 307196k, UUID=8b4a7a3e-9d3a-42b9-83d1-ecac13cbb1b9
Adding 307196k swap on /dev/block/zram0. Priority:-1 extents:1 across:307196k SS
logd.daemon: reinit
healthd: unable to get HAL interface, using defaults
healthd: No battery devices found
healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a
read descriptors
read strings
type=1400 audit(36.600:5): avc: granted { read } for pid=263 comm="init" name="ttymxc0" dev="tmpfs" ino=9417 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
magik2q7:/ $ type=1400 audit(36.610:6): avc: granted { read open } for pid=263 comm="init" path="/dev/ttymxc0" dev="tmpfs" ino=9417 scontext=u:r:init:s0 tcontext=u:object_r:tty_device:s0 tclass=chr_file
init: starting service 'surfaceflinger'...
init: property_set("ro.boottime.surfaceflinger", "33404419003") failed: property already set
init: Failed to bind socket 'pdx/system/vr/display/client': No such file or directory
init: Failed to bind socket 'pdx/system/vr/display/manager': No such file or directory
init: Failed to bind socket 'pdx/system/vr/display/vsync': No such file or directory
init: Untracked pid 298 exited with status 0
init: Service 'surfaceflinger' (pid 291) killed by signal 6
init: Sending signal 9 to service 'surfaceflinger' (pid 291) process group...
init: kill(-291, 9) failed: No such process
init: Successfully killed process cgroup uid 1000 pid 291 in 4ms
type=1400 audit(41.840:7): avc: granted { getattr } for pid=306 comm="netd" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
magik2q7:/ $ type=1400 audit(41.840:7): avc: granted { getattr } for pid=306 comm="netd" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(42.510:8): avc: granted { getattr } for pid=309 comm="iptables-restor" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
random: crng init done
type=1400 audit(42.660:9): avc: granted { getattr } for pid=310 comm="ip6tables-resto" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
init: property_set("ro.boottime.surfaceflinger", "38409906670") failed: property already set
capability: warning: `main' uses 32-bit capabilities (legacy support in use)
init: Untracked pid 355 exited with status 0
init: Service 'surfaceflinger' (pid 347) killed by signal 6
init: Sending signal 9 to service 'surfaceflinger' (pid 347) process group...
init: kill(-347, 9) failed: No such process
init: Successfully killed process cgroup uid 1000 pid 347 in 6ms
type=1400 audit(43.700:23): avc: granted { getattr } for pid=332 comm="ip6tables" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(46.860:24): avc: granted { getattr } for pid=363 comm="netd" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(47.120:25): avc: granted { getattr } for pid=367 comm="iptables-restor" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(47.270:26): avc: granted { getattr } for pid=368 comm="ip6tables-resto" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
init: property_set("ro.boottime.surfaceflinger", "43414861671") failed: property already set
init: starting service 'audioserver'...
init: property_set("ro.boottime.audioserver", "43804554004") failed: property already set
init: Untracked pid 409 exited with status 0
init: Service 'zygote' (pid 366) killed by signal 6
init: Sending signal 9 to service 'zygote' (pid 366) process group...
type=1400 audit(48.300:40): avc: granted { getattr } for pid=386 comm="ip6tables" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(52.040:41): avc: granted { getattr } for pid=429 comm="netd" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(52.380:42): avc: granted { getattr } for pid=432 comm="iptables-restor" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
init: Untracked pid 485 exited with status 0
init: Service 'surfaceflinger' (pid 478) killed by signal 6
init: Sending signal 9 to service 'surfaceflinger' (pid 478) process group...
init: kill(-478, 9) failed: No such process
init: Successfully killed process cgroup uid 1000 pid 478 in 4ms
init: property_set("ro.boottime.audioserver", "48809106338") failed: property already set
init: starting service 'cameraserver'...
init: property_set("ro.boottime.cameraserver", "48960744338") failed: property already set
init: couldn't write 491 to /dev/cpuset/camera-daemon/tasks: No such file or directory
type=1400 audit(53.200:57): avc: granted { getattr } for pid=450 comm="ip6tables" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(57.050:58): avc: granted { getattr } for pid=493 comm="netd" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(57.310:59): avc: granted { getattr } for pid=496 comm="iptables-restor" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(57.370:60): avc: granted { getattr } for pid=497 comm="ip6tables-resto" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(57.460:61): avc: granted { getattr } for pid=498 comm="iptables" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
type=1400 audit(57.550:62): avc: granted { getattr } for pid=499 comm="ip6tables" path="/vendor" dev="rootfs" ino=6479 scontext=u:r:netd:s0 tcontext=u:object_r:rootfs:s0 tclass=dir
4,280 次查看
krishnanbe1994
MY reference board is Sabre_sd board...........and my board name is
Board: MAGIK2Q7
4,280 次查看
jimmychan
Which BSP are you using?
Which board are you using?
