Android 10 and 11 on IMX6
已解决
跳至解决方案
6,598 次查看
rahmanuh
Does anyone know if there will be a support for Android 10 and 11 for IMX6?
Thank you very much.
Rahmanu
1 解答
6,589 次查看
nxf63675
Hi rahmanu,
There is not support or plans for support Andrioid 10 and 11 on the imx6, sorry for the problems that this might cause you. You can find the supported devices on the next link:
https://www.nxp.com/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applications...
Israel.
在原帖中查看解决方案
7 回复数
6,585 次查看
vinothkumars
Senior Contributor IV
Hi @rahmanuh ,
It will run, But, I did not test. why I am telling this should compatible because imx6 related board files definitely will  present in source. So, we can able to select the board.
Vinothkumar Sekar
6,564 次查看
rahmanuh
Hi Vinothkumar,
Thanks for your reply. Yes I think so, but I suppose it will need some configuration outside the documentation from NXP. I will try to test it to see if it can run flawlessly. My biggest concern is that I wanted to see if the WiFi driver for 88W8997 and the device itself work.
Rahmanu
6,590 次查看
nxf63675
Hi rahmanu,
Israel.
6,432 次查看
rahmanuh
Hi Israel,
I am just repeating arindamroy's question.
Why is Android 10 and 11 not supporting imx6 platform?
Thanks.
/rahmanu
6,413 次查看
nxf63675
Hi rahmanuh,
As our EVK does not match the minimum support hardware target of the latest release we decide to not continue updating to the newer versions, of course, someone could build a custom board that matches these hardware specifications but we do not support it from our side.
Israel.
6,565 次查看
rahmanuh
Hi Israel,
Thanks for sharing the link.
Rahmanu
6,482 次查看
arindamroy
Why is Android 10 and 11 supported on imx6? Is there a technical limitation?
