Asynchronous LCD Driver
1,624 次查看
JohnMcCosh
Has anyone used an i.MX535 with an asynchronous LCD module?  The 320 x 240 TFT LCD that I would like to use has a 16 bit bus (8080) interface utilizing the Himax HX8347G controller.  A driver would be really helpfull.
John
标记 (1)
1,306 次查看
rogerio_silva
There isn't any driver for hx8347G available, but you can use the existent async driver for epson display as a base for your driver development.
On kernel menuconfig, you can find it at:
     -> Device Drivers
       -> Graphics support
         -> MXC Framebuffer support
           -> Asynchronous Panels
             -> Asynchronous Panel Type
                  [ ] Epson 176x220 Panel
The source code file is:
linux/drivers/video/mxc/mxcfb_epson.c
Rgds
Rogerio
1,307 次查看
rogerio_silva
     -> Device Drivers
       -> Graphics support
Rgds
Rogerio
