Any SPI Master/Slave + freeRTOS example for MIMXRT1170-EVK?
kennethkong852
Apologies if this question has already been addressed elsewhere. If that's the case, would anyone please point me to such solution?
If not, could someone please point me to such an example (SPI M/S + freeRTOS implementation)?
MCUXpresso or Keil is good for me.
Thank you in advance!
Kenneth
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, I reviewed the example on the SDK for the RT1170 unfortunately the example is not available, but I found the example on the SDK of RT1064 maybe you could port it to your board.
Pavel
