Android 6.0 CTS security item test fail
1,602件の閲覧回数
felixhsu
Hi All
The customer run  Android 6.0 CTS will happened security item fail, the fail item as below,
Can you provide patch file or any suggest?
Thanks.
ラベル(2)
3 返答(返信)
1,395件の閲覧回数
diegoadrian
Which i.MX SOC is using your customer?
Diego
1,395件の閲覧回数
felixhsu
Hi Diego
Use the i.MX6Quad SOC.
Thanks.
1,395件の閲覧回数
diegoadrian
Do you happen to know which Android 6.0 release is your customer using? and also the CTS version?
I believe that upgrading to android O8.0.0_1.0.0_GA may help on this case, looking at the CTS 8.0_r4 test report for i.MX6Q SabreSD the following tests are marked as passed which fails in your customer side.
Hope this can help you.
Diego.
