We are trying to run Android(Marshmallow) on imx6Q Sabre AI with bluetooth telephone and FM radio support.
After doing an initial study, we have decided to use following modules:
1. Silicon Labs Si475x/6x-EVB daughter cards for FM Radio.
2. Broadcom BCM4339 for bluetooth telephone.
We would like to confirm 1 & 2 hardware modules have support on imx6Q Sabre AI without any hardware changes?
Also, please confirm drivers and stack for 1 & 2 are available on Android M6.0.1_2.1.0 BSP?
Akhil
解決済! 解決策の投稿を見る。
yes, for hardware, you can refer to the AI schematic, for android, I find a link for wifi module, maybe helpful for you, pls refer to it.
Hello Joan Xie,
Thank you for your valuable suggestion.
From the specified discussionWIFI module AP6335(bcm4339) get stuck on android6.0.1(kernel 4.1.15)) on wifi module , we could refer the "i.MX_Linux_Reference_Manual.pdf". This reference manual is describing the software integration for BCM4339(bluetooth) and Si476x(Radio) on Linux OS.
We are trying to use Android(Marshmallow) on imx6Q Sabre AI.
Is "i.MX_Linux_Reference_Manual.pdf" applicable for Android BSP(Linux Kernel) also?
Akhil
for android, you can refer to the porting document directly
