Ask some suggestion in the usage of IMX6 IPU
JoRadio
I have some questions about the usage method of IPU in IMX6. If I draw the Qt application on /dev/fb0 and use IPU_QUEUE_TASK to draw some images on /dev/fb0 at the same time, will data race occur at this time? If there is data race, how can it be avoided? Could you give me some suggestions
pengyong_zhang
Hi @JoRadio
Your consider is right., data rate may occur. What is IMX6 soc do you use?
B,R
