Android images and development steps for IMX6UL EVK board
2,956 次查看
pramodkanni
Anyone have android images for imx6ul evk board? Please share the details.
I don't see android image for this board in below link:
i.MX 6 / i.MX 7 Series Software and Development Tool|NXP
7 回复数
2,424 次查看
Yuri
  NXP does not support Android for i.MX6UL. Sorry.
Android Things with i.MX 6UL|NXP
Yuri
2,424 次查看
pramodkanni
Thank you for the reply.
Is there any plan to support android in future for IMX6UL EVK board?
We need to know this, because, I think IMX6UL evk supports SDIO 3.0 where SXSDB evk support SDIO 2.0 only.
Kind regards,
Pramod Kanni
2,424 次查看
Yuri
  I do not hear about plans regarding Android for 6UL EVK, since the 6UL
has no GPU.
Yuri.
2,424 次查看
pramodkanni
Thanks Yuri for this info.
So, Argon i.MX 6UL has GPU integrated? Or Android-Things works without GPU subsystem?
Kind regards,
Pramod Kanni
2,424 次查看
Yuri
  Basically it is possible to run Android under software GPU implementation, but
NXP does not use this way.
Yuri.
2,424 次查看
pramodkanni
I am referring to Android_Users_Guide.pdf for nougat.
I see below steps to checkout linux kernel for nougat.
$ git clone git://git.freescale.com/imx/linux-imx.git kernel_imx
# the kernel repo is large. Therefore, this process can take a while.
$ cd kernel_imx
$ git checkout n7.1.1_1.0.0-ga  ---> throws "error: pathspec 'n7.1.1_1.0.0-ga' did not match any file(s) known to git."
After browsing git tags/branches, I don't see n7.1.1_1.0.0-ga at all.
Can you please let me know if there is any change in checking out nougat kernel?
Kind regards,
Pramod Kanni
2,424 次查看
Yuri
  let's consider Android bring up as separate thread.
Also, You may look at https://community.nxp.com/docs/DOC-334008
Yuri.
