Android @i.MX6D/6Q(Dual/Quad) platform "TextView" widget issue
已解决
跳至解决方案
5,112 次查看
Kimizhao
     i run a test app at i.MX6DQ platform with Android R13.4 GA release code, if write a lot of words in a textview, cause a display issuse.
     Other platform doesn't have this issue, i don't know where the difference.
     the test app & fail picture at the attachment.
     Someone can help me?  any suggestion will be very thanks?
Kimi
Original Attachment has been moved to: textviewtest.apk.zip
1 解答
4,439 次查看
lily_zhang
This is known issue for R13.4 and R13.4.1 about GPU libraries. We have got the fixes recently and will publish the updated libraries in the community for the trial.
在原帖中查看解决方案
5 回复数
4,440 次查看
lily_zhang
4,439 次查看
Kimizhao
Hi, xiao li,
     Thx~
4,439 次查看
lily_zhang
Please visit https://community.freescale.com/docs/DOC-93987 for the solution.
4,439 次查看
daiane_angolini
Sorry, what is the issue?
Had you tested on other platforms using the same SDK version?
4,439 次查看
Kimizhao
Hi, i had tested on other platform ICS phone or tablets, there is no this issue.
