Ask some suggestion in the usage of IMX6 IPU
168 次查看
JoRadio
I have some questions about the usage method of IPU in IMX6. If I draw the Qt application on /dev/fb0 and use IPU_QUEUE_TASK to draw some images on /dev/fb0 at the same time, will data race occur at this time? If there is data race, how can it be avoided? Could you give me some suggestions
135 次查看
pengyong_zhang
Hi @JoRadio
Your consider is right., data rate may occur. What is IMX6 soc do you use?
B,R
