Android 4.4.2 i.MX6DL own apk question
1,366 次查看
sebastianpszczo
I compiled android 4.4.2 accordian PDF for sd Card for sabre kit and everything works fine. Next step I want customize image and I want to add some *.apk files bbut when I use PRODUCT_COPY_FILE += your/build/tree/$FILE:path/to/location/on/device/$FILE Android is not compiling correctly with error that Prebuilt apk found in PRODUCT_COPY_FILES etc. How can I add some apk file to image in simple way?
Thank You an
1,255 次查看
SergioSolis
You can try using ADB to install apk's.
Have you used it before?
This may help:
[GUIDE][ADB]Easiest How to use adb, logcat, … | Samsung Galaxy Ace S5830, S5830i, Ace II | XDA Forum...
Sergio
