Audio play issue through GUI
1,850 次查看
yashavanthashet
Contributor V
I am using Android pie 9.0 release in our custom board.
Here I am facing a issue related to audio.
I can play audio using tinyplay command, but if I  try to play any audio file through GUI using music app, it closes immediately.
If i try to play any video using gui with any app, it pauses with very first frame, doesn't move further. I have attached logcat output here.
Kindly let me know if anyone has faced this.
Thanks in advance,
Yashavantha
1,718 次查看
diegoadrian
Which i.MX are you using?
Diego.
1,718 次查看
yashavanthashet
Contributor V
I am using i.MX8.
Issue solved after updating sample rate in android_configuration.xml file.
Yashavantha
1,718 次查看
zhengguang_yang
Hi Yashavantha:
How do you fix this bug? I have the same problem.
Thank you very much.
