Are there IBIS models for the i.MX6 Solo Lite USB pins?
davidlindley
I have designed in the i.MX6 Solo Lite in my board.  I need to run SI sims on the USB traces.  I have downloaded the IBIS file, mx6sl_416mapbga13x13_autmtv, from Freescale.  I don't think the IBIS file implements a model for the USB pins.  It looks like the models for the USB D+/D- pins are listed as "NC".  Am I reading that correct?
Tags (4)
Hi David
yes, you are right, not all i.MX6 ibis models have usb,
for example i.MX6SDL has
IMX6_DL_S_IBIS : i.MX 6DualLIte and i.MX 6Solo IBIS File.
Probably you can use it. In general it is sufficient
to follow usb layuout guidelines in below document
IMX6SLHDG
Hardware Development Guide for i.MX 6SoloLite - User Guide
chip
