on the reference manual for iMX8M Mini I can find on 6.1.5.4.1 Expansion Device eFuses configuration that :
does this mean that for eMMC BOOT_CFG[6:4] should be 001 binary in any case?
If we have eMMC bus width 8 bit, should it mean that would be 010 binary for BOOT_CFG[6:4] ? not mentioned in this table but mentioned in fusemap table at 6.43.
thank you
Solved! Go to Solution.
Please refer to table 6.43 for this configuration, it have complete information for the bit combination, as you have already seen.
Aldo.
OK, thank you.
Aldo.
