Android 4.4.2 i.MX6DL own apk question
sebastianpszczo
I compiled android 4.4.2 accordian PDF for sd Card for sabre kit and everything works fine. Next step I want customize image and I want to add some *.apk files bbut when I use PRODUCT_COPY_FILE += your/build/tree/$FILE:path/to/location/on/device/$FILE Android is not compiling correctly with error that Prebuilt apk found in PRODUCT_COPY_FILES etc. How can I add some apk file to image in simple way?
Thank You an
SergioSolis
You can try using ADB to install apk's.
Have you used it before?
This may help:
[GUIDE][ADB]Easiest How to use adb, logcat, … | Samsung Galaxy Ace S5830, S5830i, Ace II | XDA Forum...
Sergio
