Audio input not working on CPU board after connecting Audio board
kumarijyoti9994
We are using imx8qxp board(Android Automotive OS) with base board attached. And we have connected the audio board to base board as well. Audio output is working as expected.
However, audio input on CPU board stops working when we connect the audio board.
Please suggest steps on how to enable audio input on CPU board using headphones/earphones.
JorgeCas
If you are using iMX8QXP MEK + base board, the default sound card is CS42888.
Best regards.
kumarijyoti9994
Is there any way to enable input from cpu board when base board is connected?
JorgeCas
No, when base board it is connected to i.MX8QXP the input audio is through MIC and line inputs.
Best regards.
