Android 10.0.0 2.3.0 Trusty missing i.MX8MN target
Search instead for
bmx666
There is no imx8mn SOC as target when build Trusty OS from manifest imx-trusty-android-10.0.0_2.3.0.xml
Only imx8m, imx8mp, imx8mm
Tags (2)
gusarambula
Hello Maxim Paymushkin,
Are you using the script included on the Install Source Package for this Android release? If not, it is available on the link below.
https://www.nxp.com/webapp/Download?colCode=Q10.0.0_2.3.0_ANDROID_SOURCE&appType=license
You would need to follow the instructions on the Android User’s Guide (link below, as this is the latest version, if you want to look for it at a later date you may need to download the documentation package for this BSP)
https://www.nxp.com/docs/en/user-guide/ANDROID_USERS_GUIDE.pdf
I hope this helps!
bmx666
Hello gusarambula
Thanks, I missed NOTE  in https://www.nxp.com/docs/en/user-guide/ANDROID_USERS_GUIDE.pdf
For i.MX 8M Nano EVK, it use the same Trusty target as i.MX 8M Mini EVK. Use make imx8mm to build the Trusty OS image, and copy the file lk.bin to ${MY_ANDROID}/vendor/nxp/fsl-proprietary/uboot-firmware/tee-imx8mn.bin
gusarambula
I hope this helps!
