Ask help for electron application under imx8
askli1983
I develop the vue project, and use the Electron-builder to package it under Linux.
I copy the electron application to the yocto system.
It can’t run well,it give the error ‘Trace/breakpoint trap’.
Do you know imx8 support the electron UI application? How to run it?
Huajun
Tags (4)
mgonzalezg9
Having the same problem. In my case electron-builder installs electron 13.0.0 but when the installed app is launched, Segmentation Fault is thrown.
Zhiming_Liu
Which version you use? You need use electron that support wayland.
askli1983
It is Yocto Zeus,imx6 som chip, could you give some guide about it how to run the electron package application?
